 Old 11-30-2018, 06:56 PM   #1
DA48's Avatar
Posts: 3   (View Stats)
DA48 will become famous soon enough
Default Fuel leak and engine sputter
Looking for some advice. In the process of searching but needed to get a jump start on diagnosing.
I have a Ď07 MS3 with 87k. Iíve owned it since August and itís bone stock with OEM CAI. Itís not a DD and until tonight was parked for about a week and a half on a full tank of gas. So I loaded the fam up tonight and a few min down the road got some major sputtering and cutting out. Turned around and came home and found a puddle of gas behind the RR tire. I took the gas cap off and seemed to relieve a lot of pressure based on sound.
I canít dig around until tomorrow, but curious if this sounds symptomatic of a basic fuel leak, or if it seems to be something else in the fuel system causing excess pressure.
Your help is much appreciated.
-Matt
DA48 is offline   Reply With Quote
 Old 12-01-2018, 12:59 PM   #2
DA48's Avatar
So as a quick update, it looks like fuel was probably leaking from the canister filter attached to the filler neck, behind the RR wheel well cover. Looks like this filter is part of the evap system. Does anyone happen to have a part number for this filter? I'd like to replace it along with the purge valve and see what happens.
 Old 12-09-2018, 06:08 PM   #3
DA48's Avatar
For the sake of future searchers...
I ended up replacing the purge valve first based on price and research. Iíve put ~50 miles on the car so far and the problem seems to have gone away. Hopefully itíll stay gone.
The Following User Says Thank You to DA48 For This Useful Post:
Thor Hammer (12-11-2018)
 Old 12-10-2018, 05:10 AM   #4
Fstrnyou's Avatar
Posts: 2,488   (View Stats)
Thanks for the update.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
fuel leak shawn. MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 10-20-2012 07:43 AM
Fuel Leak bschuske Gen2 MS3 General Discussion 14 12-01-2011 03:36 AM
Fuel Leak? azokaei MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 12-13-2010 04:09 PM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 07-10-2008 11:10 AM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 06-10-2008 02:12 AM
Page generated in 0.25448 seconds with 21 queries
