 Old 04-11-2011, 03:08 PM   #1
fbgm0514's Avatar
Posts: 27   (View Stats)
fbgm0514 is on a distinguished road
Groaned at 6 Times in 4 Posts
Default KMD internals Worth it??
just got a call from kmd i was wondering wether i should buy the internals im kinda tight with the $$ im getting 1700+ fuel psi but my LTFT are 12.00-14.7 wot on stock pump. will the internals take this prob away..? or is this even a problem? thanks !
fbgm0514 is offline   Reply With Quote
The Following User Says NO Thank You to fbgm0514 For This Un-useful Post:
manelscout4life (04-11-2011)
 Old 04-11-2011, 03:08 PM   #2
Mchart's Avatar
Posts: 980   (View Stats)
Mchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the world
Groans: 54
Groaned at 42 Times in 32 Posts
no
Mchart is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Mchart For This Un-useful Post:
Cataphract_40 (04-11-2011), manelscout4life (04-11-2011)
 Old 04-11-2011, 03:10 PM   #3
manelscout4life's Avatar
Posts: 1,781   (View Stats)
manelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the world
Groans: 661
Groaned at 45 Times in 33 Posts
donate instead. then get a fp
manelscout4life is offline   Reply With Quote
 Old 04-11-2011, 03:20 PM   #4
fbgm0514's Avatar
so no fuel pump? im not in danbger with the ltft?
 Old 04-11-2011, 03:25 PM   #5
wankular's Avatar
Posts: 4,343   (View Stats)
Your fuel trims should be zero at WOT because the ECU goes into open loop. High fuel trims are more related to MAF/intakes.
That's about the extent of my knowledge. Maybe someone smarter will weigh in.
2009 MS3 sport MGM
 Old 04-11-2011, 03:30 PM   #6
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
ltft is not a pump issue, it is an intake issue
if your fuel pressure is below 1600, then get a pump
also,
DONATE
 Old 04-11-2011, 06:06 PM   #7
fbgm0514's Avatar
okay i know have a mazdaspeed cia would it be good idea to change it to a corksport intake/inlet.. i also have cs d/p,m/p
The Following 2 Users Say NO Thank You to fbgm0514 For This Un-useful Post:
manelscout4life (04-11-2011), wolly6973 (04-11-2011)
 Old 04-11-2011, 06:08 PM   #8
R.MS3's Avatar
Posts: 987   (View Stats)
facepalm
search this shit, it's been beaten to death a billion times.
R.MS3 is offline   Reply With Quote
The Following 2 Users Say Thank You to R.MS3 For This Useful Post:
is this worth it? yang_jackson MazdaSpeed 3 - Engine, Transmission & Driveline 18 05-27-2009 12:40 PM
FMI worth it? I<3MazdaSpeed MazdaSpeed 6 - Engine, Transmission & Driveline 17 01-07-2009 05:50 PM
Page generated in 0.27134 seconds with 25 queries
