  • 1 Post By Black Metal
 Old 03-29-2012, 02:40 PM   #1
SpeedCheese's Avatar
Posts: 44   (View Stats)
SpeedCheese is a glorious beacon of lightSpeedCheese is a glorious beacon of lightSpeedCheese is a glorious beacon of lightSpeedCheese is a glorious beacon of lightSpeedCheese is a glorious beacon of lightSpeedCheese is a glorious beacon of light
Default benefit of running higher octane on a 91 map
Someone at my local auto parts store told me yesterday that running higher octane gas will give a notable improvement in power, even without tuning for it. I was under the impression that, unless you're getting knock, running higher octane doesn't make any difference. In order to get the benefits of, say, 101 fuel at the track, you have to tune for it (i.e. adjust timing).
Will running 101 (unleaded of course) on my 91 octane map give me improved performance. I've got very little knock even at WOT with my tune.
Liquid Pt Metallic MS6: Cobb SFI & TIP / CP-e DP with high-flow cat / CP-e RMM / CP-e RDM / ETS CBE / Turbo Smart dual-port BOV-BPV / Cobb AP (self-tuned) / Konig Milligrams (18x8.5) / BFG G-force SuperSport A/S 235/40s / Denzo Iridium plugs (ITV 22) / G2 painted calipers / Power Slot rotors / Hawk HPS brake pads / VG sharkfin / LED interior and fog lights / TWM Stage 1 SS + bushings / BC coilovers / SPC ball joints / CS TMIC / Autotech CDFP internals / Whiteline RSB
SpeedCheese is offline   Reply With Quote
 Old 03-29-2012, 02:50 PM   #2
Pendarus's Avatar
Posts: 165   (View Stats)
Pendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the world
Groans: 52
Unless you tune for it there's no point in going over 91 octane (on a stock or 91 octane map). Only reason for going higher octane is for using a more aggressive tune without getting knock. If you're not getting knock on 91 octane you're not going to get it on 101. Your ECU will adjust to combat knock, but it isn't going to go "oh man...higher octane...better up the powa on this bish" without you telling it to.
Pendarus is offline   Reply With Quote
The Following 5 Users Say Thank You to Pendarus For This Useful Post:
ak_spray (04-14-2012), AZSPEED3 (03-29-2012), MSFer87 (03-29-2012), phate (03-29-2012), Pseud0logik (03-29-2012)
 Old 03-29-2012, 04:26 PM   #3
That's what I thought, and what I told the guy. He was so adamant I 2nd guessed.
 Old 03-29-2012, 04:28 PM   #4
MSFer87's Avatar
Posts: 1,162   (View Stats)
MSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the world
Groans: 83
Yeah unless you are planning on running a spiceytune by Cobb then running any higher octane then needed is unnecessary, and is a waste of money.
-#1 2007 Mazdaspeed 3 GT Black Mica - BBS RX in Dark Gray, KW V2s, SPC Camber Arms, Cobb AccessPORT w/ JBR mount, Full-Race Prostock Mani, TurboXS FMIC, Grimmspeed EBC, ACT 6 puck & flywheel, TWM STS, PTP Internals, Cobb SRI w/ TIP, Cobb Shift Weight, TurboXS BPV, TurboXS Full TBE, JBR Trilogy, JBR RSB, Cobb FSB...........needs bigger turbo
-1970 Chevelle - Needs full resto
MSFer87 is offline   Reply With Quote
 Old 03-29-2012, 04:33 PM   #5
Black Metal's Avatar
Posts: 699   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 78
Groaned at 6 Times in 6 Posts
Higher octane fuels are actually harder to ignite. You can see a decrease in performance by running an octane higher than you're tuned for. Parts store guy doesn't know what he was talking about.
Blackrider likes this.
- 2006 Black Mica MS6 -
- GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP -
- Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught -
- GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete -
12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30
12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20
- 2004 Silver Sunlight Metallic RX-8 -
- 6MT - Stock -
Black Metal is offline   Reply With Quote
The Following User Says Thank You to Black Metal For This Useful Post:
Blackrider (04-10-2012)
 Old 03-29-2012, 06:03 PM   #6
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
thats why you never listen to an auto store employee. you go in for brake lines and they give you heater hose and say itll be fine
also, i was at a dyno day once with a bunch of supras and one kid wanted to be cool and have crazy numbers with race gas. he dynoed on pump and then filled with race gas and his numbers dropped like crazy lol...we laughed at him
 Old 04-07-2012, 03:47 AM   #7
tunerlover's Avatar
Posts: 81   (View Stats)
tunerlover is a splendid one to beholdtunerlover is a splendid one to beholdtunerlover is a splendid one to beholdtunerlover is a splendid one to beholdtunerlover is a splendid one to beholdtunerlover is a splendid one to beholdtunerlover is a splendid one to behold
Groaned at 30 Times in 11 Posts
putting higher octane without a tune will hurt performance.(unless you are knocking pretty bad)
101 will run richer and that can cause knock as well.
To take advantage of race gas you need leaner afrs and advanced timing.
tunerlover is offline   Reply With Quote
 Old 04-08-2012, 10:10 AM   #8
Ok, thanks for all of the input, peoples. The highest octane pump gas I can regularly get is 91. Do any of your reccommend an additive to reliably boost octane so I could reliably dial in one of the Cobb OTS 93 maps? Related; Would it be reasonable to try to tune for 93 with gas+additive that may be 94 to 96 or something? Just as long as it is over 93 and not a lot higher?
 Old 04-08-2012, 10:14 AM   #9
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
e85. dont bother with additives.
The Following User Says Thank You to p057 For This Useful Post:
Pseud0logik (04-10-2012)
 Old 04-08-2012, 10:22 AM   #10
bigriver's Avatar
Posts: 1,123   (View Stats)
In the long run it would be better to get a custom tune for the 91 octane. Performance will be much better than any ots map.
 Old 04-10-2012, 10:24 PM   #11
x09MS3GT's Avatar
Posts: 406   (View Stats)
x09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the world
Groaned at 92 Times in 11 Posts
Unless of course, your in teh same boat i am, and the only octane available from any pump in your entire STATE is 90.....
I wait until i get a gas light, then i fill. Roughly every 2 weeks, daily driven and all.
I fill my car with 4 gallons of Sunoco Super GT Plus 104 unleaded, and then usually squeeze in about 8 to 9 gallons of pump Shell 90.
That combo right there allows me to run a Stage 1 93 octane map without any KR what-so-ever. Still experimenting on a bit of timing advancement, and so far 2 degree's past OTS and no knock yet.
Reason i run the 93 is mainly because, no one else here bothered to mention , another downfall of running a higher octane than tuned for, you start to get really high EGT's.
So yea, running the 93 map seems to work for me like a champ.
--COBB SRI--COBB TIP--COBB SF AIRBOX--COBB V2 FMIC--COBB XLE-BPV--COBB DP--COBB CB-E--COBB V3 AP--COBB RMM--COBB KNOB--COBB SHIFTER WEIGHT--NGK 6510's--Autotech Internals--H&R Springs--Bilstein B8's--CpE Triple Gauge Cluster w/ Prosport E-Boost Gauge + Prosport LSU 4.9 Wide-band
--E85 FREEKTuned --
x09MS3GT is offline   Reply With Quote
 Old 04-10-2012, 10:31 PM   #12
Posts: 12,649   (View Stats)
Every car is different and after tuning 60+ speeds 91 octane in one area is the not the same as another. Sooo ... if you have KR you want to either get higher octane or to change the tune if it's not available.
Performance Benefit of SPC Camber Adjustable Ball Joints zer010gic MazdaSpeed 3/6 - Suspension & Brakes 2 03-19-2011 08:20 AM
First Ferrari 458 Italia auctioned off to benefit Haiti Haltech Automotive News 0 03-23-2010 07:40 AM
93 octane safe for a v102 91 octane map? SLOMS3
Cobb Access Port/Maps
2 12-20-2008 03:26 PM
Anyone Running v103c Stage2+ SF 91 Octane Federal? badams118
0 12-03-2008 02:11 PM
More knock on higher octane? Lex MazdaSpeed 3/6 - ECU Computer Tuning 20 10-09-2008 03:39 PM
Page generated in 0.33106 seconds with 29 queries
