 Old 03-31-2016, 07:37 AM   #1
broda's Avatar
Posts: 375   (View Stats)
broda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the world
Default Compressed Natural Gas?
In my recent attempts of finding E85 near me, I found an Exxon within 8 miles of me supposedly that was listed on multiple E85 finder sites. To my discovery, instead they had CNG (Compressed Natural Gas) pumps instead so I was kind of pissed.
After a bit of looking into it, I discovered that CNG has an octane rating of 130. So even using 1 gallon of it with give me the equivalent octane boost as 3 gallons of E85. But I don't really know anything about the plausibility of actually using it so that's why I'm inquiring here. If I would be able to use it that would be great, if not I'm screwed because the only other (supposed) E85 pump is on the turnpike.
@Enki; @phate; , science me please.
broda is offline   Reply With Quote
The Following User Says Thank You to broda For This Useful Post:
Yatta (03-31-2016)
 Old 03-31-2016, 07:49 AM   #2
Yatta's Avatar
Posts: 1,862   (View Stats)
You can’t do this without a lot of additional gear... you would need a tank to store it ‘compressed’ high pressure lines to the manifold and valves (injectors) to meter it into your intake. If you are aware of all of the above... it might be usable, might even chill charge air....
I have seen vehicles converted to it and running in mixed (gas and CNG) modes but never for performance... it is an interesting idea; I think the diesel community uses propane for a similar effect.
 Old 03-31-2016, 08:01 AM   #3
broda's Avatar
That's what I figured. I was mostly curious if using it as a 1 gallon mix would keep it viable enough to just use in tank or not.
 Old 03-31-2016, 08:07 AM   #4
torquemaniac's Avatar
Posts: 733   (View Stats)
Interesting...CNG versus meth injection!
@dale_gribble; should have no problem testing this
2011 CX-7 AWD 2.3 turbo
Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner
The Following 2 Users Say Thank You to torquemaniac For This Useful Post:
dale_gribble (03-31-2016), Yatta (03-31-2016)
 Old 03-31-2016, 08:18 AM   #5
broda's Avatar
That's something that came to mind as well. I feel like you'd need a custom setup though so it doesn't degrade the pump and nozzle(s) though. The plus side though is that you'd have to mix less and it's cheaper. Could probably run it for a year for under $20 lol
 Old 03-31-2016, 08:23 AM   #6
Yatta's Avatar
If it was used just for ‘in-boost’ a meth controller might be leveraged... though it would have to be a good one for me to trust it, CNG is quite a bit more flammable than most meth solutions....
The Following User Says Thank You to Yatta For This Useful Post:
torquemaniac (03-31-2016)
 Old 03-31-2016, 09:51 AM   #7
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
I have nothing really to add to this, other than to say that the gear required will add significant amounts of weight to your vehicle. Might be better to stick with meth.
torquemaniac (03-31-2016), Yatta (03-31-2016)
PSA Peugeot Citroen, Bosch working on compressed-air, battery-free hybrid Haltech Automotive News 0 01-26-2013 03:30 PM
PSA and Bosch unveil hybrid that uses compressed air; GM likely to use it Haltech Automotive News 0 01-23-2013 09:10 AM
Report: Toyota Ku:Rin snags compressed air top speed record with 80.3 mph run Haltech Automotive News 0 09-23-2011 12:10 PM
The Myth of the Clean Compressed-Air Car Continues Haltech Automotive News 1 07-01-2010 12:30 PM
Could compressed air lead to markedly smaller engines? Haltech Automotive News 0 02-26-2009 07:20 AM
Page generated in 0.28514 seconds with 23 queries
