 Old 01-12-2015, 01:11 PM   #1
-Six-'s Avatar
Posts: 14   (View Stats)
-Six- has a little shameless behaviour in the past
Default CDFP issues
Just yesterday experienced a sudden loss of fuel pressure that has persisted since, running at 60-75psi under all conditions; idle/throttle. Key on, pressure does rise to at least 400psi, but did not wait longer than that. I assumed possible stuck spill valve and proceeded to disassemble, clean, and reassemble/install. Unfortunately no improvement/change seen. Vehicle regularly runs straight 93 octane, but has seen 2 gallons of E85 at fill up on two occasions (one recently, but can not recall if that is what is in current tank). The spill valve did not appear to be terribly dirty, maybe a light yellow film at most.
My next suspicion is the solenoid has failed perhaps, or the internals failed (they were upgraded, but shall remain nameless so as not to wrongly tarnish a company for something as of yet unknown. Just looking to see if anyone had any firsthand experience with this, and also wanted to see if there is a source for purchasing the spill valve only, as it looks as though Mazda sells whole cdfp assembly only?
Edit: 2006 Mazdaspeed6 if anyone was questioning.
Thanks guys.
-Six- is offline   Reply With Quote
 Old 01-20-2015, 09:11 PM   #2
-Six-'s Avatar
Update, if anyone cared. I replaced the hpfp/cdfp with OE pump after swapping over the CorkSport internals that were in the original pump. Once installed, everything is once again working well.
The pump that was on there, was original and had about 96k miles on it. Might be food for thought for anyone considering upgrades to high mileage pumps, may want to consider replacing entire pump. (Unfortunately, as of now, no one I could find sells a replacement spill valve solenoid.)
Ford issues six recalls covering 101,000 vehicles for multiple issues Haltech Automotive News 0 07-08-2014 01:50 PM
do i need a CDFP? rangers4094 MazdaSpeed 3 - Engine, Transmission & Driveline 7 09-13-2011 04:51 PM
AP and cdfp tsb? booya620
Cobb Access Port/Maps
6 11-04-2008 02:55 PM
Page generated in 0.24046 seconds with 20 queries
