 Old 11-10-2010, 04:19 PM   #1
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Default APR 2.0l VW CDFP
Anyone running this pump? Im kinda thinking about it.
APR 2.0T FSI High Pressure Fuel Pump
2006 Mazdaspeed 6
 Old 11-10-2010, 04:26 PM   #2
DSIT995's Avatar
Posts: 1,768   (View Stats)
DSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the world
Looks like it would work, as long as you can connect are oem wires harness
08.5 MS3 GT - COBB AP : HPFP : DM CatchCanBack to almost stock!
99 Miata NB - Stock for now
Building a EFR 6258 Kit w/ Megasquirt 2 enhanced, COPs, Methanol, 750cc Injectors
DSIT995 is offline   Reply With Quote
The Following User Says Thank You to DSIT995 For This Useful Post:
06Speed6 (11-10-2010)
 Old 11-10-2010, 04:34 PM   #3
Speeeeeed
06Speed6's Avatar
I didnt think of that... If I am sending a spare pump in to them I would assume that it would be returned with the same connector, but I wonder if their test stand works with the different connector.
2006 Mazdaspeed 6
 Old 11-10-2010, 04:34 PM   #4
SSinstaller's Avatar
Posts: 3,984   (View Stats)
Groans: 60
IIRC that's exactly what you get when you buy the CP-E pump..
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
kilik2 (11-11-2010), Speed3eak (07-06-2011)
 Old 11-10-2010, 04:41 PM   #5
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
cpe for the victory
Monotonous ONE is offline   Reply With Quote
 Old 11-10-2010, 04:42 PM   #6
smitty5788's Avatar
Posts: 1,065   (View Stats)
smitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the world
Groans: 215
why would you get that when CPE offers the same thing.
2011 DGM STI Sedan - Fully Bolted FP Green Setup
368WHP / 335WTQ
SOLD: Black Mica 2010 MS3 - Tech Package -CPE Catless DP - CS CBE - SURE Aeros - SURE Sidewinder - TS BPV - CPE HPFP - JBarone Shifter Bushings - TRZ RMM - MD OCC - Progress RSB - DashDAQ - 18x8.5 +45 Rays Gram Light 57F - 235/40 Potenza RE760
smitty5788 is offline   Reply With Quote
 Old 11-10-2010, 05:19 PM   #7
Speeeeeed
06Speed6's Avatar
The APR pump seems to be more robust and have additional parts and testing, and it gets flow benched, for an extra $30. Seems like a deal to me. Lifetime warranty and near zero fail rate as well.
2006 Mazdaspeed 6
 Old 11-10-2010, 05:38 PM   #8
smitty5788's Avatar
Groans: 215
Cpe tests and gives you the results also, connector is correct also, just a thought
368WHP / 335WTQ
 Old 11-10-2010, 05:39 PM   #9
Speeeeeed
06Speed6's Avatar
Shot an email off to them about the connector, ill see what they say.
2006 Mazdaspeed 6
 Old 11-10-2010, 05:41 PM   #10
smitty5788's Avatar
Groans: 215
Well if they can change it it looks like a pretty good alternative considering cpe is out of stock frequently
368WHP / 335WTQ
 Old 11-10-2010, 05:54 PM   #11
Speeeeeed
06Speed6's Avatar
Yeah they are out currently and this looks at least as good, if not better, and its in stock for an extra $30.
2006 Mazdaspeed 6
 Old 11-10-2010, 05:55 PM   #12
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Well I would just go with the cpe pump but if I were to go his route I would simply swap the spill valve which had the connector attached to it. So you send them your oem pump with their style connector and have your stock one on their pump.
Still I think this is sorta pointless.
 Old 11-10-2010, 06:00 PM   #13
Speeeeeed
06Speed6's Avatar
Yeah its kinda dumb that CP-e cant stock the parts, I dont know how they even warranty them if there are none on the shelf.
2006 Mazdaspeed 6
 Old 11-10-2010, 06:50 PM   #14
Groans: 60
The CP-E pump IS the APR pump...
One is no better than the other..except for the fact that CP-E actively supports the Mazda DISI community and APR has chosen not to..
essejkcamraw (11-18-2010), FreeFlyFreak (11-10-2010)
 Old 11-10-2010, 07:42 PM   #15
Speeeeeed
06Speed6's Avatar
Rofl I thought they claimed theirs was designed specifically for our car, if its the APR pump thats been farmed out to them then that claim its pretty dubious since the APR pump was specifically not designed for our car.
I do seem to remember them getting called out on 6club about being the APR pump, but I dont remember them owning up to it.
No wonder they cant keep them in stock, its not even their pump.
2006 Mazdaspeed 6
 Old 11-10-2010, 08:29 PM   #16
driver311's Avatar
Posts: 1,769   (View Stats)
driver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the world
I think it fucking hilarious that so many people swing from cpe's nuts and proclaim they are the "only" ones to have designed a fp that works properly, when it was apr that did all the r&d and cpe takes the credit. I mean its cool that cpe offers it and doesnt mark it up anymore than apr does but what a joke that this whole site swears by "cpe's" pump when all along its been Apr's pump. Id buy from apr over cpe any day. Cpe has great products but imho they are overpriced.
Congrats on your new pump purchase and keep us posted on how it works.
2008 Mazdaspeed3, Fully built then fully parted. Sold
2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily
Mazdaspeed
12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp
11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp
driver311 is offline   Reply With Quote
The Following User Says Thank You to driver311 For This Useful Post:
 Old 11-11-2010, 08:11 AM   #17
Groans: 60
It seems to me that you're Anti-CPE about 100% of the time, what would you call the exact opposite of a nutswinger?
If they're the same pump and cost the same why would you choose APR over CP-E?
FreeFlyFreak (11-14-2010)
 Old 11-11-2010, 09:51 AM   #18
smitty5788's Avatar
Groans: 215
They stock one for warranty claims, they dont usually have to worry about it but they do stock one though.
If they will switch the connector and its the same price then congrats on finding another option for people. no one here can deny though that if they wont switch it CPE is the only option. PTP is gone and garbage anyway.
368WHP / 335WTQ
 Old 11-11-2010, 09:59 AM   #19
kilik2's Avatar
Posts: 1,254   (View Stats)
kilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the world
Groans: 127
Groaned at 40 Times in 31 Posts
CPE pumps are made/tested by APR ...old news.
kilik2 is offline   Reply With Quote
The Following User Says Thank You to kilik2 For This Useful Post:
phillyb (11-13-2010)
 Old 11-11-2010, 10:10 AM   #20
Tripple OG
NJSPEED3's Avatar
Groans: 113
Cpe never claimed that they make the pumps themselves for one.
2 people hang on their nuts simply because they never failed. There has been one failure since they began selling them.
They dont stock parts because they would simple replace the entire pump in case of a failure, which is very rare to happen.
The few failure that they have had was due to install error.
Cpe makes parts for arp as well so I dont see the big deal here.
 Old 11-11-2010, 08:46 PM   #21
driver311's Avatar
Not 100%, but I do think they are overated. They make some cool parts for sure. I just have my reasoning, but its no big deal. In fact I have some cpe parts on my car because I have to. I just............ nevermind its not even worth it. Dont mean to rag on cpe they do some cool shit for the mazdas but its hard to get a bad taste out of your mouth you know? LOL
Mazdaspeed
 Old 11-13-2010, 05:52 PM   #22
4G63's Avatar
Posts: 1,479   (View Stats)
4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world
Groans: 123
Groaned at 157 Times in 79 Posts
OP I too was looking at the one u posted and was hoping to get it but I'm not made of money and the KMD internals seem to be a good enough option for the performance/money. I'm building this winter so I need to decide whether to spend $934 on a whole new pump or $300 on internals that have seemed to work fine on big turbo cars NJSPEED3 included. Not meant to hijack I apologize regardless just here to learn and listen.
2003 Evo VIII
BUILD PLANS: LR 2.0/2.4, 6466, 800+whp. Shooting for 9s at full weight. Time is on my side, gonna take forever.
Old: 2009 White MS3. Fully bolted and tuned. Sold
4G63 is offline   Reply With Quote
The Following User Says Thank You to 4G63 For This Useful Post:
 Old 11-13-2010, 06:36 PM   #23
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
i had the kmd v1 internals. they always held up for me, and they are still running on a local buddy's car...
 Old 11-13-2010, 07:53 PM   #24
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
i can't believe i read half the posts in this thread.
anthony, i'm somewhat curious as to why your panties are bunched.
i'm also curious as to why you're name is brown and not green.
to take that one step further, why the fuck would we listen to you?
i rarely agree or even acknowledge kilik, but dude hit the nail on the head...
if this if your first time hearing of cpe's pump being the same as the apr pump, then damn...you guys got some research to do...
a lot of fucking research.
fuel pumps - bane of 2.3 mzr disis' existence
The Following 3 Users Say Thank You to phillyb For This Useful Post:
FreeFlyFreak (11-14-2010), kilik2 (11-15-2010), MATT DAMOND (11-13-2010)
 Old 11-14-2010, 01:45 AM   #25
Speeeeeed
06Speed6's Avatar
Hey I remembered the thread on 6club, I had just forgotten about it cuz it was 3 years ago lol.
Im prolly not gonna go with the APR pump.
2006 Mazdaspeed 6
 Old 11-14-2010, 09:37 AM   #26
driver311's Avatar
Im not sure about name. Also listen to me about what? I didnt tell anyone to do anything. I just didnt know apr made cpe pumps. REmember I was off the forums for 18 months. Just recently got back on. Just thought it was funny thats all, no biggie. Im "pumped' people are having good luck with apr "cpe" pumps. LOL that was my attempt at funny.
i wish I could say the same about my ptp pump. I havent been that lucky. Hopefully my new pump will work or I will have to buy a apr/cpe pump. Also unlike most the peeps on here I dont have a computer job I can research shit 12 hrs a day on. I work 60 hrs a week and find it hard during the week to even log in. Having two kids and hobbies other than the internet make it hard to research every lil thing I do. Most times I depend on vendors to keep me going and me just fucking with shit and learning. When this car first came out I learned everything on my own and posted all my findings. I will continue to do that as I can. Sorry if I came off angry I just have bad days sometimes and it shows in my posts. LOL
Mazdaspeed
FreeFlyFreak (11-15-2010)
 Old 11-14-2010, 09:54 AM   #27
laxplayermjd's Avatar
Posts: 779   (View Stats)
laxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the world
may be a stupid question. does anyknow what they use for internals? and can we source those parts?
2007 Speed 6 Liquid Platinum Metallic, DIY Duplicolor Graphite Wheel Paint, Clutchmasters FX100, Stock again with 91 ots tune
laxplayermjd is offline   Reply With Quote
 Old 11-15-2010, 05:40 AM   #28
kilik2's Avatar
Groans: 127
I am screenshotting this later.
 Old 11-15-2010, 05:57 AM   #29
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
cpe is selling the apr pump under their name.
2015 Mazda 6
 Old 12-26-2010, 01:32 AM   #30
that1rowdyracer's Avatar
Posts: 245   (View Stats)
that1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the world
people still baggin on cp-e yet people keep buying from them, they must be doing something right to keep in buisness
that1rowdyracer is offline   Reply With Quote
 Old 12-26-2010, 04:16 AM   #31
HXC LOL's Avatar
Posts: 107   (View Stats)
HXC LOL has a brilliant futureHXC LOL has a brilliant futureHXC LOL has a brilliant futureHXC LOL has a brilliant futureHXC LOL has a brilliant futureHXC LOL has a brilliant futureHXC LOL has a brilliant futureHXC LOL has a brilliant futureHXC LOL has a brilliant futureHXC LOL has a brilliant futureHXC LOL has a brilliant future
Groaned at 6 Times in 1 Post
The name and the support.
APR has made a huge name for themselves in the VW community, but really you can get parts that work just as well at a fraction of the price. People still buy APR products frequently despite that painfully obvious fact.
Oh and epic bump btw.
I drive an underpowered Volkswagen.
HXC LOL is offline   Reply With Quote
Possible new CDFP 06Speed6 2010 MS3 - Fuel, Nitrous & Water Injection 6 11-19-2009 03:41 PM
Best CDFP? Lex MazdaSpeed 3 - Engine, Transmission & Driveline 34 04-07-2009 07:30 PM
AWE CDFP SpdFreak MazdaSpeed 3 - Engine, Transmission & Driveline 27 12-24-2008 02:17 PM
AP and cdfp tsb? booya620
Cobb Access Port/Maps
6 11-04-2008 02:55 PM
Page generated in 0.47844 seconds with 34 queries
