Like Tree3Likes
  • 1 Post By Raider
  • 1 Post By nekret
  • 1 Post By Jonathanhair07
 Old 07-06-2015, 12:15 AM   #1
senor blanco ms3's Avatar
Posts: 1,353   (View Stats)
senor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the world
Groans: 49
Default JMF TB Spacer + Aquamist WMI Kit
Just wondering if anyone else ran into a problem with using the M8 to 1/8" NPT jet fittings provided by Aquamist with the JMF throttle body spacer. I can only get one turn on the adapter before it binds up. It's the same on all 4 ports.
Is English 1/8" NPT and US 1/8" NPT different? lol
2008.5 Crystal White Pearl MS3
A lot of mods
Check out my big turbo build!
senor blanco ms3 is offline   Reply With Quote
 Old 07-06-2015, 04:41 AM   #2
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
I was just given this link yesterday from someone that stated I would need this to run the aquamist nozzles in a plate:
http://www.mcmaster.com/#51615k201/=xxl0py
senor blanco ms3 likes this.
 Old 07-06-2015, 07:36 AM   #3
Groans: 49
Actually, I don't think that's exactly what I need.
A lot of mods
 Old 07-07-2015, 01:04 PM   #4
nekret's Avatar
Posts: 421   (View Stats)
nekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the world
I didn't think the English used NPT and had their own standard (BSPT/BSPP)
The difference between NPT, BSPP and BSPT seals
2011 Mazdaspeed3 non-tech package
Drivetrain
CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune
Chassis
JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace
Rice
LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers
nekret is offline   Reply With Quote
 Old 07-07-2015, 07:22 PM   #5
Groans: 49
Aquamist includes the adapter in their kits. It's also on their site:
--- 806-357N --- M8 to 1/8 NPT jet adaptors (R) - aquamist-direct.com
A lot of mods
 Old 07-07-2015, 07:53 PM   #6
nekret's Avatar
Another quick thought, maybe they sent you the wrong adapter. If you have a thread pitch gauge check to see if the thread pitch on the adapter and the spacer match.
Sent from my SM-G900V using Tapatalk
Drivetrain
Chassis
Rice
 Old 07-07-2015, 09:04 PM   #7
Groans: 49
I don't have one but can get one from a friend.
I wonder if @EdgeAutosport.com; can check if they have any on hand.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
A lot of mods
 Old 07-07-2015, 09:30 PM   #8
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Sounds like the plate wasn't tapped deep enough.
I don't have any problems with my aquamist npt adapters in the Damond Motorsports plate.
That's some shitty quality control of that's the case. It takes two seconds to throw the plug gauge in there to check the depth.
"Exclusivity" - CP-enis
Demodded.
The Seals
07micasp3 (07-23-2015)
 Old 07-07-2015, 10:10 PM   #9
Groans: 49
The threads go all the way through though. Maybe the jmf isn't npt?
A lot of mods
 Old 07-08-2015, 09:19 AM   #10
Jonathanhair07's Avatar
Posts: 1,601   (View Stats)
Jonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the world
Groaned at 8 Times in 4 Posts
I had the same problem on my MD spacer.
I just kept torquing them in. Later realized theres some kind of coating on the adapters not allowing for a smooth install. Just don't torque those jets. those are easy to snap.
2012 Mazdaspeed3
Columbus, Ga
FJ Performance Built Block/GTX3582r
Jonathanhair07 is offline   Reply With Quote
The Following 2 Users Say Thank You to Jonathanhair07 For This Useful Post:
EdgeAutosport.com (07-14-2015), senor blanco ms3 (07-08-2015)
Aquamist HFS-4 WMI Kit mize13 2010 MS3 - Fuel, Nitrous & Water Injection 31 10-30-2015 09:23 AM
Aquamist at EdgeAutosport!! EdgeAutosport.com EdgeAutosport.com 22 04-09-2015 02:37 PM
10mm spacer + 5mm spacer Atomic41 Wheels & Tires - BLACK 3 12-05-2012 11:47 AM
Welcome Aquamist to MSF Haltech Mazdaspeed3/6 General Discussion 28 03-24-2010 05:05 PM
Page generated in 0.31618 seconds with 24 queries
