Like Tree4Likes
  • 4 Post By Pu Manchu
 Old 01-21-2018, 06:53 PM   #1
SpinalTap247's Avatar
Posts: 2   (View Stats)
SpinalTap247 is an unknown quantity at this point
Default hpfp internals
so im guessing my stock hpfp is going out cause im getting some loss of power an some hesitation when it comes to boost. i just got my ap v3 to get logs...but wondering if i can put an upgraded hpfp on a stock 08 speed3
Sent from my SM-N920T using Tapatalk
it would be safe yea
Last edited by SpinalTap247; 01-21-2018 at 06:53 PM. Reason: MSF Database - Automerged Doublepost
SpinalTap247 is offline   Reply With Quote
 Old 01-21-2018, 07:09 PM   #2
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,964   (View Stats)
Groans: 546
94 M
06 MS6
The Following 3 Users Say Thank You to Pu Manchu For This Useful Post:
sharksinspace (01-22-2018), Thor Hammer (01-22-2018), Vansquish (01-22-2018)
 Old 01-22-2018, 06:51 AM   #3
mituc's Avatar
Posts: 3,519   (View Stats)
Groans: 111
Get some logs and we will talk after.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 01-22-2018, 09:18 AM   #4
ok im installing ap v3 today
 Old 01-22-2018, 09:19 AM   #5
Thor Hammer's Avatar
Posts: 1,846   (View Stats)
Groans: 211
My friend, read your welcome PM. Search/ read up on HPFP and its importance, then take logs like Mituc said, and post here.
 Old 01-22-2018, 11:36 AM   #6
WAMBUSHHHH!'s Avatar
Posts: 1,598   (View Stats)
WAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the world
It's 2018, 5 years after the last production date on this platform, and we're still seeing threads pop up about HPFPs without logs or even an AP installed...
2013 LSM Mazdaspeed3 - stocked out and traded 6/5/2017
2017 LGM Golf R - South Bend stage 3 daily clutch / DFG intake / Wagner IC / AWE downpipe / Indvidia catback / APv3 Protune
2004 Yamaha R6 - Micron Ricer Pipe / PC
2005 Honda CBR 600 F4i - R.I.P. 10/29/13
WAMBUSHHHH! is offline   Reply With Quote
The Following User Says Thank You to WAMBUSHHHH! For This Useful Post:
Thor Hammer (01-23-2018)
Hpfp tick with pressure issues WITH HPFP INTERNALS Juschiln19 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 9 11-21-2016 08:47 AM
Name those HPFP Internals! Zoomer_Esiason MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 01-26-2016 03:33 PM
HPFP internals or new HPFP? JAGspeed6 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 11 11-26-2011 01:34 PM
Page generated in 0.28117 seconds with 25 queries
