 Old 11-19-2018, 09:52 PM   #1
hml4's Avatar
Posts: 2   (View Stats)
hml4 is an unknown quantity at this point
Default Inertia fuel pump switch
I'm trying to get a definitive answer if the 2008 mazdaspeed 3 has an inertia switch to shut down one or both fuel pumps in the event of an accident/rollover or other impact. If so, where is it located? If not, did mazda ever use the switch on its vehicle and when did mazda stop using the shutoff switch/
Thank you in advance for your assistance.
hml4 is offline   Reply With Quote
 Old 11-20-2018, 10:39 AM   #2
SSinstaller's Avatar
Posts: 3,953   (View Stats)
Groans: 58
I've never seen one in the wiring diagram.
Soon to be installed:
 Old 11-20-2018, 02:32 PM   #3
Jeff23spl's Avatar
Posts: 1,937   (View Stats)
Ford used it a while back, (saw it on a 1987 tempo) not sure if they still do since everything is electronically controlled for more than 1 or 2 decade.
I stripped my 2007 3 all over and didn't seen any.
Why do you ask ? Are you looking blind to solve an issue by just pushing a reset ? Have you checked pump relay or resistor ?
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 11-22-2018, 06:41 AM   #4
hml4's Avatar
Have an 2006 Mustang, the glass technician tripped switch changing windshield. Took me about 1-2 hours to figure it out and reset switch. Just wanted to know about mazdaspeed 3 in the event anything happens to it. Thanks for response.
 Old 11-22-2018, 07:43 AM   #5
Jeff23spl's Avatar
ok i see.
Wife drive 2010 CX7
Fuel door switch stuck furinax Mazdaspeed3/6 General Discussion 5 01-11-2017 10:00 PM
Water Pump, Tstat, Fuel Pump Oh My! CBear3 Mazdaspeed3/6 General Discussion 13 10-01-2015 05:03 PM
In tank fuel pump and fuel rail valve Seatime3 2010 MS3 - Fuel, Nitrous & Water Injection 1 04-30-2012 07:44 PM
Issues with fuel pump pressures, aftermarket pump... ptperformance MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 10-04-2009 05:17 PM
Page generated in 0.25221 seconds with 22 queries
