 Old 04-28-2008, 02:28 PM   #1
Ghetto Mods's Avatar
Posts: 52   (View Stats)
Ghetto Mods is an unknown quantity at this point
Default CDFP Solenoids
Jon -
Saw a post by Tru-Boost on the other forum that you now have some sort of updated solenoid for the CDFP to improve response.
Did I get that right and is that something I can purchase separately? I have 311's old pump and I dunno if that one has the solenoid fix or not?
Or should I just drink another coffee before reading??
All your boost are belong to us.
Ghetto Mods is offline   Reply With Quote
 Old 04-29-2008, 05:23 AM   #2
Crossbow's Avatar
Posts: 709   (View Stats)
Crossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the world
I've been trying to get the part # for the new solenoids, but nobody seems to have them, or is willing to give them out.
I'd much rather just buy a new one from a vendor then go to a dealership and have to haggle to get one.
Crossbow is offline   Reply With Quote
 Old 04-29-2008, 05:33 AM   #3
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
unless something changed, Mazda does not sell the CDFP solenoid seperately from the pump assembly.
Maybe with this new TSB, they might start????
The Following User Says Thank You to whoosh@Realtune For This Useful Post:
Crossbow (04-29-2008)
 Old 04-29-2008, 11:57 AM   #4
mrlilguy157's Avatar
Posts: 606   (View Stats)
mrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the world
They do not just sell the solenoids. You'd have to go directly to Hitachi which I've already tried to do.
Regardless, with the upgraded pumps the solenoid issue, is actually no longer of an issue.
Black Mica '07 Mazdaspeed3
Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing
Reppin' ProtegeGarage for life!
mrlilguy157 is offline   Reply With Quote
 Old 04-29-2008, 12:46 PM   #5
AutoXRacer's Avatar
Posts: 1,590   (View Stats)
AutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond repute
Can you explain/expand why its not an issue?
2008 Stage 3 Roush Mustang
302E 5.0L Stroker 647rwhp-620 rwtq
AutoXRacer is offline   Reply With Quote
 Old 04-29-2008, 01:32 PM   #6
the larger diameter piston allows for more fuel to be pressurized per stroke. the fuel pressure with an upgraded pump is about 150-200psi higher once the pin (from the solenoid) hits the cap and spring which feeds more fuel into the compression chamber for the fuel pump.
i have about 30 fuel pumps in the field now and no one is complaining. Some have sent in their pumps directly, some have received old cores and new cores, no issues yet. Just several phone calls from consumers stating 'Wow, your fuel pump does everything you said it would! Thanks Jon!"
 Old 04-29-2008, 03:46 PM   #7
Averia's Avatar
Posts: 34   (View Stats)
Averia will become famous soon enough
So bottom line getting the TSB done if you are going to get Jon's rework isn't worth the time.
2007 MS6 - HKS Ignition, Cp-e Intake, Cp-e rear engine mount, TWM Short Shifter Stage 1 and Bushings, optimized throttle body.
Averia is offline   Reply With Quote
 Old 04-29-2008, 09:33 PM   #8
Performance Racing's Avatar
Posts: 193   (View Stats)
Performance Racing is just really nicePerformance Racing is just really nicePerformance Racing is just really nicePerformance Racing is just really nice
You don't want the TSB done if you bought Jon's pump!
Doesn't the dealer replace the entire pump (essentially with an updated solenoid)?
Performance Racing is offline   Reply With Quote
New CDFP TSB dadasracecar MazdaSpeed 3 - Engine, Transmission & Driveline 200 12-09-2008 02:09 AM
Cpe released their CDFP Laloosh MazdaSpeed 3/6 - ECU Computer Tuning 67 04-02-2008 02:02 PM
Page generated in 0.28469 seconds with 26 queries
