 Old 10-01-2015, 10:14 PM   #1
jmen73's Avatar
Posts: 63   (View Stats)
jmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of light
Default Fuel Injector Grommets
I have to replace the grommets PN# L3M8-13-252 (24-396) which is the grommet that is just before the o-ring on the fuel injectors. I ordered and received grommets that were not indicative of what I am replacing. There is a note on the part diagram (Z) that I don't completely understand. Do I cut them to fit?FUelrailinjectorPNs.png
2007 Red MS3: 4" ported PTE 5858, HTP intake, HTP undermount, Treadstone TR8, HKS BOV (VTA), Custom exhaust mani, V-band dp, CNT exhaust, ACT clutch, ACT 6-puck PP, Damond PMM, RMM & TMM, Koni yellows, Eibach prokit springs, Damond OCCs (vented & not).
jmen73 is offline   Reply With Quote
 Old 10-02-2015, 05:37 AM   #2
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I don't see a not on part diagram Z that says to cut anything.
"Exclusivity" - CP-enis
Demodded.
The Seals
anavrinIV (10-02-2015), WetzMS3 (10-02-2015)
 Old 10-03-2015, 07:04 AM   #3
jmen73's Avatar
No worries. They sent the wrong part. I got the OEM injector seals instead of the white plastic grommet...
Injector seals - need to replace injector/fuel line O-rings? TheRealDefman 2010 MS3 - Engine, Transmission & Driveline 3 03-02-2014 09:35 PM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 07-10-2008 11:10 AM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 06-10-2008 02:12 AM
Page generated in 0.24211 seconds with 22 queries
