 Old 02-22-2019, 01:06 PM   #1
David R's Avatar
Posts: 1   (View Stats)
David R is an unknown quantity at this point
Default Fuel pressure drops at idle
What's up guys? I'm new here and have searched all through the forums for help with my situation. My 2008 speed 3 starts and idles for about 5-10 minutes and then drops fuel pressure. From reading the forums I changed pretty much everything in the cars fuel system. I upgraded stock intank pump to a deatschwerks pump, I changed the regulator and filter, I got a used HPFP with my old corksport internals, and I changed the relief valve as well. I'm getting 12v on everything, except the circuit relay in the fuse block. On that I'm getting 10.5v. I noticed that when the coolant temp hits about 145 the car starts to drop fuel pressure. I cleaned all of the grounds and went as far as changing the crank angle sensor. Any help would be appreciated!
I'll attach a log from idle before it shut off.
David R is offline   Reply With Quote
 Old 02-22-2019, 03:53 PM   #2
Police - Grammarhead
Vansquish's Avatar
Groans: 1,901
I'm a little confused. Are you using known good HPFP internals?
Low fuel pressure at idle racersir Mazdaspeed3/6 General Discussion 22 08-30-2017 11:35 AM
Sporadic fuel pressure drops during WOT 813thumper MazdaSpeed 3/6 - Troubleshoot/Diagnostics 16 03-16-2015 09:39 PM
Fuel pressure drops Zak 2010 MS3 - Troubleshoot/Diagnostics 5 08-19-2014 05:52 AM
Fuel Pressure Drops - Pump or/and RV Axela_EN MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 01-26-2014 03:44 PM
Help my fuel pressure drops down to 5-600psi after 5000rpms?? Wenis Prinkle MazdaSpeed 3/6 - Troubleshoot/Diagnostics 25 02-11-2012 11:37 PM
Page generated in 0.23671 seconds with 22 queries
