 Old 01-08-2010, 09:11 PM   #1
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Default CDFP return line
I bought a CDFP from a member here and its damaged, but it may still be usable. There are two return pipes, one is straight and the other is a 90* bend that I believe should come out parallel to the straight pipe. The problem is that the 90* bend pipe has been bent down towards the CDFP body and bent further than 90* such that flow is probably half of what it normally is. How much fuel actually flows through this particular pipe?
2006 Mazdaspeed 6
 Old 01-08-2010, 09:14 PM   #2
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
Did the member warn you of the damage?! I hope so!
 Old 01-08-2010, 09:33 PM   #3
11cruzito11's Avatar
Posts: 824   (View Stats)
11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world
Groaned at 5 Times in 2 Posts
that bent/kink doesn't look good. I bent the other line on my CDFP before and when I installed it and turned on the car the car would stumble and the pressure would be low and not constant.
did the member tell you the line was bent? I hope so too.
11cruzito11 is offline   Reply With Quote
 Old 01-08-2010, 09:39 PM   #4
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
call ptp they may be able to sell you just that part insteed of replacing the pump. i had two pumps and crushed that same line when the pump slip out of position on my vise and i hadnt noticed. So i swaped that part with my other pump and done. Good luck
 Old 01-08-2010, 09:45 PM   #5
Speeeeeed
06Speed6's Avatar
No they didnt mention it, if it was steel ide just bend it back but it looks to be aluminum which may crack.
2006 Mazdaspeed 6
 Old 01-08-2010, 10:02 PM   #6
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
shot in the dark here,
heat the aluminum at the kink, and bend the pipe till its straight
while the metal is malliable, insert a rod the approximate inner diameter of the tube, carefully working it to the necessary diameter
place a spring inside the pipe and bend back into the necessary position, this will prevent the tube from kinking again
I used this technique when i was in college, building a project, just gotta be careful with heating the metal and work slow, but i dont know if you have the necessary clearances.
if ptp sells replacement parts id just pick that up.
The Following User Says Thank You to 8.5MS3 For This Useful Post:
06Speed6 (01-08-2010)
 Old 01-08-2010, 10:18 PM   #7
flyrevs2's Avatar
Posts: 1,235   (View Stats)
flyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the world
bend back slow, if no crack, you good to go
2013 Mazdaspeed3 Gen2
Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount
flyrevs2 is offline   Reply With Quote
 Old 01-08-2010, 10:42 PM   #8
SneakyP86's Avatar
Posts: 1,162   (View Stats)
SneakyP86 is the leader of the worldSneakyP86 is the leader of the worldSneakyP86 is the leader of the worldSneakyP86 is the leader of the worldSneakyP86 is the leader of the worldSneakyP86 is the leader of the worldSneakyP86 is the leader of the worldSneakyP86 is the leader of the worldSneakyP86 is the leader of the worldSneakyP86 is the leader of the worldSneakyP86 is the leader of the world
Groaned at 19 Times in 13 Posts
With the pinch in the bend I would doubt that it will work right. If you try to bend it back you still may have problems with it either cracking or actually pinching tighter. If it was me I would PM the member and ask for your money back since they didn't let you know.
I BUSTED SOCKS CHERRY AND IT WAS GOOOOD
I'VE BEEN PLAYING DUMB FOR SO LONG ITS NOT A GAME ANYMORE
IF IT WAS WORTH THE TIME IT TOOK YOU TO GET EVEN THAN WHY DIDNT YOU TAKE A LITTLE MORE AND GET AHEAD?
SneakyP86 is offline   Reply With Quote
 Old 01-09-2010, 02:00 AM   #9
bykeryder4life's Avatar
Posts: 1,032   (View Stats)
bykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the world
Groans: 38
yeah wtf who sold that shit to you they need to be exposed, thats not some little shit to pass off right there. Fuck that asshole /rant
bykeryder4life is offline   Reply With Quote
The Following 2 Users Say Thank You to bykeryder4life For This Useful Post:
mtnrunner (01-09-2010), OMGWTFHAX (01-09-2010)
 Old 01-09-2010, 03:29 AM   #10
OMGWTFHAX's Avatar
Posts: 445   (View Stats)
OMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the world
Groaned at 26 Times in 25 Posts
Yeah seriously who sold you this shit? Im personally someone who cant stand being sold something that was described differently to me. See my avatar for example.
Flickr
Originally Posted by Andrew85 View Post
Wow kid... how about LOL @ you for being a piece of garbage without a purpose in life. For one thing, im not really bragging, just sharing an experience. Another thing is that you like men and your opinions dont count cause you take it up the poop shute.
OMGWTFHAX is offline   Reply With Quote
 Old 01-09-2010, 10:31 AM   #11
chrisyng's Avatar
Posts: 107   (View Stats)
chrisyng has a reputation beyond reputechrisyng has a reputation beyond reputechrisyng has a reputation beyond reputechrisyng has a reputation beyond reputechrisyng has a reputation beyond reputechrisyng has a reputation beyond reputechrisyng has a reputation beyond reputechrisyng has a reputation beyond reputechrisyng has a reputation beyond reputechrisyng has a reputation beyond reputechrisyng has a reputation beyond repute
Groaned at 7 Times in 6 Posts
I really do not think the guy who sold him the pump was aware of the damage to it...
here is the original f/s thread..
http://www.mazdaspeedforums.org/foru...el-pump-45123/
Notice the original pic of the pump in the f/s thread showed the bend.. the guy said he never got a chance to install it, so I doubt he had a chance to see what a non damaged pump looked like...
chrisyng is offline   Reply With Quote
 Old 01-09-2010, 12:49 PM   #12
Speeeeeed
06Speed6's Avatar
Yeah im not calling him out, im fairly sure he didnt know what it was supposed to look like.
2006 Mazdaspeed 6
 Old 01-09-2010, 06:02 PM   #13
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
Yeah looks like an honest mistake.
I would definitely call ptp.
Maybe he has an unusable core that he could scavenge that part from for you.
Suspension:
 Old 01-10-2010, 08:52 PM   #14
Speeeeeed
06Speed6's Avatar
Possible, im talkin with him right now, ill see what he wants to do.
2006 Mazdaspeed 6
 Old 01-10-2010, 09:15 PM   #15
JumpingJackson might have one, i think he's broke down and PTP gave him a pump.
 Old 01-14-2010, 12:13 PM   #16
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
JJ has like 2 ruined pumps, i bet with that part in good shape.
The bent tube is used for the relief, usually only when you take your foot off the gas during high pressure in the rail.
It probably doesn't NEED to flow too much. Especially since the ID of the kink is still bigger than valve.
In fact i'd be willing to bet that the ID of the kind is bigger than the feed hole into the rail from the hardline. IIRC the rail feed hole is only like 2mm or something.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
06Speed6 (01-14-2010)
Turbo Oil Return Line 11cruzito11 MazdaSpeed 3/6 - Turbo Induction 21 09-27-2009 09:15 PM
K04 oil feed line & oil drain line NJSPEED3 MazdaSpeed 3/6 - Turbo Induction 12 09-14-2009 10:46 AM
Best CDFP? Lex MazdaSpeed 3 - Engine, Transmission & Driveline 34 04-07-2009 07:30 PM
CP-e CDFP and Bored Fuel supply line installed thanotosq MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 30 12-27-2008 09:05 AM
Page generated in 0.36379 seconds with 32 queries
