 Old 10-19-2011, 01:31 PM   #1
Swagerwagon03's Avatar
Posts: 309   (View Stats)
Swagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the world
Question HPFP internals question
I bought a used HPFP internals, and they are sitting in a plastic baggy. I can not install them on my car yet and I want to know is it safe to leave them sitting in the baggy for a couple months, or should I add some oil in there to keep them lubed up??
08 MS3 GT
Swagerwagon03 is offline   Reply With Quote
 Old 10-19-2011, 01:37 PM   #2
YZF-R6's Avatar
Posts: 189   (View Stats)
YZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the world
I would coat them in some fresh motor oil to prevent surface rust from forming....
2010 MS3 Liquid Silver: TRZ Poly RMM, Cobb AP, PERM (Load-Based FTW), CP-E HPFP, SURE Aeros, HTP TIP, Corksport TMIC, SURE Boost Tubes, Magnaflow CBE, Corksport T/P, JBR LE Shift Knob & Weight, Redline MTL, Swift Spec-R, TSW Nurburgring 18x8.5, Nitto NT555 235/40/18.
If You Don't Like The Pu, Don't Play In The Pu.
YZF-R6 is offline   Reply With Quote
The Following User Says Thank You to YZF-R6 For This Useful Post:
Swagerwagon03 (10-20-2011)
 Old 10-19-2011, 02:08 PM   #3
Jake5713's Avatar
Posts: 1,775   (View Stats)
Oil
Why wait?
I am here: http://maps.google.com/maps?ll=44.731403,-93.212056
-Jake
Jake5713 is offline   Reply With Quote
The Following User Says Thank You to Jake5713 For This Useful Post:
 Old 10-20-2011, 11:06 AM   #4
Thank you kindly...@Jake5713 because I'm going to add on all the parts at once instead of one at a time....
08 MS3 GT
 Old 10-20-2011, 11:35 AM   #5
Jake5713's Avatar
gotcha!
 Old 10-20-2011, 12:24 PM   #6
wankular's Avatar
Posts: 4,343   (View Stats)
I can understand putting a bunch of parts on at once but if you have a leak or a CEL than you have to go back and check a bunch of things. Maybe I'm just a pessimist.
2009 MS3 sport MGM
 Old 10-20-2011, 01:19 PM   #7
speedtown's Avatar
Posts: 533   (View Stats)
speedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the world
^ I'm with you, put one part on make sure it's good then continue onto the next mod. If something gets fucked up you have to guess what it is that's causing it.
Plus that way you can keep the mod bug at bay but putting them over a period of time!
06 VRM MS6 - AP Stage 2 (Self Tuned to 18psi) - Forge BPV - PG SRI - PG TIP - Turboxs TP - ETS TMIC - TMW Stage1+JB SSP - CP-e RMM - PTP smokey turbo fix - Bnoon bolt - Prosport Boost Gauge in block8head vent pod
speedtown is offline   Reply With Quote
 Old 10-20-2011, 02:23 PM   #8
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
The internals are not relevant to installing anything else on your car, and they will not be easier to install while doing anything else... except maybe a TIP... just saying
TRADED : 07 MS3 GT Silver... fully bolted w/K04
CURRENT : 06 MS6 GT Silver....
KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6
 Old 10-20-2011, 03:06 PM   #9
its not that I'm waiting to put on all at once per say, just that I'm waiting for time to put them on, sound better?...I just want to do it all myself and need time...
08 MS3 GT
 Old 10-20-2011, 03:47 PM   #10
Jake5713's Avatar
Just installed some today for a local guy
Super easy just time consuming, we ran into a few time consuming issues but we got them on pretty quick
I am here: http://maps.google.com/maps?ll=44.739586,-93.107877
-Jake
 Old 10-20-2011, 03:49 PM   #11
m4tic's Avatar
Posts: 4,928   (View Stats)
i got some new ones you coulda bought
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
HPFP internals or new HPFP? JAGspeed6 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 11 11-26-2011 02:34 PM
What HPFP internals and where? Joellc2434 MazdaSpeed 3 - Engine, Transmission & Driveline 13 08-31-2011 04:12 PM
HELP!!!! HPFP Internals kahunab14 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 27 03-07-2011 02:17 PM
Page generated in 0.30142 seconds with 26 queries
