  • 1 Post By Fstrnyou
 Old 07-07-2017, 09:06 PM   #1
murphy13's Avatar
Posts: 2   (View Stats)
murphy13 is an unknown quantity at this point
Default corksport HPFP need info for reasurance
hey guys. I just installed my corksport HPFP yesterday and while monitoring under normal driving I noticed that my FP seems to jump around quite a bit when running in 4th gear around 2000 RPM and i was wondering if it was normal? I have researched and could not find anything about this. I have absolutely no problems when going WOT and as soon as i touch the gas a little bit it jumps right back up.
murphy13 is offline   Reply With Quote
 Old 01-02-2018, 05:29 PM   #2
jaller1999's Avatar
Posts: 6   (View Stats)
jaller1999 is on a distinguished road
Groaned at 7 Times in 2 Posts
I have had the corksport hpfp installed for about 6 months now and this is pretty normal. As soon as you push the throttle it readies the rail fuel pressure for WOT. Which for me always seems around 1600.
jaller1999 is offline   Reply With Quote
 Old 01-02-2018, 08:44 PM   #3
Fstrnyou's Avatar
Posts: 2,412   (View Stats)
xorphanx likes this.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 01-03-2018, 10:21 AM   #4
Thor Hammer's Avatar
Posts: 1,846   (View Stats)
Groans: 211
Your data log is fucking unreadable. Aside from that, well...what can I say?
 Old 01-03-2018, 12:05 PM   #5
Fstrnyou's Avatar
Oh Thor...you fell for it too.
Brownie revived an 6 month old post.
Other rides:
History:
Corksport HPFP or Autotech HPFP? El Beaner Gen2 MS3 General Discussion 76 05-25-2017 06:55 PM
CorkSport HPFP anymore info on this JDMCRX MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 5 07-16-2014 05:18 PM
INFO! hpfp internals fbgm0514 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 10 12-26-2010 12:25 AM
Corksport SRI info Post pwned 2010 MS3 - Turbo Induction 21 07-21-2010 05:08 PM
Corksport SRI info Renzokuken MazdaSpeed 3/6 - Turbo Induction 29 11-21-2008 05:13 PM
Page generated in 0.26411 seconds with 24 queries
