 Old 10-16-2017, 02:12 AM   #1
Fonsi's Avatar
Posts: 236   (View Stats)
Fonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond repute
Default High pitched noise after replacing the injectors
Hi guys, we replaced the old injectors (150000km on it) on a Gen 1 with cleaned ones (including upgrade seals). After putting everything together, the car is making this constant, high pitched noise:
https://youtu.be/-A7S5W9GDp8
Is this some kind of injector, fuel, seal problem?
The car's battery is dead, you have to push start it. Dont know if it helps...
I told the guy to install a new battery though...
2012 Mazdaspeed 3
CS SRI, BNR S1, CS TMIC w/ Boost Tubes, GrimmSpeed EBCS, CS RMM, Stratified tuned, Cobb DP, 3" Catback, H&R coilovers, Tanabe strut & other parts
Fonsi is offline   Reply With Quote
High Pitched Metal-On-Metal Noise Spid3r 2010 MS3 - Troubleshoot/Diagnostics 10 06-01-2016 03:21 PM
AP making a high pitched noise basspunk1001
Cobb Access Port/Maps
1 04-02-2013 09:32 PM
High pitched noise coming from shifter? mazdaspdmike MazdaSpeed 3 - Engine, Transmission & Driveline 0 05-17-2011 12:30 PM
high pitched noise JmkC MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 11-08-2009 06:02 PM
clunking and high pitched screetching MazdaspeedGT08 MazdaSpeed 3/6 - Suspension & Brakes 0 03-15-2009 11:52 AM
Page generated in 0.26531 seconds with 20 queries
