 Old 04-13-2016, 03:31 PM   #1
bitbandit's Avatar
Posts: 42   (View Stats)
bitbandit is a glorious beacon of lightbitbandit is a glorious beacon of lightbitbandit is a glorious beacon of lightbitbandit is a glorious beacon of lightbitbandit is a glorious beacon of light
Default HPFP Question
I installed my corksport internals and was wondering if its normal for the internals to look this nasty? Its not the best picture but I can get a better one now that I have them all cleaned up.
I am also wondering if they are really stock internals, the piston and sleeve wont separate. I had to compress the spring and remove the tappet and retainer to get it apart so I could install the corksport internals. In the install video corksport has they just pulled the stock internals right out with out any trouble and mine were not having any of that.
bitbandit is offline   Reply With Quote
 Old 04-13-2016, 03:46 PM   #2
[R]usty's Avatar
Posts: 2,204   (View Stats)
[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world
Groans: 79
That is not normal unless you're running E85.
2010 Mazdaspeed3 w/tech
Cobb AP V3JBR Tru 3" Wide PathJBR Boost Tubes & BPV HoseCobb XLE BPVCP-E TMIC ║ UR Racepipe ║ Magnaflow CBEAutoTech InternalsGrimmSpeed EBCS ║ JBR RSBSPC Camber ArmsKW V3 CoiloversJBR IM+TB TIGs & TB BypassJBR SSPE - Focus RMMStopTech Slotted Rotors and EBC Yellow Stuff PadsTechna-Fit SS Brake Lines
[R]usty is offline   Reply With Quote
 Old 04-13-2016, 03:53 PM   #3
bitbandit's Avatar
I have never ran e85 in it. but that does not mean someone else didn't before me. I am the 3rd owner and have owned it since dec. of 2011. Other than an ACT clutch the car was stock.
should I be looking for other issues possibly?
 Old 04-13-2016, 04:08 PM   #4
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Those definitely don't look stock.
Blue Pu.
 Old 04-13-2016, 05:03 PM   #5
Snowing's Avatar
Posts: 78   (View Stats)
Snowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud of
Groaned at 3 Times in 1 Post
Here is a stocker
2012 Mazdaspeed 3
CS SRI + TIP - CS TMIC - CS Catted DP - Autotech HPFP Internals - Denso ITV22
Purple Drank Tune in process
Snowing is offline   Reply With Quote
 Old 04-14-2016, 07:37 AM   #6
bitbandit's Avatar
I am thinking they are stock internals but since I cant get the piston out of the sleeve its hard to tell for sure. They kind of look like a picture I found of some older Cobb internals.
Seems like all the internals I have seen pictures of you can separate the two pieces.
06 MS6 - Totaled
07 MS6 - Sure intake, Cobb AP, CS Turbo, CS Turbo Back Exhaust, CS HPFP Internals, CS TMIC, CS BPV, CS EBCS and Both Sure rear diff mounts.
 Old 04-14-2016, 08:31 AM   #7
Dommo14's Avatar
Posts: 693   (View Stats)
Dommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the world
it looks like stock internals to me. but just junked up from E85, or some really bad quality gas...
I'm stock bro.
Dommo14 is offline   Reply With Quote
 Old 04-14-2016, 08:55 PM   #8
Snowing's Avatar
Haha yeah you should be able to slide it right out..
2012 Mazdaspeed 3
HPFP QUESTION: davespeed1 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 08-24-2014 04:06 PM
HPFP Question speed31982 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 7 10-10-2013 03:33 PM
HPFP Question acidhalo 2010 MS3 - Engine, Transmission & Driveline 3 05-08-2012 02:16 AM
HPFP Question erod550 Custom Performance Engineering (cp-e.com) 1 02-20-2010 05:50 AM
CP-E HPFP Question... Deadman MazdaSpeed 6 - Engine, Transmission & Driveline 6 12-18-2008 04:19 AM
Page generated in 0.28458 seconds with 25 queries
