Like Tree6Likes
 Old 10-11-2011, 09:42 PM   #41
Posts: 9,484   (View Stats)
so lets look at what the actual pump assembly looks like and take it apart:
c-clip retainer for assembly top
remove and lift the top off
Venturi feed line on outside of bucket
venturi inlet in bottom of bucket
pry out on the 3 pump housing clips to remove from the bucket
pump housing removed from bucket
actual pump removed from housing
housing where pump outlet o-ring seats
Regulator location in the pump housing
regulator is held in the pump housing with double o-rings. Just pry out with a flat blade screwdriver.
pump and filter
pump bottom
pump top
filter
That's about it.
I think to try and used the upgraded MZ3 pump would require wiring in the different connector and using the MZ3 filter if possible. I haven't seen any pics of that filter but the bottom of our pump appears to be totally different than the MZ3 pump. thanks Mazda! don't make anything easy lol
The Following 9 Users Say Thank You to Dano For This Useful Post:
djuosnteisn (10-12-2011), doubleflusher (10-12-2011), GLORIFIEDBOZO (10-13-2011), Nataphen (10-12-2011), rfinkle2 (10-12-2011), SilverDemon (10-12-2011), superskaterxes (10-12-2011), wolly6973 (10-15-2011), Ziggo (10-12-2011)
 Old 10-12-2011, 04:29 AM   #42
how is the regulator held in there?
 Old 10-12-2011, 07:53 AM   #43
your wish...my command...
post 41 updated with more pics of regulator and filter.
 Old 10-12-2011, 11:11 AM   #44
Merged pics from post 41 into OP.
 Old 10-12-2011, 11:20 AM   #45
Originally Posted by Tomas View Post
16 Gauge Air Nibbler
not that expensive
ok for anyone thinking about doing the access cover mod...you WILL WANT TO BUY THIS TOOL
for 30 bones it is a no brainer...there really isn't an easy way to cut out the floor pan with the tank in place...can jig saw or saws all, tank is too close. Only other tool that would work is a cutoff wheel and you will more than likely mess up your interior unless you remove it all...lol
time it takes to remove the interior is worth 30 bucks and the nibbler will leave a much cleaner edge
Thanks @Tomas for the post
Alpha (10-12-2011), GLORIFIEDBOZO (10-13-2011), Tomas (06-17-2012), wolly6973 (10-15-2011)
 Old 10-12-2011, 11:28 AM   #46
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
i used a dremel on mine. it was nervewrecking, and a mess. I too recommend the nibbler.
looks great dano!
The Following 2 Users Say Thank You to socks For This Useful Post:
Dano (10-12-2011), wolly6973 (10-15-2011)
 Old 10-12-2011, 11:31 AM   #47
I can't express enough how easy the nibbler was...literally 30 minutes in I was done with the rough opening...including drilling out the welds on the brace.
now if only removing the cap on the pump assembly were as easy
 Old 10-12-2011, 11:31 AM   #48
jesus 17.5 SCFM @ 90 psi?!?! most shop compressor would have problems running this haha
 Old 10-12-2011, 11:34 AM   #49
meh I have a pancake compressor and it ran it fine. you only use it in short bursts...it chews thru the pan like a hot knife thru butta!
 Old 05-30-2012, 05:30 PM   #50
SilverDemon's Avatar
Posts: 3,034   (View Stats)
next use a scribe or small flat blade screwdriver to pry up the retainer on the fuel line.
Sorry to bring an older thread back to life, but I just replaced the in tank pump today. I wanted to bring to everyone's attention that I was determined to not break the retainer clip. After close inspection and a few attempts to pry the clip out, I found out that I was over thinking the problem at hand...hahhahah, I do this on many occasions.
Are you ready for how easy it is to release the clip?
Simply push down on the center of the white retainer and the line slides right off. No screwdrivers, no metal picks, only my thumbnail was needed to release the line. The retainer does not need to be separated from the fitting.
Hope this helps people out on future installs.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 10 Users Say Thank You to SilverDemon For This Useful Post:
Alpha (06-08-2012), Dano (05-30-2012), Easter Bunny (08-05-2012), IMASA (06-18-2012), Monotonous ONE (06-17-2012), phate (05-30-2012), Todd98SE (09-29-2012), Tokay444 (05-31-2012), Tomas (06-17-2012), wolly6973 (05-30-2012)
 Old 05-30-2012, 05:35 PM   #51
Hahahh. Thanks Scott. I too over think things on an almost hourly basis.
Tappin
SilverDemon (05-30-2012)
 Old 06-01-2012, 06:04 AM   #52
socks's Avatar
Groans: 125
awww sorry guys, had i noticed this thread, i could have mentioned the same thing.
push down on the white bar and the line pulls right off.
Dano (06-17-2012), phate (06-01-2012)
 Old 06-01-2012, 06:06 AM   #53
Eth Fiend
phate's Avatar
Posts: 6,935   (View Stats)
LOL, broke mine way back when, as well.
The soft clutch line from the reservoir to the master cylinder has the same type of connection.
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 06-17-2012, 08:37 AM   #54
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,798   (View Stats)
Hey @Dano,
Where did you get the SST for the pump housing? and how much did that run you? I guess there is no other way to get that cap off then using the SST?
MAKE LOVE TO THE CANVAS
 Old 06-17-2012, 08:52 AM   #55
I borrowed Dustin's and I doubt very seriously you could get it off without the SST or without making your own SST. An extremely phucked up design...but Mazda just loves making up SSTs
Dustin's SST made its way around the entire US so I am sure he will let you borrow it....hell he may not even have it and a MSFer 1 state away may have it now and could get it to you in a day.
I def recommend using an air nibbler to open the floor pan up
edit: on making an SST...all you need to do is get a grip on the ring and with the pan opened up you might be able to fab up and oil filter wrench type of SST out of an old serp belt or any belt really. The "ears" of the SST do nothing more than grip the ridges in the cap.
something to thread the belt through with a 1/2 ratchet opening and use a 6" extension and torque it lose...IDK
lol with all the shit I have seen you fab up it should be easy
Tomas (06-17-2012)
 Old 06-17-2012, 09:14 AM   #56
Bob Ross Fanclub
Tomas's Avatar
I was actually thinking about using a standard pipe wrench or one with a chain linked end. Don't think the chain end option will be so good though. Probably slip.
I'll open up the hole first and then see what happens. If it looks like I am gonna fuck it up with the pipe wrench I'll just borrow / get the SST from someone.
Dano (06-17-2012)
 Old 06-17-2012, 09:40 AM   #57
yeah but I think you need something that will leaver while applying force perpendicular to the retainer ring and it might need more of a standoff...I don't think I am wording this right so here lemee put a Dustin MSPaint drawing.
OP updated with this new valuable info
Last edited by Dano; 06-17-2012 at 09:40 AM. Reason: MSF Database - Automerged Doublepost
rfinkle2 (08-18-2013), SilverDemon (06-17-2012), Tomas (06-17-2012), wolly6973 (06-18-2012)
 Old 06-18-2012, 05:13 AM   #58
socks's Avatar
Groans: 125
i used a BFFS and BFH.
(big flathead and big hammer).
those little tabs may or may not break that hold it on. mine didnt break. they arent strong enough to keep it from unscrewing anyways, so if they do break, who cares?
rfinkle2 (08-18-2013), Tomas (06-18-2012)
 Old 08-05-2012, 10:08 AM   #59
kabobulate's Avatar
Posts: 1,146   (View Stats)
kabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the world
So I just swapped my sensor on my pump and was following this guide until everything was different. My white clip was actually a green clip that just pulls up real easy. Also, the SST is no longer needed as there is nothing to unscrew. You just undo some small screws that hold in a black bracket and pull up on the pump with your fingers. Is this a 2012 thing or a genpu thing?
Ddub-S2K likes this.
2012 CWP MS3: Tuned by Phate - 50/50 E85 | Cobb AP | SURE Intake, TIP | Corksport Racepipe, TMM Inserts | ITV22's | AT Intl's | ACT Sprung 6Puck & Prolite Flywheel | CP-E Stg2 RMM | JBR SSB, EGR Plate
2008 Silver MS3: Sold
kabobulate is offline   Reply With Quote
The Following 4 Users Say Thank You to kabobulate For This Useful Post:
djuosnteisn (08-06-2012), phate (08-05-2012), rfinkle2 (08-18-2013), Tomas (08-05-2012)
 Old 08-05-2012, 10:35 AM   #60
must be a new development...glad they moved away from that BS retainer system.
 Old 08-05-2012, 12:17 PM   #61
InFeXIoN's Avatar
Posts: 1,159   (View Stats)
InFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the world
Groaned at 42 Times in 15 Posts
Here ya go http://www.streetunit.com/In_Tank_Fu..._p/su42001.htm
GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff.
Build Complete!!!!
InFeXIoN is offline   Reply With Quote
 Old 08-05-2012, 07:31 PM   #62
Bob Ross Fanclub
Tomas's Avatar
^ Yeah well, a new lid is $32. That's cheaper than renting the tool.
Changed pumps today. Dremeled the lid to break it off.
BTW. The housing of the pump is actually a fuel filter. Not sure if this was mentioned before.
InFeXIoN (08-05-2012), rfinkle2 (08-18-2013)
 Old 08-06-2012, 11:29 AM   #63
InFeXIoN's Avatar
True but if you had a few guys doing itfps at once would also be cheaper than everyone buying a lid each.
Build Complete!!!!
The Following User Says Thank You to InFeXIoN For This Useful Post:
 Old 07-11-2014, 01:28 PM   #64
silversleeper's Avatar
Posts: 14   (View Stats)
silversleeper is an unknown quantity at this point
So newbie question. What made u certain it was your itfp that went bad. I'm not running anything crazy in terms of mods and have no access port. I checked my fuel pressure with a scan tool and it stays at 420 psi than slowly tapers off. I can watch it build pressure a couple of times but eventually it stops. Any suggestions
silversleeper is offline   Reply With Quote
 Old 10-16-2017, 07:55 PM   #65
Tommy's Avatar
Posts: 2,308   (View Stats)
Groans: 155
Sorry to dig up an old thread but all @Dano; pics disappeared. I am just not getting which clip and how to hold down to get the ring to break loose.
Want to win a v3 Cobb Access Port? Enter the raffle and help a good cause.
http://www.mazdaspeedforums.org/forum/f510/cobb-accessport-v3-raffle-good-cause-190013/
Tommy is offline   Reply With Quote
Oil Pan Replacement MrBojangles MazdaSpeed 3 - Engine, Transmission & Driveline 16 06-14-2016 12:23 PM
Upgraded ITFP Options!!!!!!!!! superskaterxes MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 36 10-11-2011 06:44 PM
Serpentine Belt Replacement, GM Replacement Parts For Older Cars, Fixing A Radiator Fan, Rebuilt Brake Calipers: Mike Al Haltech Automotive News 0 03-27-2009 01:30 PM
Page generated in 0.46742 seconds with 29 queries
