 Old 10-08-2015, 06:27 PM   #1
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
specvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the world
Groaned at 54 Times in 27 Posts
Default Assistance with AEM boost safe output
Bare with me here guys..
I recently installed an AEM meth kit (30-3300); Boost dependent controller.
Everything is hooked up perfectly and is running as it should ....BUT (big butt i know) I haven't hooked up any sort of failsafe, yet. I will once I really know which one I want and have a better understanding on how it works, hooking it up, etc.
For now I at least want to hook up the boost safe out to either the EBCS or even a horn for some sort of extra measure. ***The wire to this is a 1.7 amp switched ground. It activates when the system is armed and error code flashes or low on fluid.***
Has anyone with an AEM kit or other kits with similar trigger out wired it to the EBCS?
Pics or explanation would help. I just have this visual it looking like a hot mess with all the wires and a relay.
I am super novice when it comes to circuits/wiring shit. If I decide to use a horn to be triggered; will it still require an NC relay and setup the same way? If not then what/how will I need to wire it?
*COBB: AP, shifter weight *BITWISE: Harness, 3bar BNR: S3v2 *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, EGR delete, WP *GRIMMSPEED: EBCS *TWM: Full Shifter *KDM: HPFP internals *DENSO:ITV22 *FORD: syn trans fluid *OBX: TBE *BILSTEIN: B8 Sport *SWIFT: Spec-R springs *GTSPEC: 4point ladder brace, rear subframe brace *NITTO: NT-05 * Whiteline: BSK *MOOG: F/R endlinks* SPC: Adj. camber arms *MORIMOTO: 5K HID elite
specvspeedfreak is offline   Reply With Quote
 Old 10-29-2015, 07:35 PM   #2
@NCspecV81; @GCPhotographers;
How have you guys using the boost safe out (green) wire?
 Old 10-29-2015, 07:50 PM   #3
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
As far as boost is concerned IMO get a guardian angel.
It has a input from a methanol fail safe output.
As far as a horn you can get a relay from power to your negative meth output to trigger the horn wire in the steering column. You can also hook it up to a siren or even a led.
Get with a stereo shop and they should be able to take car of your electrical needs.
MECP
2012 BM
Rfinkle tune in progress
 Old 10-29-2015, 11:00 PM   #4
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
You could look into an AEM AFR/boost failsafe with a relay triggering the ground to the EBCS. Just about the same purpose as the guardian angel but gives you an AFR and boost gauge in one.
The Following 2 Users Say Thank You to jdmage_mx5 For This Useful Post:
Justin@Freektune (10-30-2015), MS3Shadow (10-30-2015)
Possible boost leak need assistance bigspender 2010 MS3 - Troubleshoot/Diagnostics 3 06-08-2014 04:49 PM
Do I need a bcd/fcd? How much boost is safe? nattun MazdaSpeed 3/6 - Turbo Induction 18 09-30-2012 04:01 PM
Safe Boost without DP Zak MazdaSpeed 3/6 - ECU Computer Tuning 7 02-16-2010 01:54 PM
uping boost safe? bombdotcom MazdaSpeed 3/6 - Turbo Induction 2 06-09-2008 12:24 AM
Page generated in 0.26219 seconds with 22 queries
