 Old 12-21-2010, 09:53 PM   #81
SSinstaller's Avatar
Posts: 3,984   (View Stats)
Groans: 60
I'm just gonna throw this out there, and maybe it's rubbish, but if the SB ground is different that the ECU's ground or even the sensor's ground, you can get different voltages (much like the crank pos sensor issue chris).
But it certainly seems like the sensor reads quite a bit over 4.5V.. which is a good thing. I'd just like to verify it.
I'm sure all the SB's measurements are a bit skewed, but I doubt they're off by more that a few hundredths of a volt... It would cause some serious issues if it was much worse than that..
Honestly, I'm more concerned with finding out where the sensor pegs than the actual pressure it represents.. I just want to make sure that whatever RV I end up with is set right about where the sensor pegs..
Also, my SB and the Aux Box are grounded directly to the main ECM ground bundle.. I have not had the MIL for the crank position sensor since I moved it to the ECM gound...
The Following 3 Users Say Thank You to SSinstaller For This Useful Post:
djuosnteisn (12-21-2010), FreeFlyFreak (12-21-2010), NJSPEED3 (12-21-2010)
 Old 12-21-2010, 10:03 PM   #82
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Yup. But that doesn't mean other people's SB's are. So your logs are probably a bit more accurate than other's right now. A few hundredths would be quite a bit of pressure on this sensor, possibly the differences we're seeing between AP and sb.... but who knows.
I've been clicking that datahseet in OP for like an hour and it won't fucking load. I only had a chance to glimpse it at work and now i can't get it... grrrrr.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 12-21-2010, 10:15 PM   #83
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Any chance you can get me some pics of how you did this please?
The Following 3 Users Say Thank You to NJSPEED3 For This Useful Post:
11cruzito11 (12-21-2010), djuosnteisn (12-21-2010), MarkyMark (12-22-2010)
 Old 12-21-2010, 10:42 PM   #84
Most sensors can "read" outside the specified ranges. However near the top and bottom of those ranges their linearity starts to suffer as does their accuracy and this is why the spec calls for a range as well as a particular resolution that is maintained over that range.
06Speed6 (12-21-2010), FreeFlyFreak (12-21-2010)
 Old 12-21-2010, 10:50 PM   #85
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
That is true Lex, if the data sheet spec is 4.7v, we should try to keep our working pressure under that mark. This is really going to be critical if we are pushing the pressure limits of the injectors.
2006 Mazdaspeed 6
 Old 12-22-2010, 08:41 AM   #86
Groans: 60
Here is the MS3 diagram.
Pins 1AZ 1BB 1BG 1BC 1BH are the ECM grounds.. All you need to do is trace them back into the harness until you get to the junction, and ground your SB there...
 Old 12-22-2010, 09:03 AM   #87
bnoon's Avatar
Posts: 1,770   (View Stats)
Originally Posted by forcedinduktion View Post
anyone else feel stupid reading this ?
Yeah, this is one of those moments where I'm happy I'm not on the bleeding edge. I get the jist of it as they're trying to increase the resolution of the sensor within a set working voltage range. I'm an electronics/network engineer and some of it still sounds like the parents/teachers on a Peanuts cartoon. WAwa wah wah wa wa... Yes ma'am, I know ma'am...
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
bnoon is offline   Reply With Quote
 Old 12-22-2010, 09:30 AM   #88
Captain
Groans: 79
Okay, so i can open the datasheet at work.
The sensor is a wheatstone bridge... basically 2 voltage dividers, one with a variable resistor that changes with pressure. The difference voltage (usually less than 20mV) is amplified through some op amp gain stages and conditioned a bit i bet. That's why there's a pull up resistor on the signal line.
The amplification stages (op amps) run off the supply voltage, 5V according to the datasheet. And their maximum output is dependent solely on the supply voltage. There are two main types of single supply op amps, one's that can swing to only the low rail (ground) and about 1 diode drop below the high rail (like 4.5V), and then there are some that can swing completely to both rails. IIRC the ones that need to be able to sink an appreciable amount of current (like this one if they're saying you can use up to 16V as a pull up on the open collector output) usually don't swing all the way to the high rail, but i could be wrong. I'd have to check my electronics book at home.
Usually they will just flat line at a certain level.
Marcus... is the over drive part of the datasheet your talking about in the technical data section? Where it says, " Max. overpressure = 180 bar"? Cause in my mind that means the max amount of pressure the sensor can see before it becomes damaged or un calibrated. The other pressure is "Rupture pressure = 300 bar", which i interpret as physical rupture of the device.
On the characteristic curve graph... it does show the dotted line to 4.8V, and translates to upper area for signal range... but i'm not sure if this is evidence enough to say it'll read that high.
I'd like to see some SB logs with some readings over 4.5 V.
Also, judging from the way the AP will just clip the reported pressure, makes me think there is a hard voltage limit to the out put of these sensors.
I think the easiest thing to do at this time is just pick up the higher reading sensor, and put our energy into correlating some voltages to pressures between the two.
I mechanical tester jig would still be very useful for this... *cough* scott *cough*.
www.permtuning.com
The Following 8 Users Say Thank You to djuosnteisn For This Useful Post:
Erich (12-22-2010), FreeFlyFreak (12-22-2010), jracer (01-12-2011), Lex (12-22-2010), MarkyMark (12-22-2010), NJSPEED3 (12-22-2010), SilverDemon (12-22-2010), xcoldricex (12-22-2010)
 Old 12-22-2010, 01:39 PM   #89
Groans: 60
Wow.. Should have kept my mouth shut. I just got the crank position MIL for the first time in months...
I guess it's still better than seeing it every other day..
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
djuosnteisn (12-22-2010), NJSPEED3 (12-23-2010)
 Old 12-22-2010, 01:41 PM   #90
Captain
Groans: 79
Hahahahahaha, shit... tempted the god's.
www.permtuning.com
 Old 12-22-2010, 01:52 PM   #91
Groans: 60
Ok, Rob(the_caruch) just sent me his log that he took that 2274psi screen shot from...
The max FP sensor output he hits is 4.85v (SB says that's 2274psi-but we know it's not that high), so even if it's off by .05v we know the sensor is good to at least 2219psi..
Yep, and my appt to get my safety inspection is at 11:30 tomorrow morning...
I have enough time to clear it and complete the readiness monitors before then... Thankfully I can still pass in NC with the crazy EVAP monitor incomplete...
djuosnteisn (12-22-2010), Erich (12-22-2010), the_caruch (02-14-2011)
 Old 12-22-2010, 03:05 PM   #92
If anyone has a spare sensor taking it apart is not too tough. There is a pressure transducer in the tip (variable resistor essentially) and a potted PCB inside the casing.
In heavy duty applications all sensors must be able to take above battery voltage even if they are rated for 5V and not break. This is a safety and reliability requirement and I am not sure if the same one exists in passenger vehicles. It seems that it may be the case.
Edit: Here is what it likely looks like inside. The diamond like resistor setup is the wheatstone bridge.
Edit 2: Better diagram.
 Old 12-22-2010, 03:19 PM   #93
On the other hand, the effort is probably better spent at adapting a new sensor and translating the voltage/pressure curves correctly to the control system so it can make use of them.
 Old 12-22-2010, 03:29 PM   #94
Captain
Groans: 79
Here's a screen shot from that log:
Looks good to me.
www.permtuning.com
 Old 02-05-2011, 09:56 AM   #95
Burn69's Avatar
Posts: 143   (View Stats)
Burn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to behold
Groaned at 7 Times in 4 Posts
Nice
2012 Speed3 w/ Tech. / SURE Full3 Aeros & TIP Combo / SURE Shortcut w/ Counterweight / SURE TorqR3 RMM / SURE AGS Shift Knob / COBB AP Programmer / CNT CBE Blue Tip / UR Test Pipe / RallyArmor Flaps / SPC Rear Camber Arms / MORE (coming soon).....
Burn69 is offline   Reply With Quote
The Following 3 Users Say NO Thank You to Burn69 For This Un-useful Post:
FreeFlyFreak (02-05-2011), m4tic (02-05-2011), the_caruch (02-14-2011)
 Old 02-14-2011, 09:42 AM   #96
the_caruch's Avatar
Posts: 698   (View Stats)
the_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the world
Did you guys want me to turn up the fuel psi in my Standback tune even more? Attached is my fuel psi table. I can bump those to -20 to see what voltage i get if it helps anyone out.
cp-e CAI, cp-e Turbo Inlet, cp-e catted DP, cp-e HPFP, cp-e flashes, cp-e Standback w/PNP, cp-e FMIC, TRZ RMM, TS Compact BOV (full re-circ), DDM 55W 6k HID's, Cobb RSB. HKS Hi-Power Exhaust, OCC
the_caruch is offline   Reply With Quote
 Old 02-14-2011, 12:32 PM   #97
Groans: 60
You could try, but I'd watch the realtime graphs very closely..
I wouldn't add more than 1% at at time.
If you ever see the pressure flatline, let off asap, and remove pressure until you can make a full pull without the pressure flat-lining...
I don't think you have much sensor range left, and once your adjustment pegs the sensor the FP will just keep climbing until the injectors quit firing or something breaks..
djuosnteisn (02-14-2011), Erich (02-14-2011), the_caruch (02-14-2011)
 Old 02-14-2011, 12:53 PM   #98
the_caruch's Avatar
Ok cool, i'll give this a try when i can and keep a close eye on my realtime graphs
The Following 2 Users Say Thank You to the_caruch For This Useful Post:
djuosnteisn (02-14-2011), SSinstaller (02-14-2011)
 Old 02-14-2011, 03:47 PM   #99
708
Erich's Avatar
Posts: 4,274   (View Stats)
Your car will probably let you know before the realtime graphs do (was the case for me) but a good idea to watch them none the less.
Erich is offline   Reply With Quote
The Following User Says Thank You to Erich For This Useful Post:
 Old 02-14-2011, 04:22 PM   #100
Captain
Groans: 79
Any news on your front erich? Valve still working? What pressure are you running and have you done anything about a sensor?
www.permtuning.com
 Old 02-14-2011, 04:56 PM   #101
708
Erich's Avatar
Never found a solution I liked for logging an extra higher pressure sensor. Still looking, but not real confident in getting something together before the new motor goes in.
Valve still works, though I only see 2073 in my logs on throttle off now. Have it now so I am running consistently in 2020 to 2040 range with the AFR's where they should be.
 Old 02-14-2011, 10:07 PM   #102
Groans: 60
Are you logging with the SB or the AP?
I should have a valve on the way with a ~2300psi crack pressure, so hopefully the SB will let us know the OEM sensors max Vout...
If we have enough range for the full 2300psi, I don't think we'll need an upgraded sensor... It may just be an ECM limitation for the AP, and I'm sure Cobb can get fixed if there is enough interest/need...
djuosnteisn (02-16-2011)
 Old 02-14-2011, 10:17 PM   #103
708
Erich's Avatar
AP, so limited to the 2073 the ECU provides.
 Old 03-30-2011, 05:09 PM   #104
seshomaru7's Avatar
Posts: 182   (View Stats)
seshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to all
Groaned at 13 Times in 7 Posts
Probably bringing up an old thread but just asking if anyone has upgraded the HPFP then the safety relief valve to up fuel pressure to maybe 1900-2000 without problems? It would seem like the upgrades of the fuel rail/line and injector seals wouldn't be necessary at that pressure and I would only like to be able to maintain these pressures at WOT, instead of upping the pressures even more.
seshomaru7 is offline   Reply With Quote
 Old 03-30-2011, 05:12 PM   #105
Captain
Groans: 79
seals would still be necessary... that's a function of cylinder pressure, not fuel rail pressure.
You can control where the higher pressures occur (at wot) with either of the popular tuning methods.
www.permtuning.com
 Old 08-16-2011, 10:24 AM   #106
just updating this thread with some relevant info.
i just purchased my sensor today from here
All European
Mercedes PN is in the OP or u can use the Bosch PN. make sure you tell them you saw it online to get the $122 price.
i ordered the harness from here. it was free because you can ask to view "samples" of the products.
www.te.com
i also found the connector for the stock harness so you can make this 100% PNP. now im not sure this is the right connector but it looks to be correct. ill update this post when i actually get it. (note the first 3 parts in the list are put together in a "kit" which is what the last item is.) UPDATE: THIS CONNECTOR WILL FIT THE STOCK HARNESS
The Following 10 Users Say Thank You to superskaterxes For This Useful Post:
06Speed6 (08-17-2011), bnoon (08-16-2011), djuosnteisn (08-16-2011), Erich (08-16-2011), FreeFlyFreak (08-16-2011), m4tic (08-16-2011), MarkyMark (08-16-2011), NJSPEED3 (08-17-2011), rudydecc (08-16-2011), SSinstaller (08-16-2011)
 Old 08-16-2011, 01:42 PM   #107
m4tic's Avatar
Posts: 4,925   (View Stats)
i feel like i stole something
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
The Following 3 Users Say Thank You to m4tic For This Useful Post:
06Speed6 (08-17-2011), djuosnteisn (08-16-2011), wolly6973 (08-17-2011)
 Old 08-16-2011, 01:59 PM   #108
Captain
Groans: 79
Tyco is used to that feeling.
www.permtuning.com
 Old 08-16-2011, 02:44 PM   #109
Groans: 60
I'm sure they're going to catch on when 50 people sign up and request a free sample of that one plug...
 Old 08-16-2011, 03:10 PM   #110
rudydecc's Avatar
Posts: 113   (View Stats)
rudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud of
If you buy them its $3.91 worth of parts w/o shipping.
I like the quantities for the sites that you can buy from, they go by the 1000s. lol. yeah, I need 1 lol.
2008 Mazdaspeed3 GT ::COBB STS/Turbo Inlet/AP/SW/BPV, Fujita F5 CAI, CP-E RMM/DP/CBE/FMIC, TWM Shifter Bushings/JBR Side Mounts::
2019 Audi Q7
rudydecc is offline   Reply With Quote
 Old 08-16-2011, 03:22 PM   #111
708
Erich's Avatar
I ordered mine on official Vanderlay Industries business.
The Following 3 Users Say Thank You to Erich For This Useful Post:
Dano (08-18-2011), FreeFlyFreak (08-16-2011), wolly6973 (08-17-2011)
 Old 08-16-2011, 03:27 PM   #112
glad i got mine haha.
btw they ask you for the project your using them for and application, ect.
i put upgraded bosch FP sensor testing haha
P.S. dont go order all this shit cause its free when we havent even tested the sensor yet!!!!
Dano (08-18-2011), SSinstaller (08-16-2011), wolly6973 (08-17-2011)
 Old 08-16-2011, 04:06 PM   #113
Groans: 60
I'm taking a break form being the guinea pig, it's too expensive...lol
The Following 7 Users Say Thank You to SSinstaller For This Useful Post:
06Speed6 (08-17-2011), Dano (08-18-2011), djuosnteisn (08-16-2011), NJSPEED3 (08-17-2011), superskaterxes (08-16-2011), wolly6973 (08-17-2011), xcoldricex (08-18-2011)
 Old 08-17-2011, 04:01 AM   #114
Speeeeeed
06Speed6's Avatar
I bought the crimp tool for those connectors for another project, its like $140 lol. Making custom connectors gets expensive quick. I have like 4 of those crimp tools now.
@superskaterxes I spy 247 phail!
2006 Mazdaspeed 6
 Old 08-17-2011, 05:31 AM   #115
lol hey! its good for FS thread trolling. dustin picked up a rail, 4 injectors, RV, stock pressure sensor, and harness for 75 shipped haha
djuosnteisn (08-18-2011)
 Old 08-17-2011, 02:34 PM   #116
Speeeeeed
06Speed6's Avatar
Yeah that was some phail too, he sent his pm like 10mins before I did =P
2006 Mazdaspeed 6
superskaterxes (08-17-2011)
 Old 08-18-2011, 04:35 PM   #117
Captain
Groans: 79
www.permtuning.com
 Old 08-18-2011, 04:50 PM   #118
Posts: 9,484   (View Stats)
great job there Costanza
 Old 08-18-2011, 05:53 PM   #119
708
Erich's Avatar
Hey, that's T-Bone to you.
 Old 08-18-2011, 06:24 PM   #120
Eth Fiend
phate's Avatar
Posts: 6,945   (View Stats)
I need more pressure
Subbed.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f303/fuel-rail-high-pressure-sensor-upgrade-67643/
0265005303 - Virgilio Ricerca Web This thread Refback 10-18-2011 07:58 AM
High Pressure Relief Valve Option SilverDemon MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 161 04-29-2011 08:10 PM
Opinion On High RPM High Pressure Fuel Pump Spring ms3brendan MazdaSpeed 3 - Engine, Transmission & Driveline 1 07-13-2010 01:04 PM
Removing Fuel Rail...and where is the DI psi sensor located? AFcadet MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 3 11-18-2009 04:48 PM
Page generated in 0.88426 seconds with 35 queries
