 Old 04-10-2012, 04:26 PM   #41
EdgeAutosport.com's Avatar
Posts: 6,209   (View Stats)
Originally Posted by Ckmazdaspeed3 View Post
Did anybody on here ever resolve this dropping fuel pressure issue? I am having fuel pressure drop down to 1300 at wot. It happens at peak torque/load. I haz cpe pump, I ran 4 gallons of eth for 6 months but am runnin pump on my new build, it does recover, and I do hit peak pressure when I let off.
Also, it could be coincidence, but it seems to get worse with each progressive pull. Two days ago I tried cleaning my spill valve (I will try to do it more thoroughly today) and went out for a few logs. The first log was fine, second dropped to 1500s and third dropped to 1300s. These logs were within 5-8 minutes of each other.
Same with my pump swapped spill valves got better. Then the same thing happened, after that I put in a new pump with internals and it was fine for 5+ pulls then the fp started to dip. Also the only time my fp dips is when idc>100%
The Following User Says Thank You to EdgeAutosport.com For This Useful Post:
Ckmazdaspeed3 (04-10-2012)
 Old 04-10-2012, 06:19 PM   #42
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
From what dj described in my build thread for ways that pumps fail, it sounds like yours is not spill valve/hpfp related.
Hpfp/spill valve problems from what I understand happen at peak load/torque. Problems related to the itfp and relief valve (I think) happen at peak airflow, which I'm sure is when your IDC is >100.
... I'm not smart, just regurgitating from a reliable source.
'I can not remember if it is the last or second to last page, but dj gives me a run down of main culprits of dropping fuel pressure.
http://www.mazdaspeedforums.org/foru...ml#post1351923
The Following 2 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
EdgeAutosport.com (04-10-2012), frodaddyweez (04-11-2012)
 Old 04-10-2012, 06:27 PM   #43
Have you done any testing with the fuel injector latency table in ATR? Lower that value by 0.01 at a time until you are <100% IDC. @cld12pk2go did some testing and even at 0.90 latency he hasn't seen any increase in EGT's. I wouldn't just go lowering your latency based on his results, but it is promising.
Ckmazdaspeed3 (04-10-2012), EdgeAutosport.com (04-10-2012)
 Old 04-15-2012, 12:07 AM   #44
Matthew Myers's Avatar
Posts: 235   (View Stats)
Matthew Myers has a reputation beyond reputeMatthew Myers has a reputation beyond reputeMatthew Myers has a reputation beyond reputeMatthew Myers has a reputation beyond reputeMatthew Myers has a reputation beyond reputeMatthew Myers has a reputation beyond reputeMatthew Myers has a reputation beyond reputeMatthew Myers has a reputation beyond reputeMatthew Myers has a reputation beyond reputeMatthew Myers has a reputation beyond reputeMatthew Myers has a reputation beyond repute
Groaned at 5 Times in 2 Posts
I have autotech internals in my pump and last night after about 6 runs at an 1/8 mile drag strip and a 10 minute drive home, my fuel pump started rattling. Act fp is 185-280 at idle. Pulled out the pump, took fp apart and nothing really looked bad at all, the only things I noticed was at the end of the internals, was gray. Autotechs come in black. Gray part was from wear. No scoring though. Put the pump back in, act fp pressure was at 260-340 with rattling. Any clues?
[SIGPIC][/SIGPIC]Cobb AP/Cobb TIP/SURE RMM/SURE SHORTSHIFT PLATE/K&N SRI/COBB XLE BPV/AUTOTECH HPFP/TURBO XS 3"DP/ VIBRANT PERFORMANCE DP BACK EXHAUST/CP-E FRONT MOUNT IC/ ACT 6 PUCK STREETLITE FLYWHEEL/ GRIMMSPEED EBCS 3PORT MODE/ JBR SHIFTER BUSHINGS/ DIZZY TUNED @phate
FUTURE PROJECTS: GTX3076R/ CP-E PISTONS & CONNECTING RODS/ CP-E 4" TIP/ CP-E 3.25 SRI
Matthew Myers is offline   Reply With Quote
 Old 04-15-2012, 03:06 PM   #45
Jhornbrook's Avatar
Posts: 708   (View Stats)
Groaned at 6 Times in 4 Posts
I have had the same thing minus the drag strip. My auto techs turned grey and I replaced with stock. Fuel pressure at idle is 180-260. I'm going to be swapping the intank pump, relief valve and hpfp, next week. I'll try and post up after I do the installs.
 Old 04-15-2012, 07:04 PM   #46
Let me know how everything turns out after that. I am convinced that it happens to be the relief valve.
 Old 04-15-2012, 07:24 PM   #47
triphop631's Avatar
Posts: 1,191   (View Stats)
triphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the world
Groans: 30
I am having almost the same issue and @phate seems to think it is my RV since i changed to a totally different pump and it is doing the same thing.
Sent from my DROID RAZR using Tapatalk 2
I haz Partz!!!!!!!!!!
triphop631 is offline   Reply With Quote
 Old 04-15-2012, 07:26 PM   #48
crazyp's Avatar
Posts: 1,093   (View Stats)
crazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the world
Groans: 68
Groaned at 22 Times in 9 Posts
Remember guys, quick RV check is with the car off fuel pressure should be 900 psi or higher. If its 100 or lower its the RV
2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RDM, Turbine tech FDM and FMM=JBR trilogy MM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC
crazyp is offline   Reply With Quote
The Following User Says Thank You to crazyp For This Useful Post:
Ckmazdaspeed3 (04-16-2012)
 Old 04-15-2012, 07:27 PM   #49
PT-Performance.com
This link should help some of the guys in here as far as finding the part upgrade.
 Old 04-15-2012, 07:43 PM   #50
Eth Fiend
phate's Avatar
Posts: 6,945   (View Stats)
I just had another gentleman having trouble after many data logs of solid pressure. Just a slight drop in pressure on the low end, and other low blips here and there. New RV went in Friday night and his fuel pressure is AMAZING now. 2k psi like it's nothing.
-06 MS6
-Corn fed 07 MS3 - Sold
crazyp (04-15-2012), G26 (04-16-2012)
 Old 04-15-2012, 07:44 PM   #51
triphop631's Avatar
Groans: 30
Thanks, @phate
Guess I will be ordering the ptp one. Which pressure should I get?
The Following User Says Thank You to triphop631 For This Useful Post:
phate (04-15-2012)
 Old 04-15-2012, 08:01 PM   #52
Eth Fiend
phate's Avatar
Thanks, phate
Didn't even know they had different pressure valves available. We can only read up to 2070 (?) with the stock sensor, so we won't be targeting anything over 1950-2k psi.
-06 MS6
G26 (04-16-2012)
 Old 04-15-2012, 08:11 PM   #53
triphop631's Avatar
Groans: 30
1950
2050
2150
2250
Would 2050 be overkill?
 Old 04-16-2012, 04:53 AM   #54
Was there any rattling at all? Mine has a REALLY LOUD rattle. Could be coming from underneath fuel pump, but definitely coming from that general area.
Also when we unplugged the solenoid on the spill valve at idle, we heard the rattling a lot less.
Last edited by Matthew Myers; 04-16-2012 at 04:53 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-16-2012, 05:11 AM   #55
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
I started this weekend getting dips for a cell or 2 into the 1600's around 3-3.5k after a spike, where as before fuel psi was always over 1750 psi. New 2150 psi RV on the way, should be installing it in 3 weeks.
For now I dropped my commanded fp to 1680. Also, this is with approx 10k miles with the internals in, with constant datalogs/wot.
1950
2050
2150
2250
The 2150psi valve was recommended as the best one.
Last edited by G26; 04-16-2012 at 05:13 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-16-2012, 05:19 AM   #56
G26
G26's Avatar
Groans: 39
I can't wait.
Could you possibly post 2 datalogs of his showing the before/after?
 Old 04-16-2012, 05:33 AM   #57
triphop631's Avatar
Groans: 30
Originally Posted by G26 View Post
I can't wait.
Why are you waiting 3 weeks to install?
 Old 04-16-2012, 05:49 AM   #58
G26
G26's Avatar
Groans: 39
Install day, doing seals/rv/tigs with a couple guys.
It should be 900psi + with the car having been just driven, and then shut off.
Last edited by G26; 04-16-2012 at 05:49 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-16-2012, 05:57 AM   #59
G26
G26's Avatar
Groans: 39
Friend of mine had his relief valve go out on him, he also had a rattle with idle fp around 150-250psi.
This was with 75k miles with the oem fuel pump/rv in at oem psi. He had the autotechs in for a week, and after racing someone, the rv went completely bad.
 Old 04-16-2012, 06:00 AM   #60
My car only has 47k miles on it. But yes. I'm almost certain that its the rv
 Old 04-16-2012, 06:04 AM   #61
G26
G26's Avatar
Groans: 39
My car only has 16k on it, 10k with the autotechs and as I said, I am starting to get dips after spikes in fp.
 Old 04-16-2012, 01:13 PM   #62
frodaddyweez's Avatar
Posts: 988   (View Stats)
frodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the world
Yeah I'm thinking about getting a new RV myself. I swapped mine with another local member's stock RV, who was holding pressure fine on his, but I still had a drop in mine.
My ap reads only 50psi when the engine is off and has been sitting for awhile. After I immediately shutoff my engine though, it'll slowly climb to 1600ish and then slowly drop all the way down to 50.
Maybe I just need a better one. I might try that next.
2009 Mazdaspeed3: PTE 5857 25psi etuned by tooslow2010 --> SOLD
2011 Mustang Shelby GT500 w/SVTPP: 2.3L Trinity TVS w/2.4" VMP pulley, L&M NSR cams, JLT 123mm Intake, FRPP CobraJet Twin 65mm Throttle Body, 56# Injectors, VMP Fuel Pump Booster, AFCO Dual Pass Heat Exchanger, FRPP L Springs, BMR Adjustable Panhard Bar, Shaftmasters Aluminum One-piece Driveshaft, Lethal Performance Catless H-Pipe, Flowmaster Outlaw Axleback, 315 NT05r's
Lund Tuned 683whp/622wtq 11/11/16
Upcoming mods: Full-length Headers and ID1300s for E85
1995 Mazda Miata: Stock (daily)
frodaddyweez is offline   Reply With Quote
 Old 04-29-2012, 07:25 PM   #63
triphop631's Avatar
Groans: 30
Did my RV today and my pressure is holding strong. No dips while WOT.
frodaddyweez (04-30-2012)
 Old 04-29-2012, 08:03 PM   #64
event's Avatar
Posts: 521   (View Stats)
event is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the world
FP will go down after it sat for a while. With the car fully hot and off, it should reach 1800+ psi in a few minutes. It will eventually start going back down to 50-60 once everything cools off. If it only gets to 1600psi with everything FULLY hot, then it sounds like it may be the RV. Did your friends good RV not help?
***sold*** 06 MS6 Cobb SRI 3.5" ETS TMIC Cobb AP Sure RMM JBR SSP EBay Catless DP Autotech HPFP Magnaflow
2013 Scion FR-S 6MT
1993 Mazda Miata with shocks, springs, fsb, GT2560r, Megasquirt
event is offline   Reply With Quote
The Following User Says Thank You to event For This Useful Post:
 Old 04-30-2012, 10:47 AM   #65
Well I didn't see where it would stop building pressure right after I shut off my car. I just stopped monitoring it after I saw it climbing over 1600. I thought the 50-60psi was a problem but the guy I switched RVs with also gets 50-60psi too when Coles down and off. So I guess that's normal.
On Thursday he hooked me up in some autotech internals so we swapped the kmds for those. While trying to remove the kmds, the plunger was seized in the 18mm assembly that the spring and internals install around. It eventually came out but only after it broke. Our guess was that I overtorqued it when I installed it. I'm still trying to let it breakin and haven't driven it much. I'm not getting my hopes up but ill try it out over one of these next few days.
 Old 05-01-2012, 04:50 PM   #66
Update everyone, after 2 and 1/2 weeks of not driving my car, I started up my car today to check the battery without connecting the accessport. Started up, no rattle whatsoever it seemed, revved for a split second up to about 2500 rpms and as the rpms started dipping down to idle, I noticed that the engine started to stall out and die due to the lack of fuel being provided for combustion (as if I was out of gas)... the pressure it's getting right now it seems is virtually worthless. @phate says that the relief valve is, can you say, fucking destroyed. Already ordered the new rail valve upgrade to replace it from protege garage, who by the way better get there shit together and give me a tracking number time now!
The Following User Says Thank You to Matthew Myers For This Useful Post:
frodaddyweez (05-01-2012)
 Old 05-06-2012, 08:49 AM   #67
Edit, installed the 2150 rv and now everytime fuel pressure hits above 2074psi I get immediate fuel cut. Sensor only reads 2074, anything more than that and you'll get fuel cut everytime. Feels like hitting a brick wall. Not sure if protege garage will allow me to swap it out for the 1950 psi one since I've already started using the 2150 valve. I've been asking around to see if there is a way around the fuel cut, but no one has responded as of yet.
 Old 05-06-2012, 09:31 AM   #68
My fuel psi issues at wot are gone now. Finally. The autotechs are working brilliantly. Apparently the seized plunger, in the kmds, was causing my problem. We ended up breaking it while trying to remove it. So much for reselling it.
 Old 05-07-2012, 08:23 AM   #69
triphop631's Avatar
Groans: 30
I am having some issues and maybe you guys can help me out.
I swapped out my RV and the pressure seems to be good, but every now and then I am having cold start issues. if I don't let the pump prime before starting it sometimes takes 2 turns for it to turn over. Could this be caused by the ITFP?
Thanks.
 Old 05-08-2012, 10:19 PM   #70
708
Erich's Avatar
Posts: 4,274   (View Stats)
You do not need to swap out valve, you need to tune your fuel pressure. If you are getting cut, you are getting way over 2074. Are you requesting over 2070? That is when the real problems start.
Edit to add: Just saw your other thread.
2 years after hitting 700hp and still running strong. Happy to see others joining the club.
Erich is offline   Reply With Quote
 Old 05-09-2012, 07:15 AM   #71
I'm only targeting 1750psi, but with the rv and Autotech combined, I'm hitting above fuel pressure sensor level.
 Old 05-11-2012, 03:56 PM   #72
Some other interesting observations I've made since I've had plenty of fuel psi now:
I used to get the CELs p0101 and p0245 very frequently but not since I put the new internals in.
I would experience what felt like spark blowout a lot while going wot and quite a bit of afterfires when shifting but not anymore.
Boost is dropping ... Help! apawk MazdaSpeed 3/6 - ECU Computer Tuning 18 10-03-2011 08:49 AM
Question about dropping on sum H&R's boosted_out 2010 MS3 - Suspension & Brakes 9 08-12-2011 03:05 PM
Dropping fuel pres. but AFRs ok?? ElBartoRex MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 11 01-28-2010 08:40 AM
10 reasons why auto sales are dropping (besides the economy and fuel prices) Haltech Automotive News 0 08-14-2008 05:50 PM
Page generated in 0.51780 seconds with 32 queries
