 Old 02-06-2009, 07:25 AM   #41
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
came with 15 ft of tubing... was just enough-- i have like 6 inches left.
$330 for kit and 35ish for tank? we also get a 5 percent mazda forum discount on top of that, but that pretty much just takes off the shipping cost
 Old 02-06-2009, 07:27 AM   #42
wisniaPl's Avatar
Posts: 933   (View Stats)
wisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond repute
wow good deal have to save up some moeny to instal this along w with dp....
wisniaPl is offline   Reply With Quote
 Old 02-10-2009, 09:11 PM   #43
AFcadet's Avatar
Posts: 937   (View Stats)
AFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the world
Hmm very interesting.
So what type of tune do you have? AP?
Im curious to see if this kit will work direclty with my AP map (stage 1 + SF 93 octane + FMIC v1.03).
Other then it enrichening the mixture...will there be any other "negatives"?
AFcadet is offline   Reply With Quote
 Old 02-10-2009, 09:21 PM   #44
aaronc7's Avatar
Groans: 370
it will richen it up slightly (gonna depend on your mixture and nozzle size), but depending on what map you're running and current AFRs it might not be a bad thing.
Really theres no negatives, just a little more hassle of filling the tank up and stuff...but seriously its not bad. meth is addicting...trust me!
Yeah I am running the AP. 50/50 meth on 5gph nozzle. runs fine, I just dynoed 320hp/345tq last weekend
 Old 02-11-2009, 07:04 AM   #45
AFcadet's Avatar
so just curious...how long does a 1 gallon tank last if you use your car as a DD?
I admit I zoom around town here and there...but its not like I'm constantly going WOT.
Are we talking like a couple days...a week...or a couple weeks?
 Old 02-11-2009, 12:40 PM   #46
aaronc7's Avatar
Groans: 370
I'll throw out a rough number of 1 gallon of meth every 450 miles
at least for me..and my driving style/nozzle size
 Old 02-15-2009, 03:55 PM   #47
wisniaPl's Avatar
one more thing does it make diff where in cold pipe you mount nozle?? i gues to close to the engine is no good right??
 Old 02-15-2009, 08:13 PM   #48
ljudgeii's Avatar
Posts: 180   (View Stats)
ljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond repute
I'll jump on the bandwagon, I went two fill ups and used a gallon, but when I did a canyon run I used about 2 gallons. Not sure about at the track hopefully if it doesn't rain I will find out next weekend.
running the same setup as Aaronc7, but using the 3gph nozzle.
ljudgeii is offline   Reply With Quote
 Old 02-15-2009, 08:19 PM   #49
aaronc7's Avatar
Groans: 370
anywhere is fine honestly, i would just not put it right next to the TB. you just wanna give it some space to mix in with the air
 Old 02-21-2009, 06:58 PM   #50
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
which nozzle are you using the do3 or do5?
 Old 02-21-2009, 07:10 PM   #51
aaronc7's Avatar
Groans: 370
d05
 Old 02-21-2009, 07:11 PM   #52
bova's Avatar
Groans: 45
how do you go about priming the line before using it? since this taps the map wire. what application do you think the do3 would be good for? i am buying a kit from someone but they only have a do3 and do7 nozzle.
 Old 02-23-2009, 04:27 PM   #53
wisniaPl's Avatar
just get do5 nozle its 20bucks...... btw how to get a discount??
 Old 02-23-2009, 04:31 PM   #54
aaronc7's Avatar
Groans: 370
in one of the first threads devils own made in their own section....in some long post there is the coupon code listed
 Old 02-23-2009, 04:59 PM   #55
wisniaPl's Avatar
ok thx
 Old 03-09-2009, 08:58 PM   #56
dubi0us's Avatar
Posts: 30   (View Stats)
dubi0us is a jewel in the roughdubi0us is a jewel in the roughdubi0us is a jewel in the rough
Sweet setup in the trunk, how fast are you burning through the mix though?
dubi0us is offline   Reply With Quote
The Following User Says Thank You to dubi0us For This Useful Post:
aaronc7 (03-09-2009)
 Old 03-09-2009, 09:03 PM   #57
aaronc7's Avatar
Groans: 370
d05 i would get 300-450 miles for the 1 gallon tank. Closer to 300 or 1 tank of gas if I was hard on it.
I'm running the smaller d03 nozzle and it seems to last a lot longer (probably about double...obviously)
It's really not a pain in the ass but something u should keep an eye on and check every now and then
 Old 03-10-2009, 10:26 AM   #58
DevilsOwn's Avatar
Posts: 212   (View Stats)
DevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the world
Even i don't know the coupon code. Dvldoc in in iraq and not easy for me to get ahold of him.
DevilsOwn is offline   Reply With Quote
 Old 03-10-2009, 10:39 AM   #59
aaronc7's Avatar
Groans: 370
"Your forum discount code is mzdaspd"
 Old 03-10-2009, 03:06 PM   #60
DevilsOwn's Avatar
Thanks
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f303/devils-own-stage-2-meth-installed-18351/
used kit, missing a fitting and concerned about ..... - Devilsown Methanol Alcohol Water Injection This thread Pingback 09-28-2009 03:25 AM
Saikou Stage 2 Oil Catch Can Installed! aaronc7 MazdaSpeed 3 - How-To's 59 10-07-2009 03:59 PM
meth kit installed 2 issues help please gsrtype1 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 24 11-19-2008 10:22 PM
Page generated in 0.37539 seconds with 26 queries
