  • 1 Post By Fobio
 Old 03-09-2010, 09:36 PM   #1
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
Question Help with meth nozzle sizing
I bought a used custom single stage meth kit that comes with a Hago M1 nozzle:
http://www.icsindustrialservices.co....i%20nozzle.pdf
Can I get some advise on how to properly adjust it? I meant to just keep everything installed as is, since the system was set to spray at 8 psi, I was going to run a labonte progressive controller with it and forget about it...but the fact of running unknown amounts of meth doesn't sit well.
Thanks.
-- Mario Andretti --
 Old 03-09-2010, 09:56 PM   #2
speedms6's Avatar
Posts: 825   (View Stats)
i dont know about that kit, looks beat up, shoulda gotten a labonte or devils own, they seem to be preferred with a good track record
 Old 03-09-2010, 10:04 PM   #3
Driver
Fobio's Avatar
Groans: 44
it is dirty but otherwise performs fine...came off a perfectly fine car.
besides...I can always change a nozzle, and that is why I ask for the advise.
 Old 03-09-2010, 10:28 PM   #4
i would get a brand new nozzle from DO. they are like 20 bucks and your certainly gona need bigger then an M1
Fobio (03-10-2010)
 Old 04-01-2010, 01:13 PM   #5
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Actually, it looks like the DO 'External' nozzle should work - and it's only like $4.95 as opposed to the $20 for the 'Internal' nozzle...
 Old 04-01-2010, 01:21 PM   #6
An M3 nozzle is well suited for the stock turbo. Not a fan of that 90 degree elbow but if it works ...
 Old 04-01-2010, 01:22 PM   #7
Driver
Fobio's Avatar
Groans: 44
hmmm...I've already order a M5 nozzle already...I figure since DO shiped with DO3 and DO7, I figure I'd get something in the middle...
 Old 04-01-2010, 01:29 PM   #8
Is the kit progressive? The M5 is too large for the stock turbo. You need close to 20psi to make use of it at full blast - otherwise it just bogs down and you want to turn it on well below that 20psi mark.
I had an M5 on a progressive controller and moved down to an M3 since you get better atomization at higher pressures.
Dano (04-06-2010), Fobio (04-01-2010)
 Old 04-01-2010, 01:42 PM   #9
Driver
Fobio's Avatar
Groans: 44
currently, I still have that M1 on there with that custom kit that doesn't really respond...I'm planning on replacing all of the "controls" with a Labonte VC-25 progressive controller, but haven't gotten around to it yet....hopefully by next week after I get a new baseline and before pro-tune...
atvfreek likes this.
 Old 04-06-2010, 06:12 PM   #10
Posts: 9,484   (View Stats)
about to pull the trigger on a DO progressive kit so a M3 is what I need? Is the M3 the same as the DO3?
thanks
 Old 04-06-2010, 11:34 PM   #11
hnda etr's Avatar
Groans: 90
thanks
Not sure about M3 being the same as the D03 - but definitely get the stage 2 kit and start with the D03.... Depending on your mod level, you may want to go to the D05 - both come with the kit...
The Following User Says Thank You to hnda etr For This Useful Post:
Dano (04-07-2010)
 Old 04-06-2010, 11:42 PM   #12
Driver
Fobio's Avatar
Groans: 44
hope this helps with cross-referencing:
M1 - 1gph
M3 - 3gph
M5 - 5gph
and so forth...
 Old 04-06-2010, 11:48 PM   #13
hnda etr's Avatar
Groans: 90
M1 - 1gph
M3 - 3gph
M5 - 5gph
and so forth...
Yeah these match the D01 = 1gph, D03 = 3gph, etc from the DO site...
Looks like the M nozzle is DO's "inside mount" nozzles and the D0's are "outside mount" nozzles.
Nozzles
 Old 04-07-2010, 09:03 AM   #14
Running mods in sig with factory K04 so I'll start out with the DO3, run off my MAP and start at 10PSI up to 20.
does that sound about right?
thanks
 Old 04-07-2010, 09:24 AM   #15
If I run 11s AFR with meth spraying the car is happy.
If I run 10s AFR with meth spraying, I get misfires due to the richness of the mixture.
Pointless (06-18-2013)
 Old 04-07-2010, 09:55 AM   #16
a bit off topic here but if I currently target 11.8 AFR, when I run meth I assume I'll have to lean that target out?
Meaning if I change nothing I should see richer AFRs with the meth spraying?
 Old 04-07-2010, 09:57 AM   #17
depends what concentration of meth you run. with a mostly water mixture it wont affect AFRs much if at all.
Dano (04-07-2010)
 Old 04-07-2010, 10:11 AM   #18
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
DO's standard nozzles work both internal and external- have mine mounted internally
 Old 04-07-2010, 11:23 AM   #19
still researching ratios but what little I have read with my mods and a K04 50/50 will be too much meth so IDK yet. What do you run?
Edit: I want to retract this post LOL I am a noob and I am dumb...Just spent and hour reading meth threads....will be running at least 5050. Higher octane rating = better that lower EGTs
 Old 04-07-2010, 11:37 AM   #20
hnda etr's Avatar
Groans: 90
Yeah, but there's a huge price difference - the external mount nozzles are about $20 apiece and the internal mounts are $5.
The MS3 stage 2 kit comes with the D03 and D05 nozzles (external mounting) Dano.
Dano (04-07-2010)
 Old 06-06-2010, 07:16 AM   #21
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
I started with a M5, but have been running a M7 for probably 9 months.
McMaster-Carr
 Old 11-01-2012, 03:18 PM   #22
Driver
Fobio's Avatar
Groans: 44
Sorry to bump an old thread...but my boy, breakfasteatre was looking up meth nozzle sizes and he pointed out this little thread...
...and now look how far we have all came along, together and on our own. =)
@Lex
@Dano
@cld12pk2go
@superskaterxes
@breakfasteatre
The Following 2 Users Say Thank You to Fobio For This Useful Post:
breakfasteatre (11-01-2012), Dano (11-01-2012)
 Old 11-01-2012, 04:38 PM   #23
Eth/Meth Junkie
cld12pk2go's Avatar
I have been running a M10 nozzle (10 GPH at 100PSI) at 240 PSI for about a year now...
Fobio (11-01-2012)
 Old 11-01-2012, 04:40 PM   #24
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Yeah, you go back in time and major changes from 2011 forward. 2008-2010 looked as if we were doomed
The Following 3 Users Say Thank You to Haltech For This Useful Post:
atvfreek (11-01-2012), breakfasteatre (11-01-2012), Fobio (11-01-2012)
 Old 11-01-2012, 05:53 PM   #25
god that's funny...makes you not want to post anything for fear it will def be wrong info soon
lol at me only going to run 5050 hahahah god... still funny....
*takes a sip of meth out of coffee cup* ahhhh good stuff...and with a little E85 on top!
Fobio (11-01-2012), Pointless (06-18-2013), SLOWHATCH (11-01-2012)
 Old 11-01-2012, 08:04 PM   #26
the best is looking at old 6 club threads when people were logging FP and watching it drop and then doing ITFP upgrades to try and fix it hahahaha
and they thought it had to do with the cut (fuel/boost) as well lolol
BlueStreak (11-02-2012), Fobio (11-01-2012)
 Old 11-01-2012, 08:06 PM   #27
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Yup.. Or the one vendor who lied about a Walbro dropping into the tank and socks having to do a hack job to get it to work.
The Following 2 Users Say Thank You to Haltech For This Useful Post:
 Old 11-01-2012, 08:33 PM   #28
ahhh those were the days...I came in late... or in the middle of it all depending on how you look at it and god was this car hard to figure out. Load cap, CDFP internal failures left and right...a ZZB every other week it seemed....just a pure mess for sure. Now we have 450WHP cars on stock rods/pistons.
We've definitely come a long way in a fairly short time and MSF provided an awesome fountain of information exchange that propelled the platform forward.
This group is top notch.
The Following 5 Users Say Thank You to Dano For This Useful Post:
atvfreek (11-01-2012), BlueStreak (11-02-2012), cld12pk2go (11-02-2012), Fobio (11-01-2012), Rich990 (01-10-2013)
 Old 11-01-2012, 08:51 PM   #29
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Well the real fun was 2008-09.
Fobio (11-01-2012)
 Old 11-01-2012, 08:52 PM   #30
Matrix311's Avatar
Posts: 2,133   (View Stats)
Matrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the world
woot i'll be joining the 450whp hp club soon and yes this club and platform has come a long ways. I remember when i first started modding my 07 MS3 there was only CP-E and Cobb at the time and now we have a ton of options.
Sent from my Transformer TF101 using Tapatalk 2
Eric Schlaht - Arizona Phoenix Photographer
http://www.esimaging.net - http://www.facebook.com/esimaging
2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14**
**9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp
**11/19/13** Forged engine built and started up the car for the first time, success!
**3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno
**6/24/15** Sold the Mazdaspeed 3
**7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package
Matrix311 is offline   Reply With Quote
 Old 11-01-2012, 08:56 PM   #31
Driver
Fobio's Avatar
Groans: 44
It was the wild west for sure...
The Following User Says Thank You to Fobio For This Useful Post:
Check you Meth Nozzle o-rings!!!! bioevolve MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 01-31-2010 06:40 PM
sizing question FWD=WWD MazdaSpeed 3/6 - Wheels & Tires 10 05-13-2009 02:31 PM
ok to put meth nozzle rigth before bov whole? gsrtype1 MazdaSpeed 3/6 - Turbo Induction 41 11-10-2008 01:21 PM
FMIC Core Sizing question bykeryder4life MazdaSpeed 3/6 - Turbo Induction 2 09-17-2008 12:36 PM
Page generated in 0.48629 seconds with 29 queries
