Like Tree7Likes
 Old 11-25-2011, 06:06 PM   #161
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
I get those two codes all the time, for me at least the too lean at idle is because I have the VTCS deleted and I hadn't tuned for it yet.
the fuel pressure sensor high out put only came on because I was ..... too lean at idle.....
I assume..
for the most part the fuel pressure high out put came about after my POS cp-e CAI sucked up water and I stalled out.
 Old 11-25-2011, 08:56 PM   #162
jroc's Avatar
Posts: 1,482   (View Stats)
jroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the world
Groaned at 6 Times in 6 Posts
yea i removed my vtcs as well, so that may have something to do with it. either way, id rather replace the sensor just in case. sucks that my dashhawk died so i couldnt see anything.
also bought a new AP for 524.99 shipped on ebay today. Guess the seller was having a black friday sale haha
i definitely didnt suck up any water lol
JDMFresh.com 1990 Mazda Miata
NASA Time Trials/Time Attack, Global Time Attack
A miata may be gay, but its probably faster than your car around a track. That's pretty gay.
jroc is offline   Reply With Quote
 Old 11-25-2011, 10:03 PM   #163
Posts: 9,484   (View Stats)
goddamit @jroc!
my shit started cutting out again today while tuning...only did it 3x out of like 10-15 runs and then didn't again...
where can I find you? lol
guess I need to buy a new sensor cuz I can't believe it is the actual connection this many times. Must be the end of the sensor is getting jogged around when I unplug/plug the harness back in.
FML
 Old 11-26-2011, 02:09 AM   #164
jroc's Avatar
haha sorry man. at least your car runs. mine is still down due to similar/same issues.
if it makes you feel better, my car has been down since may due to a rebuild and now i gotta deal with this shit.
pulled, rebuilt, installed by myself. (enki helped with the tranny install and torquing of some bolts)
 Old 11-02-2015, 09:48 PM   #165
grisco's Avatar
Posts: 6   (View Stats)
grisco is an unknown quantity at this point
Sorry to revive an old thread, but I've been searching for the correct one to post this in. I bought my 2011 MS3 with a CP-E HPFP already installed on it and the car has just under 50K miles on it, and I'm experiencing a plummet in HPFP pressures, thus the car bucks hard as hell. Only does it for the first 3-4 mild boost pulls. I'm running 50/50 E85. Any help would be appreciated.
grisco is offline   Reply With Quote
 Old 11-02-2015, 11:05 PM   #166
E85 is likely your trouble. 5050 is where this platform starts to have trouble. Search the E85 hpfp threads.
Tappin
littleloogy (11-02-2015), MD1032 (11-03-2015), MS3Shadow (11-03-2015), silvapain (11-03-2015)
 Old 11-03-2015, 01:59 AM   #167
blackms3_71's Avatar
Posts: 2,250   (View Stats)
blackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the world
Search. Stop using 50/50 and clean ur spilt valve
COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned
blackms3_71 is offline   Reply With Quote
 Old 11-03-2015, 09:02 AM   #168
to get the final answer go here.
http://www.mazdaspeedforums.org/foru...ml#post2844192
but you are either running one of the oils that doesn't play well with E or the CPE internals are the issue or both. Autotech internals appear to do the best (do to how they seal off the fuel from the oil) and use Royal Purple DEXOS (very important difference vs run of the mill RP).
I currently run a CPE pump with Pennzoil Plat + syn at E45 (5/7 mix) with no issues ( 1 year plus at this level). I recently bought RP Dexos and will soon move to 5050 after a 2nd oil change on RP.
clean your SV and maybe internals themselves in Si-1, or just petrol in a pinch, and reduce to a 5/7 mix and you should be ok. In lieu of that you can try to just switch back to full petrol for a tank full which might remove the black death/sticky death, as its called.
more E85 reading can be found here (not necessary to solve your issue but and interesting read).
E85 Remedy with HPFP Hardware modifications
grisco (11-10-2015)
 Old 11-03-2015, 04:41 PM   #169
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
IE internals.
100% e.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 11-03-2015, 05:04 PM   #170
grisco's Avatar
Thanks everyone for the replies. I've done a bunch of reading with no findings of a problem such as this.
 Old 11-03-2015, 05:18 PM   #171
littleloogy's Avatar
Posts: 4,005   (View Stats)
Your car feels like mild jerking, Correct? It has power but it just does not feel smooth through the RPM range?
 Old 11-03-2015, 05:33 PM   #172
grisco's Avatar
Default CDFP Pump Failures
No it bucks. Which is more like a stumble and a complete power loss for the split second it does it like the data logs display. But otherwise the car runs normally and it looks like my HPFP pressure are normal. I did the relief valve test to verify even though I didn't have any symptoms and it passed. I don't have any inverted torques so that's currently what's stopping me from removing the pump.
 Old 11-10-2015, 12:09 PM   #173
grisco's Avatar
Just an update, going to the parts store to get Si-1 to remove the spill valve and clean. The car had about 2 bars of 50/50 E in when I made my last post and It didn't stopped having problems. Nearly ran the tank empty and switched to my 93 tune and is still flawless. I'll probably go back to 50/50 after this tank. Currently running Castrol full synthetic 5W-40 OE Standard. (Volkswagen dealer oil). Ordered an Oil analysis kit from Blackstone to see how this oil comes out.
 Old 11-10-2015, 01:31 PM   #174
grisco's Avatar
From the ones I've seen on the forum I'd say this is pretty clean. Nothing felt sticky. Parts store didn't have Si-1 so I'll have to order that online.
Intersting information related to cdfp failures/ wear phailerider MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 74 01-15-2009 10:04 AM
CDFP internals or new pump Jarods7920 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 3 10-23-2008 04:33 PM
Page generated in 0.35176 seconds with 27 queries
