Like Tree3Likes
 Old 12-11-2012, 10:38 AM   #441
Eth Fiend
phate's Avatar
Posts: 6,935   (View Stats)
I no haz spare head lol
I think the key for the toyota seal being useful is to torque it a little extra (like a max of 25 ft-lbs as DJ said) to ensure all 4 have crushed as much as it can like you showed in your tests.
I meant grab extra seals and see how much they all crush at whatever torque value. Torque readings can be thrown off by something as simple as dirty threads. If you install a set, pull them and measure, you can see what's going to happen on each cylinder. From there it's fairly simple troubleshooting as to why they don't crush evenly.
-06 MS6
-Corn fed 07 MS3 - Sold
Fail_6 (03-27-2014), ms3blackmica (12-11-2012)
 Old 12-11-2012, 10:42 AM   #442
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
You are a smart man.
Good thinking!
www.tunedbynishan.com
 Old 12-11-2012, 11:04 AM   #443
jack_hammer's Avatar
Posts: 6,821   (View Stats)
Groans: 549
i found out i had leaking seals (oem) b/c i was getting knock
it's fun to do bad things
 Old 01-16-2013, 07:52 PM   #444
LatinKraze's Avatar
Posts: 804   (View Stats)
LatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the world
Found the seals for $1.50 @ TRD Sparks Toyota Parts & Scion Performance Parts Accessories from Sparks Toyota-Scion
Shipping is more than four seals but it gets shipped to your door and it's convenient for people like me who can't get to the stealership. Great for the NATOR guys that can get them shipped for the whole chapter for one shipping fee.
2007 MS3: BNRs3 PPT Tuned 350hp/360tq Stocked out and SOLD
2016 CX-5 GT AWD
LatinKraze is offline   Reply With Quote
 Old 01-16-2013, 08:02 PM   #445
Eth Fiend
phate's Avatar
Ok, beware this is going to be a somewhat half ass post because I did this testing ~3 months ago and didn't write down initial measurements. Not that they are terribly important, because we have decent comparative values. [I did go out to the garage and get readings of 1.620-1.630mm on a new injector seal, though.]
Anyway, the setup: I wanted to see just how much these Toyota seals crushed at different torque levels with the stock crows feet and stock bolts. I used ARP Ultra Torque on the threads and the friction point where the bolt head meets the foot, and where the foot meets the head and injector. Minimum friction, lol.
I did three tests, each with 3 different seals in each test (9 seals used).
1) torque to 15lb-ft, measure. Retorque to 20lb-ft, measure. Retorque to 25lb-ft, measure.
2) torque to 20lb-ft, measure. Retorque to 25lb-ft, measure.
3) Torque to 25lb-ft, measure.
Crush results (Excel workbook also attached):
http://i64.photobucket.com/albums/h1...sh_Testing.jpg
^^Units in mm^^ "Seal #x " should actually read "Test #x "
So, as you can see, at 15lb-ft, there was still room to crush them some more. They didn't crush much beyond 20lb-ft, so I don't think it's worth going with the higher torque value. The OE torque spec of ~17lb-ft is probably a safe bet, really. The seals don't seem to be reusable, as they crush inward and pinch the injector tip.
Note: The minimum and maximum are the from height measurements around the seal. A brand new seal I just measured displayed a similar variance between min and max - 1.620 minimum and 1.630 maximum. A similar variance to the crushed min/max values. I didn't notice any correlation between the orientation of the seal compared to the crows foot, it seemed to be random with each seal.
I just thought of a simple way to check the "max" crush we would be able to get out of the crows foot. They make plastigauge that reads in the .030-.070" range, which is what we're dealing with. I think I'll set it up without a seal and crank it down at different torque ranges similar to what I did above. That way we'll see if there's still movement left in the crows foot to increase clamping force on the injector, itself.
If there's still movement left, I think we can assume the extra torque on the bolt would increase clamping force. Sound reasonable?
Soooooo, I did the "max crush" testing and came up with very similar values to what my Toyota seals crushed to. I also tested my actual head for my new engine with a set of injector seals to see if any were off like Dano's and ms3blackmica's. They all crushed pretty evenly, so I'm hopeful (I'll post that in my build thread for future reference).
It's in one of these two threads we were talking about it. Can't find it in this one...
-06 MS6
impossible (05-23-2016), LatinKraze (01-16-2013), ms3blackmica (01-16-2013)
 Old 06-20-2013, 01:05 PM   #446
dgiannitakis's Avatar
Posts: 31   (View Stats)
dgiannitakis is a glorious beacon of lightdgiannitakis is a glorious beacon of lightdgiannitakis is a glorious beacon of lightdgiannitakis is a glorious beacon of lightdgiannitakis is a glorious beacon of light
I am expecting cp-e injector seals delivery next week...
http://​www.linkedin.com/in/​dgiannitakis
dgiannitakis is offline   Reply With Quote
 Old 06-21-2013, 12:22 AM   #447
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
...cool story.
The Following User Says Thank You to Mizzle For This Useful Post:
Tokay444 (06-21-2013)
 Old 03-27-2014, 09:01 PM   #448
Eth Fiend
phate's Avatar
Since we had two threads by Paveltol, with the exact same name, started at the exact same time...I added a version to the thread title. I couldn't, for the longest time, figure out why I couldn't find some info again...and it's because there were two threads with the same name. Please no one ever do something like that again.
This thread is version "B"
Over here is version "A": Injector seals solution. Version A
They both have great information, and are way too long to merge.
-06 MS6
Mizzle (03-31-2014), Nliiitend1 (03-29-2014)
 Old 02-26-2015, 05:22 PM   #449
TECH2EIGHT's Avatar
Posts: 29   (View Stats)
TECH2EIGHT can only hope to improve
just bought mine at kendall Toyota ill have em on Saturday. 3 bucks a pop,,, I can deal with that...installing them same day!!
Anyone in Oregon area? would like to a help a essay
out installing seals?
Instagram: @serg_ms3
"Peasant Gang" & "Always content never satisfied" slapper sticker available. check them out. On my buddy IG page(tiffany blue STI) @PeasantGang
TECH2EIGHT is offline   Reply With Quote
 Old 08-18-2015, 08:58 AM   #450
JB11SPEED3's Avatar
Posts: 19   (View Stats)
JB11SPEED3 is just really niceJB11SPEED3 is just really niceJB11SPEED3 is just really niceJB11SPEED3 is just really niceJB11SPEED3 is just really nice
Has any one side the HPFPupgrade.com stud kits they come with washer so no cutting the torx bolts an it's only 39.95
JB11SPEED3 is offline   Reply With Quote
 Old 08-18-2015, 11:45 AM   #451
mituc's Avatar
Posts: 3,519   (View Stats)
Groans: 111
Good afternoon, you landed on planet Earth. Now go back to where you came from.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 08-18-2015, 12:49 PM   #452
Groans: 549
their stud kits are fine.
 Old 09-15-2015, 09:16 PM   #453
Snotrocket's Avatar
Posts: 900   (View Stats)
Snotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the world
25 lbs of boost. 20,000km. Torqued to the specs on here. They just don't hold up :/
2010 MS3 Black
395whp/386wtq
| Molnar Rods | CP-e Stage 2 Pistons | Much Head Work | ATP GTX3076 | Tial 38mm EWG | HTP 4 Inch Intake | BSD | Passenger and Rear MM | Denso ITV22's | OCC | Ultimate Racing TBE | Tredstone TR8C FMIC | Tial BPV | Autotech Internals | Grimmspeed ECBS 3 port | Te37 Volks| 245/45/17 Dunlop zzi tires| Cobb AP Self Street Tuned | Sonic Tuning Coilovers | Stoptech breaks and slotted roters
Snotrocket is offline   Reply With Quote
The Following 2 Users Say Thank You to Snotrocket For This Useful Post:
Nliiitend1 (09-18-2015), phate (09-16-2015)
 Old 09-15-2015, 10:43 PM   #454
sh4d0w's Avatar
Posts: 565   (View Stats)
sh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the world
Groans: 45
Groaned at 7 Times in 4 Posts
Subbed cause interesting.
2010 Black MS3
Cobb AP // Cobb EBCS // Cobb Downpipe // Cobb RMM // JBR Tru 3.5'' Intake // JBR TMM // JBR PMM // JBR RSB // CP-E Cat Back // NGK One step colder plugs // GT 3071r // Azenis 615k // Bilstein PSS B14 Coilovers // Treadstone TR8 FMIC // Bully Stage 4 Clutch // Damon EGR Delete // Autotech HPFP // AEM V1 Meth Kit 50/50 // Freektuned 94 Oct
sh4d0w is offline   Reply With Quote
 Old 01-19-2016, 11:03 AM   #455
BuddySpeed3's Avatar
Posts: 474   (View Stats)
Is this with OEM seals or Toyota seals?
- 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 2 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress)
 Old 01-19-2016, 04:26 PM   #456
sh4d0w's Avatar
Groans: 45
You have to assume it's the yota seals cause he says "torqued to specs posted here" "They just don't hold up". I think earlier in the thread he even mentions installing them.
I have been running 26 psi for 10,000k. No issues on Toyota seals.
Yea he was.
2010 Black MS3
Last edited by sh4d0w; 01-19-2016 at 04:26 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-20-2016, 12:31 PM   #457
Yea he was.
Awesome! yeah I figured. I just hope the Toyota seals are better than the oem seals. but who knows. If they are it would be a cheap alternative for people not looking for excessive power.
You said 26 psi...How much power are u making and are u running e85/methanol? the reason I ask is cause someone on here said he's still running OEM seals with 400 hp. He said that it may be due to the fact that since day 1, he's been running e85/meth which keeps knock at bay. I wonder if knock is the cause for the seals failing to begin with from the sudden pressure spike that it creates.
EDIT : woops 26 psi quoted to snotrocket my bad.
 Old 01-20-2016, 12:40 PM   #458
Code Monkey's Avatar
Posts: 7,671   (View Stats)
I blew through PTP seals, then through the Toyota seals, and I just installed CorkSport seals. In the unfortunate case they last similar as the Toyota seals (~1.5 years) I will be switching back to Toyota seals, can't beat the price.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
 Old 03-31-2016, 04:08 PM   #459
racersir's Avatar
Posts: 71   (View Stats)
racersir is an unknown quantity at this point
I'm installing the Toyota seals tomorrow. What is the consensus torque specs 25lb? Also I was planning on using the same o- rings that go to the rail the blue ones since I don't have them available locally. Do you guys replaced the blue o-rings also? Thanks
racersir is offline   Reply With Quote
 Old 03-31-2016, 04:32 PM   #460
muffhugger's Avatar
Posts: 326   (View Stats)
muffhugger is the leader of the worldmuffhugger is the leader of the worldmuffhugger is the leader of the worldmuffhugger is the leader of the worldmuffhugger is the leader of the worldmuffhugger is the leader of the worldmuffhugger is the leader of the worldmuffhugger is the leader of the worldmuffhugger is the leader of the worldmuffhugger is the leader of the worldmuffhugger is the leader of the world
Got my Toyota seals last week. Can't wait to test them out.
muffhugger is offline   Reply With Quote
 Old 04-02-2016, 05:27 AM   #461
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
They're gonna last you longer than that.
"Exclusivity" - CP-enis
Demodded.
The Seals
Code Monkey (04-02-2016), MS3Shadow (04-03-2016)
 Old 04-21-2016, 01:06 PM   #462
leo766's Avatar
Posts: 300   (View Stats)
leo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond repute
Groaned at 93 Times in 33 Posts
Did you use the stock bolts/washers on the seals that failed or no? I wanted to ask both Code Monkey and Snot Rocket? Since it would seem plasuible that you either need new hardware(like the cp-e kit), or modify the stock studs, or have cupped crushing seals like corksport to apply full seating force, and i could see how relying on a surface as small as the toyota seals on one side and the stock torx bolts and cupped washers could create a seal almost as unerliable as the stock one in some cases?
*i dont know nuthing tho, just wanted to ask and propose a theory, but for all i know you guys did it all and they still failed on ya, i have had a set sitting a few months and i have been wondering if I should try and throw em on, or save and get the CS or CPE ones*
Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray!
Cpe: FMIC, CAI, TIP, HPFP, bone engine mount
Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar
Turbine Tech: Extra front motor mount, both diff mounts +bushings
EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk,
AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto.
17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs
Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand
leo766 is offline   Reply With Quote
 Old 04-21-2016, 02:04 PM   #463
With the PTP seals, I used their studs and bolts, switched back to stock torx for Toyota and CorkSport.
2006 Mazdaspeed6
2017 Subaru BRZ
 Old 11-12-2016, 08:30 AM   #464
Fstrnyou's Avatar
Posts: 2,420   (View Stats)
Just ordered 2 sets from my local Yotaship. $2.10ea. Plenty at warehouse. It's Saturday, so I won't have them until Tuesday. Good to know there's no more shortages like 4 years ago.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f303/injector-seals-solution-version-b-119326/
100% DI Failure with Nurburgring rentals - Page 6 - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 07-08-2013 05:54 AM
I just did my injector seal. Mine are dirtier than yours! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 08-04-2012 01:09 PM
Injector seals solution. Version A paveltol MazdaSpeed 6 - Engine, Transmission & Driveline 756 05-23-2017 09:38 AM
Injector seals solution. paveltol 2010 MS3 - Fuel, Nitrous & Water Injection 404 11-22-2016 02:39 AM
Injector seals solution. paveltol 2010 MS3 - Engine, Transmission & Driveline 397 07-25-2014 07:34 PM
Injector seals solution - Gen 2 paveltol MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline 397 09-19-2012 01:50 PM
Injector seals solution. paveltol MSF KB - Mazdaspeed 3/6 - Fuel 401 09-19-2012 12:49 PM
Page generated in 0.47062 seconds with 38 queries
