 Old 01-25-2017, 06:01 PM   #1
derek13p's Avatar
Posts: 1,194   (View Stats)
derek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the world
Groans: 38
Default Help! Lean/sputtering while cruising
Have a speed6 with the SP63 port injection fuel kit, have been on 50/50 mix of e85 for 2 years now or so.
So the story goes that for quite a while I was driving around with a—small boost leak I couldn't locate but the car was great at idle and partial throttle, just not under heavy boost. Finally found the leak, the frame had rubbed a hole in the charge pipe—under the passenger headlight.—Got that welded up and what not and the car felt great again, till a few days later I went—WOT on the freeway and my fucking port injection fuel rail popped off on the last injector cause one of the screws on the rail backed out due to all the vibrations.. got the rail back on but after that I was having problems with the car going lean at WOT then cutting out.—Car was still great under partial—throttle and idle and just cruising, just not WOT.—A few days—ago I took the in tank fuel pumps out of the car—and the filters were filthy so I cleaned them and thought that would be great.—Well now the car goes lean at partial throttle and likes to pull power and I don't even—trust it to get me to work.—
just last night I—took—everything apart, FPR, ITFP, HPFP, Port injectors, Spill valve,—relief valve, and cleaned them all with Sea Foam.
still having issues with it wanting to lean out a bit at partial throttle and partial boost.
I attached a few logs to see if anyone has some—insight into this issue.
Oh, and the Fuel Pressure Regulator will not go under 60 PSI at idle... swapped it out for another AEM FPR and that—one (brand new) wouldn't go under 80 PSI at idle...
Maybe the pumps are taking a shit??
06 MS6 & 06 MS6
The beauty is the beast
Daily driven
derek13p is offline   Reply With Quote
 Old 01-26-2017, 06:21 PM   #2
sheston's Avatar
Posts: 1,847   (View Stats)
I only looked at the first couple logs. It would be easier to trouble shoot with you having a WOT log. My guess is you still have a leak. Fuel trims are way off. Either that or you need a MAF cal badly. If you don't have a leak, clean your MAF with the correct cleaner and try that.
I believe the intank fuel pump only puts out around 60 to 80 psi. The HPFP should put out ~ 400 psi at idle. If you are not getting that something is wrong.
 Old 01-26-2017, 07:17 PM   #3
Fstrnyou's Avatar
Posts: 2,457   (View Stats)
Derek----- With over-1100 posts, surely you-know what your fuel-pressure should be. -----
Unless you run only on port injection. Then 60-80 psi is probably fine.
Try using less hyphens.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 01-27-2017, 05:54 AM   #4
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
A fuel pressure regulator is placed in line before the high pressure pump. It should only see 60psi or so of pressure there. PI injectors don't run at high pressure.
OP, what fuel pump setup are you running? Dual pumps or no? Have you checked all of the wiring for the injectors and SS controller? Rail popping off could cause some wiring issues depending on if it pulled or nicked any wires.
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
 Old 01-27-2017, 02:24 PM   #5
derek13p's Avatar
Groans: 38
I'll try cleaning the maf but it was fine before the fuel rail popped off. And with the maf Cal, nothing has changed with the I take size so it shouldn't be an issue there.
I have 2 in tank dw300 pumps. Was originally set up at 40-45 psi so 60 at idle is high on the port injection side of things.
It's running lean even cruising around and I don't feel comfortable doing a wot log and potentially leaning it out and blowing it up. That and the port injectors shouldn't come in to play cruising around. Only after 3k rpm or so. So there shouldn't be a need to look at their wiring or ss box I wouldn't think.
06 MS6 & 06 MS6
Daily driven
 Old 01-12-2018, 11:49 AM   #6
RiceCarGuy248's Avatar
Posts: 9   (View Stats)
RiceCarGuy248 is a jewel in the roughRiceCarGuy248 is a jewel in the roughRiceCarGuy248 is a jewel in the rough
I'm having the same issue with my speed 6. I am running a 5 port devils own methanol kit. I have triple checked that I am getting meth to flow and have checked numerous times for boost leaks, still no solution.
RiceCarGuy248 is offline   Reply With Quote
Sputtering at WOT Mangster6302 MazdaSpeed 3 - Engine, Transmission & Driveline 11 10-22-2015 05:19 AM
Bad sputtering. HELP koston33 MazdaSpeed 3/6 - ECU Computer Tuning 50 12-08-2013 05:33 PM
08 ms3 sputtering under wot...please help Leccles MazdaSpeed 3/6 - Troubleshoot/Diagnostics 22 12-08-2010 07:41 AM
my ms3 is sputtering... please help vadichok MazdaSpeed 3/6 - Troubleshoot/Diagnostics 50 08-04-2010 07:35 PM
Dealers got lean; many plan to stay lean Haltech Automotive News 0 05-30-2010 09:10 PM
Page generated in 0.28445 seconds with 25 queries
