 Old 09-19-2015, 09:32 PM   #1
Turbojocky13's Avatar
Posts: 96   (View Stats)
Turbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant future
Groaned at 32 Times in 13 Posts
Default Any body else use c16?
Have always used unleaded fuels, from pump gas to ms109. This setup is the first time I have ever used a leaded fuel (c16). it's not my daily so I was wondering if anyone has had any long term effects of using leaded fuels because I haven't seen that many miles on (c16), less than 500 miles. I know eventually it will fry the O2 sensor but other than that, Are there negative effects on anything else.
- Forged eagle rods - Wiseco pistons - AutoTech CDFP - 4in TIH - 4in Mrp Maf housing - Custom Fiberglass RamAir - Accessport purpledrank tune - Stiffy Torque Damper - S366 Borgwarner Turbo -SureMotorsports Balance shaft delete - Air to Water intercooler - Arp headstuds - Spark plugs itv22 -RaceRoots T4 turbo manifold - 3in downpipe dump - Egr delete - 3 bar map sensor (Bosch) - Focus ST Direct Port Meth Intake Manifold- No BOV - Tial 38mm wastegate -GrimSpeed 3 port boost controller - Torque solutions rear engine mount - Torque solutions short shift plate - Torque solutions shifter counter weight - DEI heat shielding - 100% Gutted - 245/40/18 street radials- Streetunit Solid Motor Mounts- 3in Intercooler piping- etc etc...
Turbojocky13 is offline   Reply With Quote
any ms6 body philbie MazdaSpeed 3/6 - Appearance 66 11-27-2010 03:48 PM
Lingenfelter releases info on engine packages, body kit for 2010 Camaro body kit Haltech Automotive News 0 05-04-2009 10:00 AM
Page generated in 0.22012 seconds with 20 queries
