Like Tree7Likes
 Old 04-30-2012, 03:13 PM   #1
twintzs's Avatar
Posts: 40   (View Stats)
twintzs has a spectacular aura abouttwintzs has a spectacular aura about
Default Fuel Pressure Relief Valve Question
How do you determine if the Fuel Pressure Relief Valve is bad? I'm having fuel pressure drop in the 2500 to 4200 rpm range but then will hit targeted hpfp.
I've searched and it seems the only way to test is to read the ap fuel pressure after car is off. I get 500 psi and it increases slightly. Then another time I have the fuel pressure drop below 60 with car off.
Is there a How to on replacing this part?
Thanks in advance.
twintzs is offline   Reply With Quote
 Old 05-02-2012, 08:21 PM   #2
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
HOW-TO: Replace Relief Valve (RV)
The test you performed is the reccomended test. I am diagnosing this issue with a buddy's car now. Sometimes fuel pressure shits the bed, sometimes it holds strong. My car with key on engine off drops pressure real low...it does not build...but my fuel pressure with car on is spot on. Weird.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 05-07-2012, 04:40 PM   #3
twintzs's Avatar
Well I got the 2150 upgrade garage fuel relief and no change. Pressure still drops between 3k and 4k rpm. Now what. I can't just keep throwing money at everything. Please help.
 Old 05-07-2012, 04:42 PM   #4
EdgeAutosport.com's Avatar
Posts: 6,209   (View Stats)
Is the fuel pressure failing at peak load?
my guess is internals
The Following 2 Users Say Thank You to EdgeAutosport.com For This Useful Post:
Ms3_Miami (05-08-2012), smoogs12 (05-08-2012)
 Old 05-07-2012, 04:44 PM   #5
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
If its dropping at peak load, around 2.0 +, then your internals are bad.
The Following 3 Users Say Thank You to G26 For This Useful Post:
EdgeAutosport.com (05-07-2012), Ms3_Miami (05-08-2012), smoogs12 (05-08-2012)
 Old 05-07-2012, 05:35 PM   #6
mrmonk7663's Avatar
If not at peak load, then possible it is your in tank filter clogged up?
 Old 05-07-2012, 05:36 PM   #7
Or spill valve, post logs op!
This thread is useless without a log
 Old 05-08-2012, 05:11 AM   #8
twintzs's Avatar
I apologize. Here is a log from a day ago.
 Old 05-08-2012, 05:17 AM   #9
G26
G26's Avatar
Groans: 39
What internals do you have? That looks like the kmd drop fuel psi at max load syndrome lol.
 Old 05-08-2012, 05:26 AM   #10
twintzs's Avatar
Yes I have the KMD internals. This log was taken in 4th gear at 2500 RPM to 6500 rpm.
 Old 05-08-2012, 05:27 AM   #11
leon78's Avatar
Posts: 2,595   (View Stats)
Your "Actual" is great. (HPFP Act. Press. (PSI) vs HPFP Des. Press. (PSI))...but the desired is dropping off? You can leave it so your commanding 1749 across the RPM range.... the Fuel Pressure Relief Valve is still giving you over 2000 psi NP. And peak load is happening 3000 rpm prior to the strange drop off? I'm curious as to whats going on...subbed.
2013 Scion FR-S (Whiteout)
Less parking more racing
leon78 is offline   Reply With Quote
 Old 05-08-2012, 05:27 AM   #12
twintzs's Avatar
I have a dyno session set for tomorrow morning should I cancel it based on the log?
 Old 05-08-2012, 05:28 AM   #13
G26
G26's Avatar
Groans: 39
His desired is staying at 1749, its his actual that is dropping around 2.15 load.
The Following User Says Thank You to G26 For This Useful Post:
leon78 (05-08-2012)
 Old 05-08-2012, 05:35 AM   #14
leon78's Avatar
Ahh, thanks....I looked over that dip where it goes down to 1350ish cuz it jumps right back up just fine. Why does the Calculated Load effect the mechanics of the HPFP (KMD wise) ?, electric signal says time for fuel cut?
 Old 05-08-2012, 05:40 AM   #15
G26
G26's Avatar
Groans: 39
Because load is effectively torque. At max torque fueling demands are the greatest.
 Old 05-08-2012, 06:09 AM   #16
twintzs's Avatar
I removed the internals last week and inspected them. I wasnt sure what I was looking for but I did take some pictures.
 Old 05-08-2012, 06:32 AM   #17
twintzs's Avatar
I'm concerned about the dyno session should I not go? I dont know how bad this is.
 Old 05-08-2012, 06:51 AM   #18
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
Pretty sure this isn't bad internals, it looks more like some sort of fuel cut to me. Are you running the HPRV in this log? Who is tuning you? @phate may have a little more insight on this.
 Old 05-08-2012, 07:14 AM   #19
twintzs's Avatar
here is the log with the upgraded hpfp relief valve. Boost_Creep has been tuning me great guy he thinks it maybe internals but can find anyone local to switch out with to test.
 Old 05-08-2012, 08:13 AM   #20
This opened to jiberish for me, and I am not excel smart enough to unjiberish it
 Old 05-08-2012, 08:19 AM   #21
mrmonk7663's Avatar
Same..the log is in the wrong format in excel...can't read it.
 Old 05-08-2012, 08:46 AM   #22
Eth Fiend
phate's Avatar
Posts: 6,944   (View Stats)
I've pulled some failing KMD's to find they looked perfect. That pressure drop looks like internals, rather than a relief valve issue.
@Boost_creep
PS - The data log he posted just needs to be parsed by using the "Text To" function in Excel.
File Type: xlsx twintz_PressureDrop_datalog2_Posted201205080814.xlsx (44.3 KB, 36 views)
-06 MS6
-Corn fed 07 MS3 - Sold
Boost_creep (05-08-2012), leon78 (05-08-2012), rfinkle2 (10-30-2014)
 Old 05-08-2012, 09:32 AM   #23
twintzs's Avatar
well, I just took off the spill valve and it looked perfect. No gunk or anything not that I was running E85. I only us 93.
@Boost_creep
@phate
Any way to test the internals? I just bought the upgraded relief valve and dont have the money to drop another $300+.
Last edited by twintzs; 05-08-2012 at 09:32 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to twintzs For This Useful Post:
 Old 05-08-2012, 09:33 AM   #24
G26
G26's Avatar
Groans: 39
@phate
Put your stock ones back in.
 Old 05-08-2012, 09:42 AM   #25
Boost_creep's Avatar
Posts: 829   (View Stats)
Boost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the world
@phate
Brian,
If you still have your warranty card, kmd should replace them for you. I personally have not had to go down that road, but it appears others have.
Did you call kmd yet?
www.dizzytuning.com
www.facebook.com/dizzytuning
Boost_creep is offline   Reply With Quote
The Following User Says Thank You to Boost_creep For This Useful Post:
 Old 05-08-2012, 09:50 AM   #26
twintzs's Avatar
Originally Posted by Boost_creep View Post
Brian,
I talked to some guy who sounded like a prick. Kept calling me bro and just told me that it could be a number of things and he couldnt diagnosis over the phone. Based on searching it appears i need to talk to a Mara at KMD.
The Following 2 Users Say Thank You to twintzs For This Useful Post:
 Old 05-08-2012, 09:57 AM   #27
G26
G26's Avatar
Groans: 39
Tell them you know and they know this is a common problem caused by their bull shit.
 Old 05-08-2012, 09:58 AM   #28
Yes, Mara is very pleasant to deal with. I can look back and see if she has a direct email, but I think if you just send them a general email, she would be the one who replies. I'll take a look though.
Edit- ok, I just found it. mara@kmdtuning.com
Pretty self explanatory. Lol.
www.dizzytuning.com
 Old 05-08-2012, 10:06 AM   #29
Same thing happened to me, pulled my kmds and they looked fine. swapped spill valves with the kmds still in the pump and the problem went away for a couple pulls and came back.
I ended up putting in a new pump with AT internals and no problems since then but I still think my in tank is going out because even at wot my pressure dips to 1650.
 Old 05-08-2012, 10:16 AM   #30
twintzs's Avatar
Where is your pressure dropping to 1650 above the 4k range or below even with the AT internals?
 Old 05-08-2012, 10:25 AM   #31
let me see if I can find some recent logs
Seems like pressure isnt dipping anymore so it looks like it was the pump/spill valve
 Old 05-08-2012, 11:48 AM   #32
G26
G26's Avatar
Groans: 39
Autotechs ftw. 11k miles and counting.
 Old 05-08-2012, 11:54 AM   #33
G26
G26's Avatar
Groans: 39
Btw, just had a local nator guy install his ptp fp internals, and his fp is dipping bad.
freddd likes this.
 Old 05-08-2012, 01:49 PM   #34
mrmonk7663's Avatar
We have a local 3071 car that had PTP internals and had to ditch them for another option...They just wouldn't put the pressure out that was needed. DJ was tuning the car actually. The internals were an older batch though, so maybe they have changed.
 Old 05-08-2012, 01:51 PM   #35
Eth Fiend
phate's Avatar
Internals are hit and miss, no matter which way you go. I've worked with several cars with PTP pumps that work great, as well as KMD, CPE, and AT.
-06 MS6
atvfreek (05-08-2012), Boost_creep (05-09-2012), mrmonk7663 (05-08-2012), Ms3_Miami (05-08-2012), rfinkle2 (10-30-2014)
 Old 05-08-2012, 05:12 PM   #36
mrmonk7663's Avatar
Honestly, this is a rather unfortunate thing ...but yes it is true.
The Following User Says Thank You to mrmonk7663 For This Useful Post:
 Old 05-08-2012, 07:17 PM   #37
twintzs's Avatar
Just a random thought could the low pressure be how I'm taking my logs. I get into 4th gear cruise until I get to 2500 RPMs then I hit the log button on the AP then I stomp on the gas to 6500/7000 rpm.
Mikey likes this.
 Old 05-08-2012, 07:23 PM   #38
mrmonk7663's Avatar
No.
 Old 05-08-2012, 08:43 PM   #39
Ms3_Miami's Avatar
Posts: 3,185   (View Stats)
Ms3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the world
Groans: 55
yup thats me..asked John at PTP for a refund and ordered AT fp internals from Edgeautosport . I know two guys on here that have the PTP fp internals for 30k miles on E85 without an issue
08 Black Mica Ms3~full bolt ons/Nishan Tuned-Sold
NATOR FL
Ms3_Miami is offline   Reply With Quote
The Following User Says Thank You to Ms3_Miami For This Useful Post:
 Old 11-25-2018, 08:31 AM   #40
mattydame's Avatar
Posts: 1   (View Stats)
mattydame is an unknown quantity at this point
Default 2011 Mazdaspeed 3 jerking violently
Hi everyone. I have a 2011 Mazdaspeed 3. Until about 2 weeks ago everything was great. I was on my way home from work when all of a sudden I lost all power and my car started jerking violently and the throttle did nothing. The idle would almost stall but would keep running. I was able to make it home going on 10 mph. I checked my fuel pressure and it seems to be lower than normal. Does anyone know if the fuel pressure relief valve would cause this problem? Thanks
Tachi.official likes this.
mattydame is offline   Reply With Quote
High Pressure Relief Valve Option SilverDemon MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 161 04-29-2011 08:10 PM
Page generated in 0.56766 seconds with 30 queries
