 Old 09-21-2012, 12:36 PM   #1
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
Default best way to drain the fuel tank
ive got a half tank in the car and want to get to 1/8th before going to the track.
is there an easy way to drain it?
or run it out, go next week.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 09-21-2012, 12:39 PM   #2
Posts: 7,290   (View Stats)
Lots of WOT, or a siphon.
Bass Pro Shops® E-Z Siphon | Bass Pro Shops
Nator is what it does.
 Old 09-21-2012, 12:40 PM   #3
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
Unhook the low pressure side of the hpfp and turn the key to on. That will run the pump, but you better have something to catch all the fuel that is about to shoot out
The Following User Says Thank You to TWOptSL0W For This Useful Post:
phate (09-21-2012)
 Old 09-21-2012, 12:45 PM   #4
XLT_66's Avatar
Posts: 850   (View Stats)
Disconnect your battery, pull the fuse. Jumper the circuit. Pull the low pressure fuel supply hose from the CDFP and feed it into a bigger/longer hose that drains into a bucket or fuel tank.
Use your negative battery cable as an on/off switch.
This only primes the HPFP. It's like a 3 second priming cycle. Lots of key cycles before that tank will empty...
2009 CWP MS3 Sport
SOLD!
2008 Toyota Tacoma TRD Sport 4x4
Last edited by XLT_66; 09-21-2012 at 12:45 PM. Reason: MSF Database - Automerged Doublepost
XLT_66 is offline   Reply With Quote
The Following 2 Users Say Thank You to XLT_66 For This Useful Post:
kritz (09-21-2012), mxlplx71 (09-21-2012)
 Old 09-21-2012, 12:46 PM   #5
I still think lots of WOT is more fun.
The Following 6 Users Say Thank You to kritz For This Useful Post:
Dash08 (09-21-2012), edrazor (09-21-2012), fivefingerdeathpunch (09-21-2012), mxlplx71 (09-21-2012), silvapain (09-21-2012), TWOptSL0W (09-21-2012)
IN-TANK FUEL PUMP Adrenaline Mazdaspeed3/6 General Discussion 6 04-12-2013 10:22 AM
In tank fuel pump and fuel rail valve Seatime3 2010 MS3 - Fuel, Nitrous & Water Injection 1 04-30-2012 08:44 PM
In-Tank Fuel Pressure Tester superskaterxes MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 17 11-02-2011 01:34 PM
VW awards U.S. fuel tank contract to TI Automotive Haltech Automotive News 0 04-08-2009 12:30 PM
HUMMER recalls '09 H3T for fuel tank that could fall off Haltech Automotive News 0 03-14-2009 09:20 AM
Page generated in 0.26710 seconds with 23 queries
