 Old 12-02-2011, 03:42 PM   #1
fearturtle03's Avatar
Posts: 52   (View Stats)
fearturtle03 has a spectacular aura aboutfearturtle03 has a spectacular aura about
Default High DI Fuel PSI after CAI install
Had a CAI on my 06speed for awhile and my Fuel Pressure DI reading on my DH has always been around 1700 or so. Tonight I put on a SRI in place of the CAI, disconnected the negative terminal first, and started her back up. It seems the fuel pressure is going through the roof now, like around 3-4k at idle and up to 10,000 under throttle. Is this just part of the ECU re-learning process or is something jacked up? My AFR is still around the same as before and the STFT is about 3-4% under throttle. Any ideas?
Thanks
fearturtle03 is offline   Reply With Quote
 Old 12-02-2011, 03:44 PM   #2
did u change maps?
 Old 12-02-2011, 03:48 PM   #3
wankular's Avatar
Posts: 4,343   (View Stats)
Are you sure it's not reading in kiloPascals? A few times I reconnected my battery without unplugging the DH first and it started reading all temps in Celsius and fp in kiloPascals.
2009 MS3 sport MGM
The Following 2 Users Say Thank You to wankular For This Useful Post:
Scribbles (12-02-2011), whos_MS3 (02-07-2012)
 Old 12-02-2011, 03:51 PM   #4
Yeah BIG EDIT....I just went out and checked and I guess the DH defaults to metric...Switched to English and all is well...Add another reason I hate Europe and the stupid metric system. Cant people fall in line with the superpower?
Thanks Guys for the quick replies on me being an idiot.
 Old 12-02-2011, 03:53 PM   #5
Scribbles's Avatar
Posts: 861   (View Stats)
Scribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the world
damn, 5 mins too slow. This is what it is doing, change the settings back
Still cant get enough of your avy man
07 MS3
Built motor with K1 rods/wesico pistons, ATP 3076r, SS Mani, ATP DP, Cobb FMIC V2, CPE FP, TurboSmart MBC, TurboSmart Dual Port BOV, Hotchkis RSB FSB, BC Coilovers, AP, Dashhawk, Trilogy JBR 88 duro's, JBR catch can, Guardian Angel
Perm
Scribbles is offline   Reply With Quote
The Following User Says Thank You to Scribbles For This Useful Post:
wankular (12-02-2011)
High fuel trims at idle sdg_3mps MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 32 07-28-2012 07:51 AM
Opinion On High RPM High Pressure Fuel Pump Spring ms3brendan MazdaSpeed 3 - Engine, Transmission & Driveline 1 07-13-2010 01:04 PM
Low and High Fuel Pressures myspeedy07 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 11 10-03-2009 09:09 AM
Page generated in 0.25159 seconds with 23 queries
