Like Tree2Likes
  • 1 Post By speed3sailor
 Old 01-08-2014, 12:39 AM   #1
speed3sailor's Avatar
Posts: 835   (View Stats)
speed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the world
Default Ethanol injection
I am trying to get information on using Ethanol in my DevilsOwn alcohol injection system. I have done some research and haven't found very much about it on here. There is plenty of info on using in tank Ethanol but not in a alcohol injection kit. I would love to just add it to my tank but it will more than likely push my IDC above 100%. When spraying a D07 50/50 meth my IDC was in the low 90s. I'm not too worried about the Ethanol effecting the pump. Quote from Devils Own website "While this pump is chemically compatible for use with 100% methanol and/or ethanol, we do not recommend running flammable liquids."
The only reason im looking at Eth instead of Meth, is because I am stationed in Italy and I am having a hard time finding Meth. The best option that i had avaliable just went away. I was using a concentrated WWF that i purchased on base.
Its fairly easy for me to find Ethanol or Denatured alcohol out in town. its kind of expensive though. around 20 euro for 5L (27$ for 1.3Gallons). I can also get pure grain alcohol on base (96%) but i'm not sure about the price.
anyone have any experience with it?
kby likes this.
07 SILVER Speed3 , BNR S3- Tial 38mm EWG w/ stock mani- COBB AP- Ebay catless Downpipe- HTP 3in intake- Devils Own WMI (D10)- CX Racing FMIC- Autotech internals- Grimmspeed 3P EBCS- Denso ITV22- HKS super SQV- Bosch 3 bar - Damon PMM- JBR RMM- shift weight- EGR delete- TIGs- JBR RSB- Eibach springs- TR Motorsports 17x9- Hankook RS-3 255/40/17
speed3sailor is offline   Reply With Quote
 Old 01-08-2014, 06:32 AM   #2
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
from everything i've read, they're both fairly similar to run.
DO will cover their butts and say never run flammable liquids, so dilute the alcohol with water until it can no longer ignite easily.
however, many like myself run pure methanol straight through the system with little or no issues.
The main reason why people will run meth over eth is cost. Meth is generally cheaper (i can pick up a gallon for roughly 6 bucks). Also has a slight more cooling effect on the intake charge.
again, this is me recalling things from what I've read. Correct me if I'm wrong.
 Old 01-08-2014, 06:41 AM   #3
yea, I don't think that there would be any issues with running pure Eth. I probably would only run like 75% E though. Im really just looking to read peoples experiences with tuning for it and what kind of performance was yielded.
also, I looked at the price of pure grain alcohol today on base. 20$ for 2 Liters. F that.
 Old 01-08-2014, 06:58 AM   #4
pmartz16's Avatar
Posts: 1,140   (View Stats)
pmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the world
Groaned at 18 Times in 4 Posts
@Realgib3; uses a 6th port system with an independent tank to shoot pure ethanol through those two pre throttle body injectors.
Originally Posted by Realgib3 View Post
Definitely not harder to tune, in some ways slightly easier because your fuel flow through the secondaries is extremely consistent since it's an independent, regulated, return style system. For the most part though, it's the exact same tuning.
2008.5 Mazdaspeed 3 BM - Built BT Realgib3 Tuned
2014 Mz3 MG
pmartz16 is offline   Reply With Quote
The Following 2 Users Say Thank You to pmartz16 For This Useful Post:
ABolewski (01-08-2014), Realgib3 (01-08-2014)
 Old 01-08-2014, 07:55 AM   #5
Sounds expensive. A little out of my price range for now
The Following User Says Thank You to speed3sailor For This Useful Post:
pmartz16 (01-08-2014)
 Old 01-08-2014, 09:15 AM   #6
v8 convert
p057's Avatar
Groans: 220
every situation and car is different. However, expect just about the same results running ethanol vs methanol.
you can try bumping back your timing a couple degrees to be on the safe side.
The Following User Says Thank You to p057 For This Useful Post:
speed3sailor (01-08-2014)
 Old 01-08-2014, 09:17 AM   #7
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
Dizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the world
Where do you get pure ethanol?
Sent from my HTC One using Tapatalk
Dizzy Turbo is offline   Reply With Quote
 Old 01-08-2014, 09:27 AM   #8
I'll turn boost and timing down a little bit before I give it a whirl for sure. Have you tried Eth?
A store out in town called Leroy Merlin. It's used for fire places. Lol it's funny explaining to Italians that you are going to use fire place gas in your car
ABolewski likes this.
Last edited by speed3sailor; 01-08-2014 at 09:27 AM. Reason: MSF Database - Automerged Doublepost
 Old 01-08-2014, 09:28 AM   #9
Isn't there a type of windshield washer fluid you can use? And that's cool, I never knew anywherre you could buy bulk ethanol besides e85
 Old 01-08-2014, 09:31 AM   #10
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I'm pretty sure Mark is shooting e85. Not denatured alcohol.
I know @rfinkle2; has run ethanol through his meth kit.
Look for methyl hydrate. It's 100 meth.
"Exclusivity" - CP-enis
Demodded.
The Seals
Mauro_Penguin (01-08-2014), Realgib3 (01-08-2014), speed3sailor (01-08-2014)
 Old 01-08-2014, 09:39 AM   #11
I have found other WWF but none with high % of meth.
What kind of place would carry methyl hydrate? I haven't found any if it yet. I take a picture of everything that I found out in town that might have the slightest chance of containing meth. Once I get home I search for a msds. No luck yet
Last edited by speed3sailor; 01-08-2014 at 09:39 AM. Reason: MSF Database - Automerged Doublepost
 Old 01-08-2014, 10:01 AM   #12
pmartz16's Avatar
Yes my bad. Its e85
2014 Mz3 MG
 Old 01-08-2014, 10:11 AM   #13
Posts: 12,651   (View Stats)
methyl hydrate would be in hardware stores in the paint section.
It is probably fine to run ethanol and it is safer for the person handling it.
If you have ethanol available you can also drop a couple of gallons in the tank.
 Old 01-08-2014, 10:23 AM   #14
I've been in quite a few hardware stores but haven't seen that yet.
I was thinking of switching back to a D05 nozzle while running E and see how my IDC looks. If they are low enough I'll add a little to the tank. With the D07, I go through Washer fluid tank real fast. Makes road course racing hard to do. I'm scared I will run out mid race.
Also, running in tank E is not wallet friendly for me. A couple gallons would cast me like 50$
 Old 01-08-2014, 10:50 AM   #15
SparkySparks's Avatar
Posts: 1,314   (View Stats)
Where I am originally from if you wanted straight ethanol all you had to do was go see Billy-Bob and get some moonshine.
Do they have denatured alcohol in the hardware stores? You could always run that if you can't find methanol.
On Order:
Coming Soon:
DIY Projects:
Last edited by SparkySparks; 01-08-2014 at 10:50 AM. Reason: MSF Database - Automerged Doublepost
 Old 01-08-2014, 10:56 AM   #16
I'm from Tennessee. I know all about shine.
They have denatured alky. That is pretty much ethanol tho. It's like 80%E 20%meth if I remember correctly. Most of the denatured stuff I found out in town is pink in color. Not sure if it's got dome other crap in it
 Old 01-08-2014, 11:03 AM   #17
Eth Fiend
phate's Avatar
Posts: 6,942   (View Stats)
Ethanol vs methanol in a port injection setup has a couple advantages and disadvantages. Ethanol is safer to handle, as Lex said. It will also help fueling head room more than methanol will, but that's a pretty small difference. Methanol, though, has a much higher latent heat capacity, meaning it will cool the intake charge more than ethanol. So, if you're going for fueling head room only, eth is probably the way to go.
-06 MS6
-Corn fed 07 MS3 - Sold
Mauro_Penguin (01-09-2014)
 Old 01-08-2014, 11:15 AM   #18
I'm not really trying to get more head room. Just trying not to lose any more. I'm using it for lower bats, and higher octane. I know it's not as good as pure meth but I don't even have pure meth available. The best I could get is around a 50% mix. I'm just hoping a higher concentration if E will be as good as the 50/50 meth or better
 Old 01-08-2014, 12:22 PM   #19
hopefully @rfinkle2; can chime in with his experience.
 Old 01-08-2014, 12:41 PM   #20
kashbringer's Avatar
Posts: 514   (View Stats)
kashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the world
Groaned at 4 Times in 2 Posts
@Voltwings; Ran denatured alcohol from home depot in his kit and it worked fine for fueling bu it's like 9 bucks a can. As other have said.. Eth does not cool as well as meth but works fine. Running mixes of meth/water will help get you cooling and not destroy afrs with all the extra fuel.
2012 MazdaSPEED 3 - Crystal White Pearl
Performance - Precision 5858 - Built motor (K1 Rods / Wiseco Pistons / ARP main studs / Stock head bolts) - Cobb V3 AccessPORT - PERM 5th port kit, PERM Plate - HTP 3.5" Intake (Powder Coated Pure Orange) - Autotech HPFP Internals – CPE Vband Exhaust Manifold - Kozmic Vband Downpipe, Dumptube, Oil feed / Return lines, Vented OCC, Primary EGR delete – Ultimate Racing Catback, FMIC modified for 5th port by Kozmic Motorsports - Turbosmart dual port , 45mm EWG - JBR Coolant Bypass, EGR Delete, Throttle body TIG, Dogbone RMM, Transmission Mount, Sealed OCC - Grimmspeed EBCS - NGK plugs - Bosch 3.5 Bar MAP w/MattJackson86 PnP Harness – Ported Intake manifold with VCTS delete, 1/8" Intake manifold TIG by Zack - Spec Stage 3+ Clutch and flywheel
Tuned by Voltwings
(OLD k04 SET UP ) 374.5 WHP 447.2 WTQ with stock K04 - 1-17-14 Dynocom dyno
(New BT numbers soon) ~487WHP 455wtq Virtual Dyno and out of fuel... moar injectors!
Looks - Pure Orange Powder Coated Gen Pu Stockers - Muteki SR48 Lugs - 5k HIDs / 3K HID Fogs
kashbringer is offline   Reply With Quote
The Following 2 Users Say Thank You to kashbringer For This Useful Post:
speed3sailor (01-08-2014), Voltwings (01-08-2014)
 Old 01-08-2014, 12:56 PM   #21
Voltwings's Avatar
Posts: 3,713   (View Stats)
I quoted Phate because i saw pretty much exactly what he said. Also, i found that on a 25% E85 blend, spraying denatured alcohol played much nicer with my AFR's than spraying methanol. Trying to find a happy median for 3 fuels is kind of a pain lol. Methanol is much cheaper though... i ran denatured with great success however, and i love the smell when it kicks in, smells like horsepower
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
The Following 2 Users Say Thank You to Voltwings For This Useful Post:
Mauro_Penguin (01-09-2014), speed3sailor (01-08-2014)
 Old 01-09-2014, 03:01 PM   #22
Dust's Avatar
Posts: 192   (View Stats)
Dust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the world
Eth will fuel better than Meth. I had to do the same thing you are doing in Japan. Check on camp fuel, burning alcohol, gas line antifreeze, etc. You have to have some ingenuity to get things done in other countries.
Dust is offline   Reply With Quote
The Following 2 Users Say Thank You to Dust For This Useful Post:
Mauro_Penguin (01-12-2014), speed3sailor (01-09-2014)
 Old 01-09-2014, 03:48 PM   #23
The Canadian cars had a much larger washer fluid tank. I believe the Euro cars might as well due to the headlight washers. It also includes a low level light that you might be able to plug into the harness.
 Old 01-09-2014, 10:26 PM   #24
I need a bigger tank for sure. When im tuning, I go through a full tank in a hurry. hopefully HTP releases their new tanks soon.
do you think that would be the regular 3s also?
Last edited by speed3sailor; 01-09-2014 at 10:26 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-09-2014, 10:51 PM   #25
Most likely.
 Old 07-18-2018, 06:11 AM   #26
LeoK's Avatar
Posts: 1   (View Stats)
LeoK is an unknown quantity at this point
Smile Bioethaol Fuel
Bioethanol is widely used in smart fireplace systems. My family has bought our fireplace from Planika. They are safe, easy to maintain and use.
LeoK is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f303/ethanol-injection-162247/
E-85 injection vs meth injection This thread Refback 03-07-2015 11:09 AM
The questions part of Ethanol FAQ - Direct Injection specific Twofer MazdaSpeed 3/6 - E85 Fueling 40 07-05-2017 05:16 PM
Ethanol seanmiller09 Mazdaspeed3/6 General Discussion 8 12-13-2010 08:56 PM
Ethanol/H20 Injection Nepharius MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 07-12-2010 07:37 AM
Ethanol in gas countzero2k9 2010 MS3 - Troubleshoot/Diagnostics 9 06-22-2010 01:09 PM
Ethanol from almost anything? Coskata opens Lighthouse cellulosic ethanol plant Haltech Automotive News 0 10-18-2009 10:20 AM
Page generated in 0.63940 seconds with 31 queries
