 Old 12-04-2011, 08:05 PM   #1
burntmushu's Avatar
Posts: 128   (View Stats)
burntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond repute
Default installed cpe hpfp running lean code 2187
besides my vvt problem the car wasn't throwing any other codes. and during my last tear down on trying to get the vvt in the right position i replaced the hpfp to a cpe. thought i had a vacuum leak but everything is good. but i'm running lean. i tore down the car again today to try and realign the vvt and double checked the vacuums while i was tearing it down. anyone have the same problems? any ideAs?
burntmushu is offline   Reply With Quote
 Old 12-23-2011, 11:30 AM   #2
410ms3's Avatar
Posts: 91   (View Stats)
410ms3 has a brilliant future410ms3 has a brilliant future410ms3 has a brilliant future410ms3 has a brilliant future410ms3 has a brilliant future410ms3 has a brilliant future410ms3 has a brilliant future410ms3 has a brilliant future410ms3 has a brilliant future410ms3 has a brilliant future410ms3 has a brilliant future
Groaned at 4 Times in 2 Posts
I was throwing the same code but not running lean at idle or any other situations. Checked vacuums and intercooler piping and couplers and found out that my purge valve was stuck open causing the car to throw a lean idle code. Im not sure if its the same for your car but that was my issue. Hope this helped a lil.
410ms3 is offline   Reply With Quote
The Following User Says Thank You to 410ms3 For This Useful Post:
rfinkle2 (12-23-2011)
New Spark Plugs = 2187 code? sallyspeed3 MazdaSpeed 3/6 - ECU Computer Tuning 2 10-08-2011 08:22 PM
Am I running too lean? BudUMfan MazdaSpeed 3/6 - ECU Computer Tuning 21 03-02-2010 03:47 PM
Running Lean W/FFS Realgib3
Cobb ATR Support
108 10-13-2009 12:41 PM
Running Lean? Praelior MazdaSpeed 6 - Engine, Transmission & Driveline 20 08-12-2009 05:47 AM
Running lean? Meder MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 01-14-2009 07:03 PM
Page generated in 0.23820 seconds with 21 queries
