 Old 08-04-2015, 05:02 PM   #1
Ms3jerm's Avatar
Posts: 94   (View Stats)
Ms3jerm will become famous soon enough
Default AFR check engine light.
So I installed my hpfp internals on a basically brand new pump. I was running lean at idle before and the dealership said it was the hpfp and replaced it. Well I also installed my downpipe. Everything was fine for about 3 days I drove a lot in that time frame. Now I have codes p2187(lean at idle) and p2096(target AF feedback system too lean) my afr has been sitting around 20-21 at idle and I've seen it get up to 26 on its own. WOT it seems to be doing okay cause it'll drop to 8.7-11.. Anyone have any tips on how I can fix this problem or what the issue may even be? Thanks. I'm sure there are other threads on this but I'm pretty new to the forums and still getting used to navigating them. Sorry in advance for that. Oh and I'm also on the Cobb 91 sf+dp tune
Ms3jerm is offline   Reply With Quote
 Old 08-04-2015, 05:37 PM   #2
littleloogy's Avatar
Posts: 4,005   (View Stats)
Lean at idle may mean you have a vacuum leak. Unmetered air is getting into your engine. You ECU can only add so much fuel before it throws a lean code. I would check your engine bay for loose or missing boost tubes/vacuum hoses. If non are found a boost test will eliminate the possibility of a boost leak
If you could take a log with your access-port and post it up on this thread We might be able to better see what's going on.
Sent from my iPhone 6
 Old 08-04-2015, 06:33 PM   #3
Ms3jerm's Avatar
I'll check the hoses later on and take a log
 Old 08-04-2015, 07:19 PM   #4
08cosmic3's Avatar
Posts: 2,920   (View Stats)
08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world
Groaned at 54 Times in 43 Posts
Wiggle the wires on your MAF sensor harness and listen for engine idle change or monitor while you do this and see ig AFR or fuel trims change. I had 2187 and it was due to the black ground wire on the MAF harness. Clean the MAF sensor also.
EBTEC Manley Built // GT3071R // FreekTuned // Freek 3.5" Intake // Ported IM // Perm Plate Dual CC // Catless DP // CNT CB // Tokay V 1's // Autotech // AEM Failsafe // TR8 IC// GFB // JBR 88 RMM // DM PMM // JBR 70 TMM // ACT 6 puck prolite fly // Cobb RSB // 6 pc chassis braced // Koni FSD's // Cobb Springs // EGR Full delete // SWAS switch // SS brake lines // 100% Methanol Injection D14
____________________________________________Dragon Slayer _________________________________________________
08cosmic3 is offline   Reply With Quote
 Old 08-11-2015, 01:02 AM   #5
Ms3jerm's Avatar
So I got a chance to take a look. The Afr code is taken care of my secondary O2 sensor got wiggled loose from the exhaust. Now I'm just still getting a lean at idle code.
 Old 08-11-2015, 05:41 AM   #6
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Still seems like there is a leak somewhere, double check all hoses and clamps, make sure everything tight, and fully connected. MAF sensor clean? MAF Sensor O-ring still good? Tightened there? No intake hoses loose, clamps not fully tightened? Check vacuum lines also.
 Old 08-11-2015, 09:04 AM   #7
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Check the breather hose from the valve cover to the intake boot.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CHECK ENGINE LIGHT 08ms3grey MazdaSpeed 3/6 - ECU Computer Tuning 12 12-14-2013 02:49 PM
Check engine light came on after 7 months with light mods SwizzleSpd MazdaSpeed 3/6 - Turbo Induction 10 01-03-2013 05:15 PM
check engine light Dmayo MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 08-08-2012 01:13 PM
engine idle and check engine light msalva2 MazdaSpeed 3 - Engine, Transmission & Driveline 35 07-25-2012 04:48 PM
Check Engine Light Stingray69 Gen2 MS3 General Discussion 5 11-18-2011 04:37 PM
Page generated in 0.27021 seconds with 24 queries
