View Poll Results: Devils Own, Stage 1 or Stage2?
Stage 1 2 8.33%
Stage 2 (Progressive) 22 91.67%
Voters: 24. You may not vote on this poll
 Old 09-10-2009, 09:44 PM   #1
11cruzito11's Avatar
Posts: 824   (View Stats)
11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world
Groaned at 5 Times in 2 Posts
Default Devils Own Meth Injection
All-
I am ready to purchase the Meth Kit from Devils Own and wanted everyone's input on what Stage I should get.
Please share your feedback!
Stage 1 or Stage 2?
Cobb AP, 504whp 492wtq
11cruzito11 is offline   Reply With Quote
 Old 09-10-2009, 09:51 PM   #2
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Stage 2, you need the controller to dial in the mixture... Choose the D03 and D05 nozzles.
 Old 09-10-2009, 09:54 PM   #3
JoshC23's Avatar
Posts: 375   (View Stats)
JoshC23 is the leader of the worldJoshC23 is the leader of the worldJoshC23 is the leader of the worldJoshC23 is the leader of the worldJoshC23 is the leader of the worldJoshC23 is the leader of the worldJoshC23 is the leader of the worldJoshC23 is the leader of the worldJoshC23 is the leader of the worldJoshC23 is the leader of the worldJoshC23 is the leader of the world
Groaned at 8 Times in 4 Posts
Stage 2 for sure and I think your the guy who asked me if I was pulling the mustang on youtube. Yeah I was pulling him hard and if we didnt let off because of traffic i would of put a full car on him by 130. He traps 110-112
If you had a standback I would say get the stage 1 and the profuel from cpe but since I see you have the AP you will want the controller.
JoshC23 is offline   Reply With Quote
 Old 09-10-2009, 10:06 PM   #4
Thanks both JoshC23 and Haltech for your posts, I want to get some feedback from users before I purchase the kit.
 Old 09-10-2009, 10:47 PM   #5
ljudgeii's Avatar
Posts: 180   (View Stats)
ljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond repute
With AP, stage 2 progressive controller is a must.
07 Black Mica with Sunroof"
11/17/11 ZZ-SB (Spun #4 Rod Bearing @97,643 miles)
"I'm back Baby" says the almighty Bender
CURRENT MODS:
Cobb ATR self tune+JBR WP+FMIC+BNR S3+MI+IM+CP-e EXMAN:
VDyno 351hp and 331tq
BEST 1320:
COBB AP S2+MSCAI2+FMIC-v1.03i Best ET on 2Nov08 13.6@98mph (yeah I missed 5th gear)
ljudgeii is offline   Reply With Quote
 Old 09-10-2009, 11:04 PM   #6
So I can understand better, why is the Stage 2 a must with the AP?
I most likely will get Stage 2 but curious to know why is it needed?
 Old 09-10-2009, 11:59 PM   #7
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
You need it to control when you want the meth to begin flowing and at what rate do you want to be 100%.
With stage 1, its on or off, which will most likely, bog you down. Each car is different, each run diff nozzles and bolts ons, so it takes you about 20 mins of driving to fine tune it with the stage 2 controller. Also, on extremely hot days or humid days, you can increase it. On very cold days, you can turn it down.
Depending on the mods, 3 or 5 nozzle will lower your AFR by one full point. If you run 100% mixture, 1.3 pts.. 70/30, 1 full point.
 Old 09-11-2009, 01:43 AM   #8
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
cruzito, I haz stage 2 DO on my car..... I would rather lose my left testicle than go to a non progressive setup.
plus's
a) simpler install (believe it or not there are less mechanical parts)
b) less consumption of meth when not nbeeded (when u are part throttle, part boost u dont spray it all to shit
c) adjust it in cabin (provided the controller is near u)
d) you wont bog and easier to tune for......the 2 stages makes the added fuel a smoother transition
so.... get it. end of story.
I have done about 4-5 stage 2 kits and they are both easy and practical
The Following User Says Thank You to rodrigo For This Useful Post:
aaronc7 (10-17-2009)
 Old 09-11-2009, 09:37 AM   #9
Thanks Lenny127 and Haltech,
I will go with the Stage 2 set up.
Another thing what tank size is everyone running? Is the 2.5 gallon one too much or should I stick with the 4 quart tank?
 Old 09-11-2009, 09:44 AM   #10
ljudgeii's Avatar
I'm running a 1 gallon tank. As far as refilling the tank depends on your driving habits and where you have the controller settings at. I have gone through 3 - 5 full tanks of gas before refilling the meth tank, but then again I don't spend my commute WOT
CURRENT MODS:
BEST 1320:
 Old 09-11-2009, 09:51 AM   #11
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
The stage 2 kit is nice but its $100 extra bucks it just allows you to spray smaller percentages at lower boost. I got stage 1 and works for me comes on full blast and works great with high or medium boost. I have the boost switch set to 6psi and the car never bogs and boost temps dive below ambient. I say if your rolling in the dough get stage 2 or if on a budget get stage 1 and save $100...
 Old 09-11-2009, 10:13 AM   #12
ljudgeii's Avatar
Yeah but the OP is running the AP, and you have the Standback+Profuel controller correct.
CURRENT MODS:
BEST 1320:
 Old 09-11-2009, 10:36 AM   #13
gsrtype1's Avatar
Groans: 102
Nope I might get that eventually but i'm perfectly happy with boost switch. works fine...
 Old 09-11-2009, 11:10 AM   #14
Are you also running the 1 gallon tank?
 Old 09-11-2009, 11:19 AM   #15
gsrtype1's Avatar
Groans: 102
Na I just use the windshield washer resivour its easy you just drill the whole and screw in the nozzle like you would with a gallon tank.
 Old 09-11-2009, 12:13 PM   #16
I am thinking of starting with 50-50 mix, I heard of HEET Methanol and some type of distalled water for the mix.
Where is everyone buying both the Methanol and Water, and what price?
Thanks,
 Old 09-11-2009, 12:21 PM   #17
DevilsOwn's Avatar
Posts: 212   (View Stats)
DevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the world
if you look around should be able to get meth for 2.25- 2.50 a gallon
DevilsOwn is offline   Reply With Quote
 Old 09-11-2009, 12:32 PM   #18
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
pure meth or go home.
water is for the birds
itzjustme407 (05-29-2015)
 Old 09-11-2009, 12:50 PM   #19
gsrtype1's Avatar
Groans: 102
Thanks,
Defiantly cheaper to get it by the gallon but HEET is 99.9% methanol and .001% distilled water. (according to an email I got from HEET) and you can get it at walmart $1.27. So if you running low its an alternative.
 Old 09-11-2009, 01:22 PM   #20
gsrtype1,
Where do you purchase your meth?
 Old 09-11-2009, 01:33 PM   #21
gsrtype1's Avatar
Groans: 102
gsrtype1,
I mostly get the Devils own 50/50 mix ($8 a gallon here locally) and dilute it with HEET. I liked 100% meth but I noticed it "seems" could be in my head... That with 100%meth boost temps don't drop nearly as much and I get significantly more knock with 100%meth vs 80-90% meth. 50/50 defiantly sucks compared to 80% meth. So I like mine mix to have a little water in there...
 Old 09-11-2009, 02:20 PM   #22
If I go with 100% Meth, Where could I get the Meth?
 Old 09-11-2009, 02:32 PM   #23
Zoom-Zoom Boom
mleblond's Avatar
Posts: 210   (View Stats)
mleblond has a reputation beyond reputemleblond has a reputation beyond reputemleblond has a reputation beyond reputemleblond has a reputation beyond reputemleblond has a reputation beyond reputemleblond has a reputation beyond reputemleblond has a reputation beyond reputemleblond has a reputation beyond reputemleblond has a reputation beyond reputemleblond has a reputation beyond reputemleblond has a reputation beyond repute
I get VP meth from a local racing shop. They get it by the tub lol
I remember a thread on the different washer fluids that included meth that would work but who still does that?
2007 Black Mica Mazdaspeed 3 (SOLD)
Blew: May 24 2009
mleblond is offline   Reply With Quote
 Old 09-11-2009, 09:43 PM   #24
Where is everyone buying their Meth.....PLEASE POST!
 Old 10-17-2009, 02:29 PM   #25
For the 250psi pump users,
Are you running 250 psi, 200 psi or 150psi?
Thanks,
 Old 10-17-2009, 03:57 PM   #26
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
run 250psi...that said i have a 150psi pump and it works fine.
I buy methanol from a local "performance shop" They sell VP fuels and have the VP M1 Methanol. It's like $6 a gallon. I buy it at 5 gallon quantities at a time.. I have ran both 100 meth and 50/50. I don't notice a huge difference, but I don't have anything like an EGT gauge anymore to compare stuff like that. I run 50/50 right now because its cheaper (not that running pure is that bad), and it's what I have at the moment.
I would say DO3 nozzle and 50/50 is a good place to start. Keep in mind 50/50 is by weight, not volume. There's some calculators on here to figure out how much water and how much meth makes 50/50. I mix 4 gallons of water of 5 gallons of methanol for 9 gallons of a perfect 50/50 mix.
 Old 10-17-2009, 07:26 PM   #27
Aaron,
If I am doing 80% Meth and 20% Water, is the amount calculated by weight or by volume?
Say for example I have 4 gallons of Meth, how many gallons of water do I need for a perfect 80% to 20%?
Thanks,
 Old 10-17-2009, 07:38 PM   #28
gsrtype1's Avatar
Groans: 102
Aaron,
Thanks,
a simple calculator? lol use ounces
 Old 10-17-2009, 07:40 PM   #29
That's what I've been using, but I saw that Aaron said he mixed 5 gallons of Meth to 4 gallons of Water, and got a 50 - 50 Mix?
I thought it would be 4 gallons of Meth to 4 gallons of Water, a 50 -50 mix.
Meth injection troubles Meder MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 21 05-16-2009 07:41 PM
Devils Own Stage 2 Meth Installed aaronc7 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 59 03-10-2009 03:06 PM
Water-Meth injection EvilMonkey MazdaSpeed 3 - Engine, Transmission & Driveline 2 08-06-2008 10:41 AM
Page generated in 0.46137 seconds with 29 queries
