 Old 10-16-2017, 03:12 AM   #1
Fonsi's Avatar
Posts: 236   (View Stats)
Fonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond repute
Default High pitched noise after replacing the injectors
Hi guys, we replaced the old injectors (150000km on it) on a Gen 1 with cleaned ones (including upgrade seals). After putting everything together, the car is making this constant, high pitched noise:
https://youtu.be/-A7S5W9GDp8
Is this some kind of injector, fuel, seal problem?
The car's battery is dead, you have to push start it. Dont know if it helps...
I told the guy to install a new battery though...
2012 Mazdaspeed 3
CS SRI, BNR S1, CS TMIC w/ Boost Tubes, GrimmSpeed EBCS, CS RMM, Stratified tuned, Cobb DP, 3" Catback, H&R coilovers, Tanabe strut & other parts
Fonsi is offline   Reply With Quote
 Old 10-16-2017, 08:05 AM   #2
Djohns's Avatar
Posts: 3,944   (View Stats)
Groans: 112
Wow no clue what that is but I would say replacing the battery is a good start.
2010 black mica speed3
Soon:built motor
 Old 10-16-2017, 11:19 PM   #3
Fonsi's Avatar
We replaced the battery, but there's still this freaking noise.
Can it be the fuel relief valve?
I dont know if its a mechanical noise (i.e. the relief valve or a bad injector seal) or an electronical noise (a bad capacitor or something like this).
2012 Mazdaspeed 3
 Old 10-17-2017, 02:51 AM   #4
Fonsi's Avatar
We made a second video, where you can hear the noise too:
https://youtu.be/OJOOGhAjn6U
If you pull the plug from the HPFP or the throttle body, the noise continues.
2012 Mazdaspeed 3
 Old 10-17-2017, 09:33 AM   #5
Djohns's Avatar
Groans: 112
That is seriously strange. I’m pretty much lost on this one. You can’t pinpoint where it’s coming from?
Soon:built motor
 Old 10-17-2017, 12:50 PM   #6
Fonsi's Avatar
Not really. Its somewhere in the hpfp, fuel rail, throttle body area.
I'm gonna check the relief valve the upcoming weekend.
2012 Mazdaspeed 3
 Old 10-19-2017, 05:30 AM   #7
Fonsi's Avatar
We logged the fuel rail pressure today:
In idle it is somewhere around 435 psi, in WOT somewhere around 1700 psi.
Seems like there is a leak somewhere. Im thinking of the injector seals or the egr block off (we deleted the whole egr pipe).
2012 Mazdaspeed 3
High Pitched Metal-On-Metal Noise Spid3r 2010 MS3 - Troubleshoot/Diagnostics 10 06-01-2016 04:21 PM
AP making a high pitched noise basspunk1001
Cobb Access Port/Maps
1 04-02-2013 10:32 PM
High pitched noise coming from shifter? mazdaspdmike MazdaSpeed 3 - Engine, Transmission & Driveline 0 05-17-2011 01:30 PM
high pitched noise JmkC MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 11-08-2009 07:02 PM
clunking and high pitched screetching MazdaspeedGT08 MazdaSpeed 3/6 - Suspension & Brakes 0 03-15-2009 12:52 PM
Page generated in 0.26402 seconds with 21 queries
