 Old 01-12-2009, 04:50 PM   #1
7mileshome's Avatar
Posts: 350   (View Stats)
7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world
Default Fuel Cut, or tuning issue
I just installed a cpe fuel pump last weekend, and this morning on my way to work, I gave it some gas, and I had fuel cut in 3rd gear! between 3K and 3500. My question is, is anyone else having this problem? Do I need to adjust my maf voltage ever time the weather changes?
P/S- it was 40 deg outside. Last time we messed around on the stand back it was like 55 deg out side.
2012 Mazdaspeed3 LSM
Should have gotten a speed6
2008 Mazdaspeed3 GT Black Mica [sold]
Built motor, Etc.
383 hp 401 tq GTX2867R @ 25 psi
7mileshome is offline   Reply With Quote
 Old 01-12-2009, 04:57 PM   #2
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
Do you have a dashhawk to log fuel?
 Old 01-12-2009, 05:06 PM   #3
phailerider's Avatar
Posts: 4,639   (View Stats)
phailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the world
Groans: 49
Groaned at 179 Times in 125 Posts
when it gets cold its possible the fuel that you have added down low on your tune is inducing it.
eliminating that, or running 17psi should be a cure. but seriously.... yes, now you know why making power on this car is such a bitch. this ecu sucks.
once you get the dashhawk... run some logs so a/fs look good, and then you can adjust fuel there... maybe even pull some if and it doesnt look like it will hurt. another thing to try is adding back the fuel, and just pulling some timing during spool.
theres a bunch you can do without getting the cut flash if you dont think youre ready. but no matter what...yes.... 40deg and less, making power you have to be creative with the tables.
phailerider is offline   Reply With Quote
 Old 01-12-2009, 05:37 PM   #4
7mileshome's Avatar
ok, cool. I just got the dashhawk today, so tomorrow I can make some logs.
Thanks !1
Built motor, Etc.
Kia Rondo recalled for fuel pump issue Haltech Automotive News 1 09-24-2008 07:50 AM
Fuel management tuning? Reap3rVIRUS MazdaSpeed 3/6 - ECU Computer Tuning 6 07-17-2008 05:57 PM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 07-10-2008 11:10 AM
This sound like the fuel pump issue? pheare MazdaSpeed 3 - Engine, Transmission & Driveline 2 06-26-2008 12:55 PM
How Much Fuel Is Left When Fuel Indicator Light Comes On, Hard Starting Dodge Caravan, Oil Pan Plug Fell Out, Mixing Coo Haltech Automotive News 0 06-10-2008 02:12 AM
Page generated in 0.25234 seconds with 22 queries
