 Old 04-05-2016, 11:11 AM   #1
Cdnspeed6's Avatar
Posts: 139   (View Stats)
Cdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond repute
Groaned at 4 Times in 2 Posts
Default Heads up Aem water/meth Failsafe gauge
Just a heads up to anyone that purchases this kit and the gauge doesn't work.
I Found that 2 wires from the factory were switched on the sensor connector, I was chasing my tail till i double checked all the wiring.
Should be
|Br|Y|Bl|
Cdnspeed6 is offline   Reply With Quote
 Old 04-05-2016, 12:04 PM   #2
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Their flow sensors are garbage; they don't hold up. If you want any chance of the flow sensor to survive, I would put it on the inlet side of the pump. My sensors were always on the outlet side of the pump, and they didn't hold up.
I gave up on that piece of shit system a while ago after 4 sensors failed months apart from each other.
MINI H1 6.0 - CAR LED TAILS
 Old 04-05-2016, 12:20 PM   #3
broda's Avatar
Posts: 375   (View Stats)
broda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the world
I've heard it's just better to go the route of getting the AFR Failsafe instead so it fuel cuts if it gets too lean.
broda is offline   Reply With Quote
 Old 04-05-2016, 12:22 PM   #4
Unless you are spraying a shit ton of methanol, it isn't going to hit the AFRs enough to trigger.
 Old 04-05-2016, 01:05 PM   #5
Cdnspeed6's Avatar
No way! ugh Fml, I do have mine on the inlet side of the pump, I suppose I'll try it for abit till it dies. I wish there was an Alternative to this failsafe.
as soon as its warm enough out im going to wire in a relay to drop the Boost solenoid as my safety, at least it'll drop to wastegate pressure
2007 Speed6- Cp-e RMM, M2 Downpipe, BNRS3V2, HKS SSQV
CS FMIC, CS TIP, CS SRI, CS HPFP, H&R coilovers
The Following User Says Thank You to Cdnspeed6 For This Useful Post:
dale_gribble (04-05-2016)
need help with AEM failsafe water/meth system please HOCKEYNUBE 2010 MS3 - Fuel, Nitrous & Water Injection 3 05-01-2014 11:10 AM
COMPARISON: Labonte Stage 2 Water/Meth Kit vs. AEM Water/Meth Kit The Great NY Mazdaspeed Forums User Reviews 2 01-19-2013 08:48 AM
Page generated in 0.25729 seconds with 22 queries
