 Old 09-19-2017, 11:06 AM   #1
mikaeli's Avatar
Posts: 6   (View Stats)
mikaeli is an unknown quantity at this point
Default Car does'nt start - Low fuel pressure
Hi,
I kindly ask for your help with starting my car ( even if the help would be "go read the F** thread", I couldn't find any referring to my situation) What I could find, most issues ends with relief valve replacement, eventually fuel pump...
Long story short:
Car was in garage for 1,5y. I replaced lot of stuff, disassembled practically every part beside engine block itself (major overhaul was done less than 10k ago) and now I cannot start it.
Symptoms:
fuel pressure on access port is constantly 58-64PSI, even when cranking motor. Car for a moment hesistates if should start up or not, some smoke from exhaust appears and after 1 second gives up - still kranking but no combustion can be heard
What I ruled out so far:
battery - brand new
spark plugs - brand new, but even the old ones were working fine
coils - Tested and ok
starter - rebuilt
HPFP - replaced (with used one) The magic wire that needs to be grounded is grounded
Relief valve - replaced (with used one)
Throttle - cleaned, acting as required
Crank position sensor - Tested and ok
ECU restored to factory and then economy map uploaded so I can read values.
What I don't know how to check:
spill valve on HPFP. If it is disconnected, should pump provide high pressure or not? But anyway, I replaced whole unit..
So anyway, If could someone point me into some more tests I can do I'd really appreciate it.
Best regards
Michal
mikaeli is offline   Reply With Quote
 Old 09-19-2017, 08:18 PM   #2
MRR
MRR's Avatar
Posts: 95   (View Stats)
MRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to behold
The fuel pressure you are looking at with your access port is the pressure delivered by your intank fuel pump. Your HPFP will do alot more than that when working.
MRR is offline   Reply With Quote
 Old 09-23-2017, 01:05 AM   #3
mikaeli's Avatar
Yes I'm aware of that. The question is what is causing that since hpfp is a mechanical pump and internals are moving during crank. Is it spill valve? How can I diagnose hpfp?
Wysłane z mojego SM-G920F przy użyciu Tapatalka
 Old 09-23-2017, 06:58 AM   #4
danb's Avatar
Posts: 151   (View Stats)
danb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud of
what does fuel pressure read when you have the key on but have engine off? should rise till crack(?) pressure. over 1500
2007 speed3 GT. cobb rmm, JbR pmm, twm solid shifter bushings, AP3, Autotech, corksport turbo, HTP 3.5, Depo catless dp, Turbosmart Kompact bpv, Corksport 3port, cpe BlockD, Guardian Angel V3, DO DVC-30, SU TMIC Freektune 93 and e85 maps
2011 mazda 6 95k. wifes ride
danb is offline   Reply With Quote
 Old 09-23-2017, 11:40 AM   #5
mikaeli's Avatar
Thx for reply. It is always 58-62. The question is: is it sufficient pressure to start the car and I should look for cause somewhere else or that is exactly my problem..
Today i disassembled spill valve - it was dirty and stuck - wasn't able to push it with screwdriver. I connected it directly to battery and there was also no reaction. I cleaned it up and now i'm able to move it manually but still no work while connected to battery. since i have two pumps I did exactly the same to the other spill valve and it is acting the same. Do i test it right?
Other thing is i measured voltage on wire to spill valve and there is always 0V (also while KOEO or cranking) any suggestions?
 Old 09-13-2018, 09:19 PM   #6
Solarsurge's Avatar
Posts: 570   (View Stats)
Did you ever figure out what your issue was? I'm having a similar issue. Replaced damn near everything fuel related. Still no start.
 Old 09-13-2018, 09:55 PM   #7
Solarsurge's Avatar
Jesus Christ. My post attracted a spam bot.
 Old 09-14-2018, 12:09 AM   #8
MRR
MRR's Avatar
Have you checked the ground wire.
 Old 09-14-2018, 09:56 AM   #9
Solarsurge's Avatar
About 753 times. With a multimeter. And wires. And alligator clips.
Fuel pressure only 60 PSI, car won't start Bob-o MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 05-20-2014 07:54 PM
Please help, Low Fuel Pressure 2.3speed06 Mazdaspeed3/6 General Discussion 32 02-21-2014 08:24 AM
0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? AFcadet MazdaSpeed 3/6 - Troubleshoot/Diagnostics 24 08-03-2012 12:12 AM
More fuel pressure not enough? Enki MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 36 06-21-2011 10:55 AM
Fuel pressure dip myms3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 05-03-2008 12:37 PM
Page generated in 0.31768 seconds with 23 queries
