 Old 04-30-2015, 07:24 AM   #1
frankc730's Avatar
Posts: 115   (View Stats)
frankc730 will become famous soon enough
Groaned at 9 Times in 5 Posts
Default Hpfp output fitting possibly leaking?????
So recently I noticed a strong gas smell coming from the engine bay, popped the hood and with the car off I heard a faint hissing sound coming from the bottom of the Hpfp it's not where the hard line connects to the fitting but where the fitting goes into the Hpfp housing. now I replaced the internals months ago and it went smoothly can I tighten the 17mm fitting I was told that it shouldn't move when tightening the 19mm hard line. When I go to tighten it to see if the hissing will stop it does but I think it's moving both the fitting and the compression nut. Anyone else have this problem or know if I can tighten the 17mm fitting?
frankc730 is offline   Reply With Quote
HPFP Hardline cracked and leaking!! MPS_Fan 2010 MS3 - Fuel, Nitrous & Water Injection 62 06-09-2017 03:58 PM
HPFP Fuel Line Leaking Jtaylor MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 18 10-03-2016 06:52 PM
hpfp leaking o-ring muggs Mazdaspeed3/6 General Discussion 3 03-29-2014 10:21 PM
Leaking hpfp dyin hawaiian MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 10 02-06-2013 09:00 PM
Page generated in 0.22308 seconds with 20 queries
