 Old 10-26-2015, 10:14 PM   #1
Cdnspeed6's Avatar
Posts: 139   (View Stats)
Cdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond repute
Groaned at 4 Times in 2 Posts
Default Erratic Hpfp Psi during Pull
Ive been starting to tinker with my Cobb Pulling some logs for Maf Cali and Looked at my HPFP PSI and it varies wildly, My Afr's don't seem to be too effected by it.
Is this a Normal Looking output? or should i be hunting for something wrong. Log is attached
the car is a 07 Speed6 131,000 kms with a Corksport short ram and turbo inlet
Thanks guys
Cdnspeed6 is offline   Reply With Quote
 Old 10-26-2015, 10:26 PM   #2
phillyb hates me!'s Avatar
Posts: 27   (View Stats)
phillyb hates me! has a reputation beyond reputephillyb hates me! has a reputation beyond reputephillyb hates me! has a reputation beyond reputephillyb hates me! has a reputation beyond reputephillyb hates me! has a reputation beyond reputephillyb hates me! has a reputation beyond reputephillyb hates me! has a reputation beyond reputephillyb hates me! has a reputation beyond reputephillyb hates me! has a reputation beyond reputephillyb hates me! has a reputation beyond reputephillyb hates me! has a reputation beyond repute
you should look into what means what on a log.
phillyb hates me! is offline   Reply With Quote
 Old 10-26-2015, 10:35 PM   #3
Cdnspeed6's Avatar
I'm Looking at HPFP Act. Press
using the Virtual Dyno Datalogger
 Old 10-26-2015, 10:39 PM   #4
yeah, i know...
op needs to look into what MEANS what on a log.
in other words, op.
you need to learn the rest of the values on your log.
when your pedal is at 99%, what's your fuel pressure doing?
when your afr is over 14 (why 14? look it up), what's your fuel pressure doing?
what's your pedal doing?
Last edited by phillyb hates me!; 10-26-2015 at 10:39 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-26-2015, 10:48 PM   #5
Cdnspeed6's Avatar
I understand what does what I've tuned Haltechs megasquirts and Hondata I'm not familiar with Direct injection Fuel pressures and How they Should look.
Fuel pressure swinging like this does not look normal to me. This was During A Wot Pull in 3rd gear, I can Add in the other parts I was logging.
Last edited by Cdnspeed6; 10-26-2015 at 10:48 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-26-2015, 11:08 PM   #6
tegxsi's Avatar
Posts: 1,255   (View Stats)
Groans: 87
As long as it's over 1600psi at WOT you are fine. Fuel demands will increase when you start modding and cranking up the boost. That's when you need HPFP upgrade. The forum has plenty of information about almost anything already.
You need to figure out your knock issue.
2018 Audi RS3
2007 Acura TSX 6MT
Cdnspeed6 (10-27-2015)
 Old 10-27-2015, 12:42 AM   #7
Cdnspeed6's Avatar
Thanks Tegxsi, I'm going to get my Maf calibrated and go from there
 Old 10-27-2015, 04:23 AM   #8
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Knock is most likely from early spool, and because OP is still running stock map values, that's why it is so slow to decay. Other than that, log looks ok for a stock car, MAF values seem to be a little off while cruising/idle.
Also, you don't want to start a log at 2k rpm, especially when you don't know what you are doing. There is a ton of information on this board, about fuel pressures and all, I highly suggest you do some reading, and a majority of the questions you might have, will be answered.
The Following 3 Users Say Thank You to g00s3y For This Useful Post:
Cdnspeed6 (10-27-2015), Vansquish (10-27-2015), WetzMS3 (10-27-2015)
 Old 10-27-2015, 05:02 AM   #9
Cdnspeed6's Avatar
Thanks again, I started the log down low just to see where the tune was at the Maf values were out quite abit i've got it dialed in abit more now.
I have done quite abit of reading on the high pressure fuel system just to get more familiar with it I just found a 100psi swing Odd and figured i would ask.
it doesn't seem to afr too much and the ecu didnt try to adjust pulse width for it.
Erratic AFR's, running rich Tommy MazdaSpeed 3/6 - Troubleshoot/Diagnostics 41 10-09-2019 07:17 AM
Erratic Boost Gauge, install help? Spiral1183 Mazdaspeed3/6 General Discussion 2 10-18-2013 08:12 PM
HPFP issues on WOT pull - with swapped internals LilGator MazdaSpeed 3/6 - Troubleshoot/Diagnostics 91 01-13-2013 11:23 PM
CS intake, erratic boosting 2k4_8 2010 MS3 - Turbo Induction 7 06-16-2011 04:56 AM
Page generated in 0.29343 seconds with 24 queries
