 Old 10-08-2017, 06:26 PM   #1
Speeden6's Avatar
Posts: 598   (View Stats)
Speeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the world
Groaned at 23 Times in 12 Posts
Default Fuel System Problem
ok, 07 MS6 and a bit ago it started to run strange. when monitoring with my App at just ignition on it would read HPFP around 67 - 80. when at idle I would be at around 200 - 800. WOT it would only go to maybe 1200 - 1500 steady.
I have had the car parked for a while and just tore into it today. I have the Corksport iternals and pulled them out and the fuel pump looks good, internals have no damage on them.
I was told to check out the high pressure relief valve so I picked one up used. I pulled mine out and when comparing it to the used one I picked up the used one when I put my lips on the fuel line in end and blow I cant get anything to pass through. On the one I took off my car when I put my lips on the same end and blow you get some air passing through.
Is the one that was on my car bad cause it freely passes air, or the used one bad cause it is clogged? what else could be the problem?
Thanks.
2007 MS6 -
CPE TMIC, CS HPFP Internals, CS Stage 2 Intake and Inlet, Turbo Smart 50/50 BPV / BOV, Catless DP
2006 Acura TL Fully bolted and Running Nitrous! 330WHP SOLD
SOLD 1992 Corrado VR6
268 Cams, air intake, cat back, upgrade plugs and wires, coilovers.
SOLD
2001 Audi Allroad
SOLD
2006 MS6 -
CAI, TIP, ETS TMIC, AutoTech Internals, TBE catless, E85 30%,
19PSI, Cobb AP, RMM, K04, HKS SSQ4 VTA,
TUNED BY LEX FOR 330 AWHP / 380 TQ
Custom tune by
The habits we form today are the ones that Define us tomorrow
Speeden6 is offline   Reply With Quote
Bose sound system problem (Gen 2) jpminem MazdaSpeed 3/6 - Car Audio & Electronics 14 03-09-2017 02:54 PM
Nav System Problem marco427 Gen2 MS3 General Discussion 2 06-18-2014 07:39 PM
Problem after problem: Running rich & Fuel cuts wherewuat 2010 MS3 - Troubleshoot/Diagnostics 30 01-30-2014 01:13 PM
Unknown boost system problem EmPeEs6 MazdaSpeed 3/6 - ECU Computer Tuning 9 06-27-2013 01:35 AM
other cars that share our fuel system (specifically fuel rail) TWOptSL0W MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 05-12-2012 08:13 AM
Page generated in 0.22444 seconds with 20 queries
