Like Tree2Likes
 Old 05-03-2014, 02:54 PM   #41
frankc730's Avatar
Posts: 115   (View Stats)
frankc730 will become famous soon enough
Groaned at 9 Times in 5 Posts
well it dies ik that pressure is fine but it was low like 175 i think
frankc730 is offline   Reply With Quote
 Old 05-03-2014, 02:56 PM   #42
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
Dizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the world
Did you prime the car at all first? Does it idle fine until you give it gas or what? Your being a tad vague
Sent from my HTC One using Tapatalk
Dizzy Turbo is offline   Reply With Quote
 Old 05-03-2014, 03:01 PM   #43
evilmonkey187's Avatar
Posts: 294   (View Stats)
evilmonkey187 is the leader of the worldevilmonkey187 is the leader of the worldevilmonkey187 is the leader of the worldevilmonkey187 is the leader of the worldevilmonkey187 is the leader of the worldevilmonkey187 is the leader of the worldevilmonkey187 is the leader of the worldevilmonkey187 is the leader of the worldevilmonkey187 is the leader of the worldevilmonkey187 is the leader of the worldevilmonkey187 is the leader of the world
Did u remember to tighten the hard line at the bottom of the hpfp? Does the engine compartment smell like gas? Did you take the spring apart or push on the keepers of the spring when you examined the internals? I don't think you damaged the bore of the cam lobe housing but if you did it's possible it's stuck
Originally Posted by gingermike View Post
ugh. there's so much fail going on here I don't know what to address first. Have you checked for any leaks on the hard line? did you make sure the cam bucket went in properly?
Last edited by evilmonkey187; 05-03-2014 at 03:01 PM. Reason: MSF Database - Automerged Doublepost
evilmonkey187 is offline   Reply With Quote
 Old 05-03-2014, 03:08 PM   #44
frankc730's Avatar
the cam bucket went in fine it sat in perfectly i started the car with my AP plugged in and my pressure was 75-100 so I'm guessing the hpfp isn't even working. and yes all the lines are on it went back in smoothly after i got the cam bucket out cleaned it and re installed also cleaned and lubed internals like i read on cork sport so idk it seems like the pump isn't working at all could i have fried a relay or fuse or something
 Old 05-03-2014, 03:11 PM   #45
Did u turn the key on and of 10 times b4 starting?
To prime
 Old 05-03-2014, 03:15 PM   #46
frankc730's Avatar
yes everything is tightened. i primed the hpfp. i just took the back part of the piston idk what its called its the cylinder and then slide the piston out checked it, cleaned it, lubed it. put it all back together. if it wasn't cleaned good enough would it be running like this.
didn't do it 10 times did it about 5
there is no smell of gas in the engine compartment either
Last edited by frankc730; 05-03-2014 at 03:15 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-03-2014, 03:21 PM   #47
So u loosened the hard line, removed the 3 bolts, took off the hpfp, didn't touch the spring at all, removed the bucket(piston) got it stuck, lubed it, and put it all back together and now no fuel pressure? Check that all the electrical plugs are connected
 Old 05-03-2014, 03:23 PM   #48
frankc730's Avatar
basically i took the internals apart only because i thought that that was binding me up trying to reinstall not knowing the cam bucket was stuck.
 Old 05-03-2014, 03:31 PM   #49
I'm gonna say that you installed something wrong when you reinstalled the internals. Take it apart again. Make sure everything is installed correctly.(it is possible that the large ring with the little hole in it is upside down) and put it back together.
And donate for fucks sake, there are a shit ton of walk thru's for this procedure
The Following User Says Thank You to evilmonkey187 For This Useful Post:
Dizzy Turbo (05-03-2014)
 Old 05-03-2014, 03:42 PM   #50
frankc730's Avatar
is the little ring with the hole in the side of it is the hole supposed to be seen. i thought it was supposed to be at the bottom as in towards the spring get what I'm saying ?
that cylinder can only go in one way for the internals to fully screw back in
Last edited by frankc730; 05-03-2014 at 03:42 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-03-2014, 03:57 PM   #51
Like this
 Old 05-03-2014, 04:06 PM   #52
frankc730's Avatar
if i did put it in backwards could i have done damage to anything
 Old 05-03-2014, 04:15 PM   #53
It depends, I don't think you did, there would have been some major wonky noises. The worst ( I think) would be that the spring was depressed to much because of the backwards part.
 Old 05-03-2014, 05:29 PM   #54
frankc730's Avatar
I got it guys the internals weren't tight at all so I'm guessing that's what it was idk shittin thing is I gotta do this all over again. But I wanna thank all of you u guys know ur shit
 Old 05-03-2014, 05:57 PM   #55
glad you got it worked out....when you put upgraded internals in next time, you'll be doing it with a sammich in your left hand, while your right does all the work lol
good thing you donated and went vip.... now you have access to everything you need
 Old 05-03-2014, 06:38 PM   #56
frankc730's Avatar
the second time i had it in and out in and cleaned and back in in like 30 min. and I've been meaning to go vip a while. man have i been mission out
 Old 05-03-2014, 06:52 PM   #57
frankc730's Avatar
should i worry about the scoring on this ?
 Old 05-03-2014, 07:00 PM   #58
jme
jme's Avatar
Posts: 39   (View Stats)
jme is a jewel in the roughjme is a jewel in the roughjme is a jewel in the roughjme is a jewel in the rough
you might have a fuel leak? I had a bitch of a time putting mine back in because the line was bent a little bit when we pulled it out.
BNR stage 4 turbo, Full race exhaust manifold, Mahle 2618 Forged Pistons, Darrell Cox vvt, Manley H-Tuff Rods, Clevite H-Series Main & Rod Bearings, SP63 Custom Age 625+ 10mm Head Studs, ARP main studs, Keyed Crankshaft, Pulley, & Sprockets, pioer stage 2 camshaft
Guardian Angle with 4 bar Corksport 3" TBE, HPFP, 3.5" intake, Corksport FMIC, JMF Intake Manifold, Synapse DV, toyota fuel injector seals, Grimm speed EBC, RMM, Balanced Crank/Clutch/Flywheel, Balance shaft delete, James Barone Oil pan Baffle, South Bend stage 4 Extreme clutch kit, Injecting yummy METH "CM10"!
jme is offline   Reply With Quote
 Old 05-03-2014, 07:12 PM   #59
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Can you feel it with your fingernail? If so.... get some new ones. My 2¢
The Following User Says Thank You to pzr2874 For This Useful Post:
 Old 05-03-2014, 07:23 PM   #60
ms3steeez's Avatar
Posts: 312   (View Stats)
ms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the world
Must be the weather, everyone was apparently in a great mood today lol
Sent from my VS980 4G using Tapatalk
pzr2874 likes this.
FreekTuned GT3076R, M2 catless DP, CS HPFP internals, Custom 3.5" intake, Custom 51R battery box, Grimmspeed 3 port EBCS, CS shifter bushings, RA mudflaps, TurboXS core w/ custom piping, Devils Own 100% meth injection, JBR 88 RMM, Denso ITV22, CPE Safeseals, JBR EGR delete, Forge V1, Hawk HPS pads, VCTS Delete, 3 bar map sensor, kozmic primary EGR delete (391 whp on Vdyno, ZZB 12-17-14)
Build in progress
.020 over block, pinned and keyed, wiseco pistons, manley H beams, SP63 head w/ intake and exhaust ports, and mild bowl work. DM TB spacer, L19 studs, XSpower V1 mani, CNT catback, ACT 6 puck w/ streetlight flywheel, CS injector seals, Clevite main and King rod bearings, redefined performance PCV plate, PTP oil pan baffle w/ JBR BSD, 4 bar map sensor
ms3steeez is offline   Reply With Quote
 Old 05-03-2014, 08:01 PM   #61
I second this gentleman
HPFP are back in stock and ready to ship www.cp-e.com Custom Performance Engineering (cp-e.com) 0 07-26-2012 07:38 AM
Autotech HPFP Back in stock!!! @ CTS Turbo! CTS Turbo 2010 MS3 - Turbo Induction 18 04-24-2012 07:06 PM
HPFP Internals...Back Orders VRMSPD6 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 28 03-03-2011 04:05 PM
Page generated in 0.37824 seconds with 26 queries
