| MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection Have a CDFP fuel pump question? Do you want to add Nitrous or Water Injection to your Mazdaspeed 3/6 ? Please come on in! |
![]() | | #201 | ![]() |
| Banned ![]() Join Date: Dec 2010 Location: Middlesex County, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 170
Groaned at 188 Times in 55 Posts
| Not Ranked : 0 score
Do we have a guesstimate?! Or a range at least? And could you point me in the direction for more information on this Ported Injectors, and roughly guesstimately where this would put me for AWHP Fuel wise? Many Thanks, If I could hug you Marcus I would =) (Cyber Hugs Marcus - No Homo) ~JaKe | |
![]() | | #202 | ![]() |
Rep Power: 6709 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,343
With a fuel pressure upgrade you might be able to hit 500hp, with stock pressure maybe 400-450 depending on a number of factors. With the +25% injectors and max everything maybe 650hp but at that hp range the cdfp might become a factor.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 3" ID 700hp I/A intercooler, ATP catless DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, CP-e whale penis, CP-e sri, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, 2007 MS6 p/s pump, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant |
![]() | | #203 | ![]() |
| Not Ranked : 0 score And where do we buy these injector upgrades?
![]() | | #204 | ![]() |
![]() Join Date: Feb 2009 Location: gilbert, az
Rep Power: 1865 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,856
Groans: 237
Groaned at 70 Times in 36 Posts
Move to Himalayas, make like a corrected 1000whp on stock fueling easy.
__________________ 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, hallman pro rx bc, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Turbosmart Hybrid bpv, SURE TIG's + coolant bypass, ITV24's, CP-E 75d RMM, Medefail Tranny mount, DDM 35W 6000K HID's, SURE Counterweight, 18x8 245/40 NT-05's up front, R: 225/45 Sport Maxx TT's 390whp/400wtq |
![]() | | #205 | ![]() |
![]() Join Date: Nov 2008 Location: Tucson, AZ
Rep Power: 4208 ![]() Thanks: 4,085
Groans: 103
Groaned at 21 Times in 19 Posts
| Not Ranked : 0 score You can't. Only one person has upgraded injectors, and the company that did them said they would never do another set again.
__________________ ![]() |
![]() | | #206 | ![]() |
![]() Join Date: Dec 2009 Location: San Antonio, TX
Rep Power: 4097 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,096
Groans: 89
Groaned at 103 Times in 69 Posts
Wtf.. figures^
![]() | | #207 | ![]() |
| (Toe-kay) ![]() Join Date: Jan 2011 Location: Oakville Ontario Canada
Rep Power: 8686 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,687
Groans: 501
Ptp is hard at work trying to modify the stock injectors. Erich, and word on progress with that?
__________________ ![]() ![]() Tokay Racing BeCuse Seals. BeCuse you need these. Demodded. Mwho? |
![]() | | #208 | ![]() |
HPFPUPGRADE - Can you tell us your progress, oh wait. . . Three morons wanted him banned so I guess he can't really say shit now can he SMH ~JaKe | ||
![]() | | #209 | ![]() |
![]() Join Date: May 2009 Location: Clw/ NPR Florida
Rep Power: 1312 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,845
Groans: 85
WWpearlms6......why you keep beating the dead horse with the upgraded injectors ?? just get DJ's 5th port fuel system and be done...
__________________ 2006 speed6~Cobb AP~COBB custom E-tune~CobbTIP-CobbSRI~CPeHPFP~ATPdp~Magnaflow exhaust~Denzo plugs~Forge bov~Matt Damon's Occ Kit~Treadstone FMIC~PG V1 Ex.Manifold~CPE safe seals~SU EGR block off plate~SURE TIG intake mani gasket~SU lower motor mount~AWR trans. mount/passenger mount~SU shifter bushings~CPE diff mount~H&R springs~Tenzo type M ~235/40/18 Firestone Indy 500 Wide Oval~ipod adapter~HD lip~Prosport boost gauge~ TWM Desert Eagle Shift Knob~JBR shift plate~spin on oil filter~Block8head Vent Pod~ported intake manifold w/ VTCS delete~EBC red pads w/ slotted rotors~4500k HID fogs 2 gal. E85 mix !!!" A woman's asshole is like a 9-volt battery..U know its wrong, but sooner or later ur gonna put ur tongue on it !! " |
| The Following 2 Users Say Thank You to jracer For This Useful Post: | TWOptSL0W (06-05-2012), WWPearlMS6 (06-05-2012) |
![]() | | #210 | ![]() |
SO I found the old thread that elaborates on the one known upgraded injector kit made It was whoosh@Realtune who bought them first and wrote about it Than SSinstaller bought Whoosh's set. The injectors were upgraded by a gentleman named David Deatsch WEBSTITE: http://www.deatschwerks.com/ Can you fellaz chime in on your experience with the upgraded ones and how they have been working and tuning with them etc. etc. ~JaKe | |
![]() | | #211 | ![]() |
Groans: 501
Deatschwerks is actually going to be the company that comes out with aftermarket injectors for us. It's been a long time in the making, but at least they aren't taking anyone's money before they're finished. This was confirmed by deatchwerks at a trade show. A few members got to speak with them about the potentiality, and the answer was, "we're working on it."
| The Following User Says Thank You to Tokay444 For This Useful Post: | silvapain (06-05-2012) |
![]() | | #212 | ![]() |
He took my name number and email cause Dave stepped out for lunch today. But they are going to follow up with me very soon. I did inform them that time is of the essence with all that is being worked on if they wanted to maintain the market/be first.. it would need to be pushed to the front of the line. This looks promising though! Meantime SSinstaller - Please chime in on your experiences and tuning with these injectors Stay tuned for updates ! =) ~JaKe | |
![]() | | #213 | ![]() |
Groans: 501
It was common knowledge 6 months ago I thought...
| The Following 7 Users Say Thank You to Tokay444 For This Useful Post: | doubleflusher (06-05-2012), Easter Bunny (06-05-2012), Monotonous ONE (06-05-2012), PapaSmurf (06-05-2012), silvapain (06-05-2012), TWOptSL0W (06-05-2012), WhoIsJeremy (06-05-2012) |
![]() | | #214 | ![]() |
| Not Ranked : 0 score |
| The Following User Says Thank You to WWPearlMS6 For This Useful Post: | Tokay444 (06-05-2012) |
![]() | | #215 | ![]() |
Groans: 501
If you wanna tease me, just tickle my arsehole with a feather. Eye contact is also important.
| The Following 5 Users Say Thank You to Tokay444 For This Useful Post: | ak_spray (06-05-2012), Easter Bunny (06-05-2012), Roddiy (06-05-2012), silvapain (06-05-2012), SKiZ0TT (06-06-2012) |
![]() | | #216 | ![]() |
![]() | | #217 | ![]() |
| NATOR Photog ![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 1831 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,645
Groaned at 61 Times in 26 Posts
So I just stumbled on this this thread that's been deemed "the best" thread... what'd I miss?
__________________ ![]() Anthony D. Christiano 2008 CosmicBlue Mazdaspeed3 - 294whp/335wtq on stock K04, new BNR Stage 3 numbers coming soon... BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, 3-bar map and connector, PTP injector seals and studs, Kritz 3-port boost solenoid, Sure Return, CP-E FMIC, TWM STS, AutoTech Fuel Pump Internals, James Barone 88-Duro RMM, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 ET48, Cobb Rear Sway Bar, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back. BF Goodrich g-Force Sport 235/40/18's, MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
![]() | | #218 | ![]() |
Groans: 103
Not much. ~JaKe
| The Following 8 Users Say Thank You to Enki For This Useful Post: | ak_spray (06-05-2012), chuckms6 (06-05-2012), doubleflusher (06-05-2012), duappleganger (06-05-2012), Tokay444 (06-05-2012), TWOptSL0W (06-05-2012), WhoIsJeremy (06-05-2012), WWPearlMS6 (06-05-2012) |
![]() | | #219 | ![]() |
![]() Join Date: Mar 2008 Location: Jacksonville, NC
Rep Power: 2288 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 797
Groans: 46
Groaned at 16 Times in 11 Posts
There was no specific tuning necessary for me to run the ported injectors. Either the porting wasn't very effective, or the ecm can effectively trim for the relatively small amount of extra fuel the porting actually provides.. IMO, the injectors I'm running are not worth what I paid for them.. I'm still stuck at the same 450whp that everyone else is seeing. I was able to get there without meth, but my entire fuel system is far from stock. So I really have no idea how much effect the injectors had on their own.. Unless we get some upgraded injectors that flow 100% more fuel than stock(and will still idle), the fifth port setup is going to be the most effective means of getting extra fuel.. As soon as funds allow(and I get my car back on the road), I'll be adding the fifth port setup...
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
![]() | | #220 | ![]() |
Rep Power: 7667 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,965
Groans: 34
and JM Fab is "working" on producing Scotts' IM....long story short just spend the $700 or whatever DJs 5/6th port setup costs and call it a day...extremely flexible and tunable solution and probably better/cheaper than new DI injectors if you take the time to think about it. Almost constant washing of fuel over the valves depending on where you scale your MAF and start the 5th port injection. I haven't followed where those guys are starting the injection process but time will tell. You can take it a step further and spray 100% E on your 5th port as well with aux fuel cell and pumps, etc. Lots of options. anyway just my humble opinion ![]() BTW I have a feather if you need it.
__________________ ![]() ![]() PERM ![]() 07 Red MS3 GT - E40 - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - SS Exmani - Cobb DP - CNT CBE - AP w PERMTune - Grim EBC - Dano OCC - CPE CDFP - Labonte S2 WMI/w failsafe - ACT Street Kit - SUv2 RMM -"Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-05 | |
![]() | | #221 | ![]() |
![]() Join Date: Mar 2011 Location: North Jersey
Rep Power: 204 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 150
Groaned at 54 Times in 17 Posts
| Not Ranked : 0 score ... your avatar leads me to believe otherwise
__________________ 2011 Black Mica MS3 FREEKTUNE IN PROGRESS, ATP GTX3071R IWG Full Race exhaust manifold CP-e whale peen + 3.25 in. intake COBB EBCS + Downpipe + BPV + AP Stage 2 Corksport SRI + TIP + CBE Ultimate FMIC NGK Iridium IX @ .28 DDM HID 6000k Autotech CDFP Internals JBarone EGR delete, TB + IM gaskets, SSP + Shift Anchors, 88D RMM, 70D passenger + tranny mount, RSB, and OCC HTP battery box TSW Nurburgrings 18x8.5 MBR w/ Michelin Pilot Super Sports 235x40x18 +45 Installation TBD: , H&R springs + Koni yellow shocks + struts |
| The Following User Says Thank You to duappleganger For This Useful Post: | ak_spray (06-05-2012) |
![]() | | #222 | ![]() |
I see, well I suppose if I was as ugly as you I would use the Flash as my Avatar as well =] ~JaKe | ||
![]() | | #223 | ![]() |
Groans: 103
It's not the flash, its Ahnold. Also you realize the stupidity of signing all your posts on an internet forum, right? ~JaKe
| The Following 4 Users Say Thank You to Enki For This Useful Post: |
![]() | | #224 | ![]() |
![]() Join Date: May 2010 Location: Albuquerque, NM
Rep Power: 4591 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,362
Groans: 89
Groaned at 56 Times in 30 Posts
How can upgraded injectors be the best option when they havent even been proven on our platform?!?! Untill we have upgraded injectors on the market that are making power... Dustins 5th port > all
__________________ Twinscroll GT3582R 3M Matte Blue Metallic Wrapped PERM Tuned/Built Genpu Dragon 565whp/543wtq corrected at 5500ft asl 476whp/458wtq uncorrected at 5500ft asl |
| The Following 6 Users Say Thank You to PapaSmurf For This Useful Post: | Boosten Ya(josh) (06-05-2012), charlesfist (06-07-2012), Dano (06-05-2012), jracer (06-06-2012), silvapain (06-05-2012), TWOptSL0W (06-06-2012) |
![]() | | #225 | ![]() |
Groans: 34
Fully operational larger DI injectors are years away and here's why. the 1st problem you're probably gonna have is idle quality. now maybe not and with some of the flexibility of altering CDFP pressure perhaps this can be overcome... perhaps not. at the upper end, can the rail and associated items support the higher volume needed with the larger injectors. David @ cobb says there are numerous fuel pressure related tables that would need to be exposed and tweaked to upgrade the FP sensor to say a skyactiv, scale it and control fuel delivery. This is before we even start trying to control the actual injection event. The new injector latency scalar needs more work as do the fuel scalars/gravity setting for E85. There are probably other things I can't think of off hand like can the ITFP and line to the CDFP support bigger DI injectors. so to "hold out" for DI injectors AND getting them to work is going to be a very long wait IMO DI/PI hybrid is our best short to medium term option. Thats not to say to give up the goal but keep the reality in perspective
| The Following 9 Users Say Thank You to Dano For This Useful Post: | Boosten Ya(josh) (06-05-2012), charlesfist (06-07-2012), duappleganger (06-05-2012), jracer (06-06-2012), PapaSmurf (06-05-2012), pzr2874 (06-06-2012), TiGraySpeed6 (06-05-2012), TWOptSL0W (06-06-2012), WWPearlMS6 (06-05-2012) |
![]() | | #226 | ![]() |
~JaKe ![]()
HP To HP - Direct Injection will always make more power than Port injection because it is simply more efficient, provides better fuel economy, and More Horsepower. What more would you like sir? So our injectors, but even better....yes, is undoubtedly the best option.
I can almost positively assure you that if their were injectors to do just this, COBB would almost definitely have a tuning solution. I mean, what do you expect for them to develop the software support for something before the hardware is available for it? Not gonna happen. When the hardware is here, the software will be relatively cake for them. The reality of it also is the more people that seek other alternatives for fuel may minimize our chances for injectors. If everyone upgrades to a different form of fueling that is less people interested or in need of injectors, which makes our "small" market/community even smaller, and our purchasing power minute. And don't get me wrong 5th & 6th port is awesome, and if absolutely must be that is the road I will travel. DJ is putting a lot of hard work into it and it looks very promising. I'll again re-affirm that we are greatful and it will be sick. However, I would like to maintain Direct Injection for the obvious reasons stated above. ~JaKe Last edited by WWPearlMS6; 06-05-2012 at 06:36 PM. | |||
![]() | | #227 | ![]() |
![]() Join Date: Apr 2012 Location: Austin, Texas
The last pic in the injector line up is by far how I want my to look.
__________________ Chad Erwin -ATX 06 MazdaSpeed6 Gt AWD/Turbo/#5994 MODS: COBB AP // MSD Dashhawk // Street Unit TMIC // Street Unit Test Pipe // COBB SRI intake // Speedies TIP // Turbosmart BOV // RPM Street Spring // Bilstein Struts/Shocks // TWM Stage 2 Short Shifter // CPE Dogbone rear mount // CPE Dogdone Diff mount // COBB Shifter weight // HPFP Internals // Magnaflow 3IN Cat Back// Denso ITV 22s // Shorty Antenna // PA Engineering OCC // LED swap |
![]() | | #228 | ![]() |
| Not Ranked : 0 score I'm more of an ass man myself, but those are okay. Much preferred in person (Not actually a fan of strip joints either) But thats another day and another conversation ! Injectors we are talkin here Chester the Cheeto ! ~JaKe |
![]() | | #229 | ![]() |
~JoSh
__________________ 2011 Black Mica MS3 FREEKTUNE IN PROGRESS, ATP GTX3071R IWG Full Race exhaust manifold CP-e whale peen + 3.25 in. intake COBB EBCS + Downpipe + BPV + AP Stage 2 Corksport SRI + TIP + CBE Ultimate FMIC NGK Iridium IX @ .28 DDM HID 6000k Autotech CDFP Internals JBarone EGR delete, TB + IM gaskets, SSP + Shift Anchors, 88D RMM, 70D passenger + tranny mount, RSB, and OCC HTP battery box TSW Nurburgrings 18x8.5 MBR w/ Michelin Pilot Super Sports 235x40x18 +45 Installation TBD: , H&R springs + Koni yellow shocks + struts | |
![]() | | #230 | ![]() |
I appreciate your concern, and I'll place it in my own very personal suggestion box. ~JaKe - Your gettin the hang of it Toshooooooooooooo (Love that show) =) | |
![]() | | #231 | ![]() |
Groans: 103
| Not Ranked : 0 score You've just confirmed for everyone who ever reads this thread on how much of a pole smoker you really are.
![]() | | #232 | ![]() |
Email: Goaway89@gmail.com If I don't respond just wait for it, I'm usually slow at reviewing my emails but I'll get back to you eventually. To the rest of my party people in here, INJECTORS is what we're talkin ! =) ~JaKe | |
![]() | | #233 | ![]() |
Rep Power: 4090 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26,497
Have fun waiting. For injectors, for bigger HPFP, for controls in ATR. In the meantime the rest of us will be making power. Do you really think that nobody has tried before? That we are all incompetent? Nothing is ever black and white, there are always tradeoffs. Have you ever looked at the injection window at your 8000rpm? Your valves? Thought about wash down on cylinder walls? Reduced atomization because of higher flow? These are all reasons PI is better than DI ~ChRis
| The Following 5 Users Say Thank You to Ziggo For This Useful Post: | Boosten Ya(josh) (06-06-2012), Don06speed6 (06-06-2012), Enki (06-06-2012), jracer (06-06-2012), SKiZ0TT (06-06-2012) |
![]() | | #234 | ![]() |
| lowspeed ![]() Join Date: Jun 2009 Location: Tally, FL
Rep Power: 1752 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,687
Appreciate your enthusiasm here ~JaKe, but I'm inclined to agree with what Ziggo says. Respectfully suggest cease typing about it and go forth & do stuff instead. It really has become beating a dead horse since it's all just typing the same thing over & over with no new forward movement. Create, or hush up on the this topic. Not wanting to sound like an ass, but feel honestly compelled to draw comparison to the WRX owners in another post- there are builders and owners. The builders, the creators, those who lay the paths the rest of us follow have been here, done this, talked to the manufacturers already. What can be done, what progress there is to be made is being done, being made. You asking the same question over & over is not contributing to the subject. And no, I'm not contributing either, I just don't want to unsubscribe from this thread for the future good stuff, but the static is getting thick.
__________________ Mazdaspeed6 GT #3476 TiGray slicktop Cobb AP, SRI & TIP, BNR S3, MAC 3 Port, FMIC, TS BPV, 3 BAR MAP, VTCS Delete M2 DP & Magnaflow, KMD Internals, GPWerks BSD & Baffle, SM OCC, EGR Delete, TB Coolant Bypass, SU Billet RMM TWM Stage II STS & JBR SSB, Prosport Mech Boost RX-8 wheels & 235/40 RE760, H&R Sport Springs, SPC abj's, Strapped diff Stage 1 Brakes: Slotted, Hawk’d, Lined & Blued 405/394 AWD - cf1.01 e38 BNRs3 315/372 AWD - cf1.01 e38 k04 |
![]() | | #235 | ![]() |
I never suggested incompetence was the reason it isn't here, it is only a matter of time. As I said if need be I will do the 5th & 6th port. Just want to be sure that after 6+ years it is still all we have. The majority of the work in trying to get these developed was 4-5 years ago. Alot has changed since than, an addition of a MS3, a Genpu, CX-7 and a whole bunch of time to get the cars used and more prevalent. Its clear that the technology is here to stay so want to see what we got for options and if they have been followed up to see if there positioning has changed.
So I followed up with: deatschwerks - Waiting on a call back Who else had we contacted/can I contact to follow up? ~JaKe | ||
![]() | | #236 | ![]() |
Groans: 85
~jake Pretty low blow about Ziggo post. " Yeah, you'll be taking off straight to the moon with your BNR & F___WD." Ziggo has been on this forum for awhile and has contributed lots... He told you the hard facts .. and you cant handle it.. Quit arguing with the facts..geez........ I talked to every manufacture at the PRI show earlier in the year .. they all gave the same lip service.." yeah we are looking into it.....blah,blah,blah... who knows if mazda will even make another speed3 next year with our DISI engine.. why would they develop a injector for a engine thats on the way out ?? if mazda makes another speed.. it will most likely be a sky active wouldnt you think.? witch uses different injectors
| The Following 5 Users Say Thank You to jracer For This Useful Post: | Don06speed6 (06-06-2012), Enki (06-06-2012), SKiZ0TT (06-06-2012), TiGraySpeed6 (06-06-2012), TWOptSL0W (06-06-2012) |
![]() | | #237 | ![]() |
Note that the CX7 has been discontinued. The Speed3 is the only production vehicle using this engine. Tho it's on a Gen2, with Mazda's move to Skyactiv platforms one could easily wonder where the future of the Speed3 lies. It's a diminishing market, one that was never really that big to begin with, and where only a tiny fraction of the owner base would be interested in such a product. Regardless of how much that small percentage may want it. Jake, when the guy at DW told you "Dave's not here", I chuckled, thinking he was pulling your leg with the old movie line...
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | jracer (06-06-2012) |
![]() | | #238 | ![]() |
If you talked to every manufacture at the PRI show, Please give me the names so I could compile the list here to check off when they were last contacted and date it. I don't suppose Mazda would ever make an injector capable of what we will be looking for anyway. I was more looking into aftermarket companies.
Haha, could be. I'll follow up next week and try and get them on the phone to provide more info cause the guy did not know all that much regarding our area/product. ~JaKe | ||
![]() | | #239 | ![]() |
| Will fuck up ur day ![]() Join Date: Feb 2010 Location: Parrish, FL
Rep Power: 3381 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,744
Groans: 409
Groaned at 205 Times in 121 Posts
__________________ 07 MS3 bone stock? The original Genpoo Hater GTX3076r FenderRollerRental Rent a fender roller, or MZR DISI Timing tools! Turismo Vids - Store your car vids and pics here! Blog your builds too!
| The Following User Says Thank You to chimmike For This Useful Post: | jracer (06-06-2012) |
![]() | | #240 | ![]() |
I got no problem with you trying, but don't criticize what we have going on unless you have something *right now* that is better. What are the parameters for how long we have to wait till we get to say "I told you so?" if 6 months go by and there still isn't a DI solution (including pump and everything else) that is as at least 50% more flow over stock and under say $1500? 1 year? 2 Years? Zigatapatalka
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk | |
| The Following 4 Users Say Thank You to Ziggo For This Useful Post: |
