 Old 03-10-2010, 01:53 AM   #201
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
you lucky bastard....2000 miles and im droping pressure
2015 Mazda 6
 Old 03-10-2010, 02:00 AM   #202
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
The Following User Says Thank You to rodrigo For This Useful Post:
IshiKage (03-10-2010)
 Old 03-10-2010, 02:04 AM   #203
erod550's Avatar
Posts: 467   (View Stats)
erod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the world
I got impatient when I installed my PTP pump. Only idled it for about 12 minutes instead of 20. Then drove the 56 miles to work varying the RPMs but babying it. As I was leaving work I drove the few miles to the interstate in 2nd and 3rd gear at 5-6k rpms (low load, low boost), saw 2000psi holding fine, so when getting on the interstate I said fuck it and romped on it. 1700-1800 psi with no cuts. Been fueling like a champ with another couple hundred miles and a good 20 WOT pulls ever since. Never saw a single seize or cut since I put it on.
2011 Mustang GT Premium 5.0
2009 True Red Mazdaspeed3 - Sold
Cobb SRI | Cobb TIP | Cobb AP | CP-E DP | SU TMIC | Denso ITV22 | PTP HPFP | Synapse Synchronic BPV | Saikou Michi OCC | SU 90A RMM | SU Side Mounts | TWM Stage 2 STS w/Bushings | Dashhawk
erod550 is offline   Reply With Quote
 Old 03-10-2010, 02:08 AM   #204
IshiKage's Avatar
Groans: 278
lenny, is it possible to install the cam up-side-down in the pump cyl and the pump not seize but drop pressure as a result?
i hope i havent been full of failure, was careless(when i took my time) and put the cam in the wrong way and thats causing the prob
you are in the bastard club too haha. fml
2015 Mazda 6
Last edited by IshiKage; 03-10-2010 at 02:09 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to IshiKage For This Useful Post:
erod550 (03-10-2010)
 Old 03-10-2010, 09:06 AM   #205
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
well, i never tried to install the follower upside down.....
im about to jump off a cliff though
 Old 03-28-2010, 05:04 PM   #206
evidence's Avatar
Posts: 1,033   (View Stats)
evidence is the leader of the worldevidence is the leader of the worldevidence is the leader of the worldevidence is the leader of the worldevidence is the leader of the worldevidence is the leader of the worldevidence is the leader of the worldevidence is the leader of the worldevidence is the leader of the worldevidence is the leader of the worldevidence is the leader of the world
Mine is now idling between 330-340, and I'm getting cut at medium throttle when fuel psi would drop heavily. It doesn't sieze, but at low RPMs it just can't supply the fuel. I'm guessing it's getting pretty scored and just can't flow as it should.
Been talking with John for a few months and have always had a bit lower pressure (~380) than I felt was normal, though everyone kept telling me it was fine and not to worry. About 2 weeks ago it finally got to be too much though, 340 idle just isn't acceptable and then it started cutting. Apparently more stock arrives Monday, I'll be getting a new one..
Some things.
evidence is offline   Reply With Quote
The Following User Says Thank You to evidence For This Useful Post:
DaleNixon (03-28-2010)
 Old 03-28-2010, 06:30 PM   #207
DaleNixon's Avatar
Posts: 2,079   (View Stats)
Groans: 91
That sucks, evidence. Mine idles around 380 after I've been driving around a bit.
Possible new CDFP 06Speed6 2010 MS3 - Fuel, Nitrous & Water Injection 6 11-19-2009 03:41 PM
AP and cdfp tsb? booya620
Cobb Access Port/Maps
6 11-04-2008 02:55 PM
GM may not break up with Big Oil on TV after all Haltech Automotive News 0 06-18-2008 06:40 AM
Page generated in 0.27513 seconds with 25 queries
