Like Tree4Likes
  • 1 Post By dale_gribble
  • 1 Post By [R]usty
  • 1 Post By sharksinspace
  • 1 Post By Fstrnyou
 Old 10-25-2015, 09:15 AM   #1
armyman's Avatar
Posts: 28   (View Stats)
armyman has a spectacular aura aboutarmyman has a spectacular aura about
Default injector O ring size
Does any one know the size of the O ring for the fuel injector? I wanted to order them from Mazda in the Netherlands, where I live, but I think they are made of gold judging by the price of over 100 euro's per set of 4! Looking for alternative now. Replacing seals this week and want to do the O rings just be sure
CPe HPFP, Corksport Mazdaspeed 6 power series catted downpipe, Corksport TMIC, Corksport MZR Bypass valve, Cooling Mist W/M injection with cmgs, JBR Tru-3.5 Wide Path Full aluminum Intake System, Denso ITV-22, intank 265 L fuel pump, rear engine mount, EGR block off plate, XS stainless steel exhaust manifold ceramic coating, BNR stage 3 turbo, Stratified Mazda 3 Port Electronic Boost Control Valve, Stratified tune, HKS Twin Power
armyman is offline   Reply With Quote
The Following User Says NO Thank You to armyman For This Un-useful Post:
08mzr (10-25-2015)
 Old 10-25-2015, 10:28 AM   #2
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Those orings hold back 1800psi and they are very important hence the price. Just suck it up and get oem parts.
MINI H1 6.0 - CAR LED TAILS
ms6mil (10-25-2015)
 Old 10-25-2015, 12:23 PM   #3
mituc's Avatar
Posts: 3,518   (View Stats)
Groans: 111
It's actually going to be more than 100EUR/set, because you need about 3 types of o-rings if you intend to pull the injector rail and replace the rings. Luckily though the other ones are about 3EUR/piece or so, but they still add up to the final price.
Get the OEMs, those are parts that you replace maybe once at 150-200k kms. You need a set of four L3K9-13-253 (the blue and most expensive ones), a set of L3M8-13-252 and another set of L3M6-13-252.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
Micha (02-05-2016)
 Old 10-25-2015, 01:47 PM   #4
armyman's Avatar
Thnx for the replies and part numbers. Guess it's worth the investment.
 Old 02-02-2016, 12:56 PM   #5
rusharp's Avatar
Posts: 110   (View Stats)
rusharp is a splendid one to beholdrusharp is a splendid one to beholdrusharp is a splendid one to beholdrusharp is a splendid one to beholdrusharp is a splendid one to beholdrusharp is a splendid one to beholdrusharp is a splendid one to behold
Groaned at 5 Times in 1 Post
I think the price is just pure rape...look at other di cars and injectors seals are no where near this price.
rusharp is offline   Reply With Quote
 Old 02-02-2016, 01:31 PM   #6
That's what happens when you buy a car with an engine that was on the cutting edge of technology in the early 2000s with hp/liter that was close to supercars on a low production platform.
Mazdas are pretty cheap to keep up, the o-rings/grommets are one of the only gotchas.
rusharp likes this.
The Following 2 Users Say Thank You to dale_gribble For This Useful Post:
Micha (02-05-2016), WetzMS3 (02-03-2016)
 Old 02-03-2016, 05:25 AM   #7
rusharp's Avatar
Your right, just sometimes it feels necessary to moan about it...If I didn't need them then I'd probably just go about my life..ha.
The Following User Says Thank You to rusharp For This Useful Post:
dale_gribble (02-03-2016)
 Old 03-03-2017, 11:27 AM   #8
Prodigalson's Avatar
Posts: 133   (View Stats)
Prodigalson has much to be proud ofProdigalson has much to be proud ofProdigalson has much to be proud ofProdigalson has much to be proud ofProdigalson has much to be proud ofProdigalson has much to be proud ofProdigalson has much to be proud ofProdigalson has much to be proud ofProdigalson has much to be proud of
Thread resurrection:
Does anyone have any spare old O-rings that I can examine? I work at Bosch in the DI group and would like to see if we have an equivalent DI injector O-ring that can be used.
2012 MS3 Crystal White, Tech; Upgraded HPFP, Damond SSP, RMM, PMM, TMM CS RSB, shift knob, mud flaps, hood scoop, TMIC, JBR shifter bushings, leather shift boot w/red stitching, Stoptech lines, Bayson-R front lip.
Not yet installed: JBR EGR delete, catless DP
2007 Kawasaki Mean Streak Special Edition
Low & Mean CRS, Hepco & Becker crash bars, Marauder headlight w/3800 lumen LED bulb, MBW LED front signal rings, Chrome Glow LED rear signals, 420 lumen LED 1157 taillight bulb, Danny Gray Raven solo seat, Muzzy 2-to-1 exhaust, black front calipers w/red lettering, Thunder Tornado intake, 200/55 rear tire, Progressive front springs w/Racetech Gold valves, Progressive 444 rear shocks (12.5"), Bad Ace rear caliper relocation bracket, Bad Ace Cam Chain Tensioner Extenders, Bad Ace Fork Cap Covers, Bad Ace Fuel Enrichment Knob Relocation Bracket, Avon black anodized air grips w/throttle boss, sidemounted license plate
Prodigalson is offline   Reply With Quote
 Old 03-03-2017, 12:16 PM   #9
[R]usty's Avatar
Posts: 2,204   (View Stats)
[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world
Groans: 79
I might have one lying around. I'll check when I get home.
Prodigalson likes this.
2010 Mazdaspeed3 w/tech
Cobb AP V3JBR Tru 3" Wide PathJBR Boost Tubes & BPV HoseCobb XLE BPVCP-E TMIC ║ UR Racepipe ║ Magnaflow CBEAutoTech InternalsGrimmSpeed EBCS ║ JBR RSBSPC Camber ArmsKW V3 CoiloversJBR IM+TB TIGs & TB BypassJBR SSPE - Focus RMMStopTech Slotted Rotors and EBC Yellow Stuff PadsTechna-Fit SS Brake Lines
[R]usty is offline   Reply With Quote
The Following User Says Thank You to [R]usty For This Useful Post:
Prodigalson (03-03-2017)
 Old 03-03-2017, 03:47 PM   #10
sharksinspace's Avatar
Posts: 763   (View Stats)
Groans: 126
I'm planning to do a valve cleaning/injector seal swap hopefully later this month, and will be changing out the orings while I'm at if. If you still want/need them at that time, I can send you the OEM rings that I yank out...assuming I don't forget, haha.
2007 MS3
PD by Will
The Following User Says Thank You to sharksinspace For This Useful Post:
Prodigalson (03-09-2017)
 Old 03-03-2017, 06:00 PM   #11
Fstrnyou's Avatar
Posts: 2,383   (View Stats)
Groans: 24
I have a used set laying around.
Not sure why I'm helping you though. My brother works at Continental, Fuel Systems.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 03-09-2017, 10:29 AM   #12
[R]usty's Avatar
Groans: 79
@Prodigalson; The only ones I have are brand new. I was saving them for when I eventually build. Any chance I can let you borrow one or do you need to destroy it?
 Old 03-09-2017, 12:28 PM   #13
Borrowing is fine! Just want to compare it to existing Bosch O-rings...If the size matches up, we're good (both are DI injector O-rings so functional capability will be equivalent).
Is your brother a Mazdaspeed brother?
 Old 03-09-2017, 01:46 PM   #14
[R]usty's Avatar
Groans: 79
PM incoming.
 Old 03-09-2017, 03:12 PM   #15
Fstrnyou's Avatar
Groans: 24
Unfortunately no. He has a 420whp G35 that will be up for sale soon.
Other rides:
History:
 Old 03-10-2017, 07:56 AM   #16
galaxyspeed's Avatar
Posts: 17   (View Stats)
galaxyspeed has a little shameless behaviour in the past
Fucking orings
galaxyspeed is offline   Reply With Quote
 Old 03-14-2017, 01:59 PM   #17
@prodigalson any luck with orings?
 Old 03-14-2017, 02:34 PM   #18
Haven't gotten them yet...
 Old 03-14-2017, 02:37 PM   #19
Hopefully you can save some coin let us know man
 Old 02-14-2018, 09:01 PM   #20
JohnnyTightlips's Avatar
Posts: 8   (View Stats)
JohnnyTightlips is a jewel in the roughJohnnyTightlips is a jewel in the roughJohnnyTightlips is a jewel in the rough
Anything ever come of this?
JohnnyTightlips is offline   Reply With Quote
 Old 02-15-2018, 04:56 AM   #21
GroceryGtr's Avatar
Posts: 472   (View Stats)
If you mean the blue o-ring ontop, that is available aftermarket, the others are a bit more of a pita. You can usually buy a set of the blues from any injector service place. below is a post with some info. I believe I bought my spare set from the injector guy in canada for like $10-15.
Injector seal confusion
 Old 02-15-2018, 05:29 AM   #22
flapjack's Avatar
Posts: 121   (View Stats)
flapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to behold
We are talking about the blue O-rings that go on top of the injectors right?
If you are in a pinch you can pick up a set of those O-rings at Autozone/Advance. Fel-Pro makes them and they are the correct size, but not the same material as OEM.
I bought a set and compared them when I did my injector seals but I coughed up the extra $$$ for OEM because I did not want to have something fuck up. Its my daily driver currently.
2007 Sunlight Silver Mazdaspeed3
Engine:
\\ JBR Solid RMM \\ AWR PMM \\ TRZ TMM \\ JBR PCV OCC \\ HTP 4" Intake \\ BNR S3 \\ CPE 3.25" TMIC \\ eBay 3" Catless DP \\ Autotech HPFP Internals \\ Ford Transit Van Spin-on Oil Filter Adapter \\ Full EGR Delete \\ Throttle Body Coolant Bypass \\ Corksport Injector Seals \\ Greddy Type FV BPV \\
Tuning:
\\Cobb AP V3\\ Freektune Custom Tune \\
Suspension/Brakes:
\\ BC Racing BR Type Coilovers \\ StopTech Street Pads F&R \\ Centric Drilled & Slotted Rotors \\ OZ Alleggerita Wheels 18x8 et48 \\
 Old 02-15-2018, 06:47 AM   #23
kTaLgsTo's Avatar
Posts: 566   (View Stats)
Why not just go dealer? No headache, just put the money down and take care of your car. If you want cheap dealer parts buy a tiburon
 Old 02-15-2018, 06:53 AM   #24
flapjack's Avatar
OEM O-rings are $16.50 per and the Fel-Pros are $7 for a set of 4...
Cost is the main factor here but I still highly recommend OEM parts.
Engine:
Tuning:
Suspension/Brakes:
 Old 02-15-2018, 08:06 AM   #25
Being cheap is not the issue, an o-ring costing an absurd amount of money is. I thought I might be missing something as these cars have been out for 11 years now and maybe someone has an alternative. Such as a complete rebuild set for like 15$ which most diesel DI vehicles have, was not sure if someone did a set like that for us. I will take a look at the other thread and just bite the bullet if need be. Thanks
 Old 02-15-2018, 10:10 AM   #26
Fstrnyou's Avatar
Groans: 24
I bought all new o-rings/grommets when I swapped injectors. Stupid expensive, as it's been pointed out, but now I know it's good to go for many more miles using OEM quality parts/materials. I won't ever have to replace them again unless they tear or break.
sharksinspace likes this.
Other rides:
History:
 Old 06-11-2018, 06:41 PM   #27
Sansbacon's Avatar
Posts: 2   (View Stats)
Sansbacon is an unknown quantity at this point
It sounds like you're all oem but I'm curious if anyone on here has used the fel-pros and how many miles you've gotten so far?
Sansbacon is offline   Reply With Quote
What is the correct hub ring size 67.xxmm? mhebert2001 2010 MS3 - Wheels & Tires 11 02-03-2015 08:53 PM
Injector seals - need to replace injector/fuel line O-rings? TheRealDefman 2010 MS3 - Engine, Transmission & Driveline 3 03-02-2014 08:35 PM
hks snap ring size? lol Mazdaspeed3/6 General Discussion 2 05-23-2013 10:00 AM
Nicked injector near where blue o-ring sits aviator79 Mazdaspeed3/6 General Discussion 8 03-24-2012 04:06 PM
Stock Injector Size? TheNewGuy MazdaSpeed 6 - Engine, Transmission & Driveline 15 04-15-2011 05:57 AM
Page generated in 0.45876 seconds with 33 queries
