  • 1 Post By Ziggo
 Old 12-09-2012, 04:04 PM   #1
breakfasteatre's Avatar
Posts: 300   (View Stats)
breakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the world
Default Logs showing 1 point of fuel pressure drop into the 100s
As can be seen in the photos, and the logs, i am getting these short 'drops' in fuel pressure showing up in the logs.
fp drops to 200's but has no discernible affect on how the car drives. Ie no fuel cut/boost cut
Spill valve on pump was removed and cleaned, although it looked pretty much flawless
sensor on fuel rail was swapped out with a buddies, did some logs and didnt notice any drops.
bought a new sensor, and after installed, i am still getting the drops
running cpe pump, hopefully its not that as i am not looking forward to trying to warranty it.
should i swap pumps with a buddy, or is this obviously something else?
2011 poo
mods: cpe top mount, UR dp and test pipe, JBR 3.5" intake, itv 22s, 7gph meth nozzle in boost tube spraying at 15psi
breakfasteatre is offline   Reply With Quote
 Old 12-09-2012, 04:19 PM   #2
johnredding's Avatar
Posts: 437   (View Stats)
johnredding is the leader of the worldjohnredding is the leader of the worldjohnredding is the leader of the worldjohnredding is the leader of the worldjohnredding is the leader of the worldjohnredding is the leader of the worldjohnredding is the leader of the worldjohnredding is the leader of the worldjohnredding is the leader of the worldjohnredding is the leader of the worldjohnredding is the leader of the world
Theres a NATOR toronto?
sorry to thread crash.
Did you reflash your map? Maybe its not a mechanical problem.
Really i have no clue. Just a thought.
2007 Mazdaspeed 6 Black Mica
Richtuned
~Some things have been bolted on~
johnredding is offline   Reply With Quote
 Old 12-09-2012, 04:28 PM   #3
KusteLokal's Avatar
Posts: 2,664   (View Stats)
Groans: 124
@dantes5823; @rfinkle2; @Bucker; can this just be a glitch while logging?
KusteLokal is offline   Reply With Quote
 Old 12-09-2012, 04:29 PM   #4
that is debatable
The Following User Says Thank You to breakfasteatre For This Useful Post:
johnredding (12-09-2012)
 Old 12-09-2012, 04:49 PM   #5
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,157   (View Stats)
Groans: 792
Have you swapped fp sensors yet?
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 12-09-2012, 04:53 PM   #6
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
ugh ooooo!! You have joint a small club of Pu owners that have this issue. I'll try digging up the thread and post it here.
 Old 12-09-2012, 04:54 PM   #7
yep. As indicated in the first post, i bought a new sensor and it is currently installed
 Old 12-09-2012, 04:55 PM   #8
Ziggo's Avatar
Posts: 3,843   (View Stats)
It's an electrical glitch, fiddle with the plug on the fuel pressure sensor. It's fairly common, most guys just clean the connector and re-plug and it goes away. Sometimes it will strike again in a few months.
Bucker likes this.
Ask Me About My:
The Following 3 Users Say Thank You to Ziggo For This Useful Post:
breakfasteatre (12-09-2012), Bucker (12-10-2012), RichieRichness (12-09-2012)
 Old 12-09-2012, 04:57 PM   #9
Groans: 35
Fuel Pressure Dips
The Following User Says Thank You to RichieRichness For This Useful Post:
 Old 12-09-2012, 05:02 PM   #10
Tokay444's Avatar
Groans: 792
Reading fail, but yeah connector like we first thought.
Demodded.
The Seals
 Old 12-09-2012, 05:16 PM   #11
makes sense now, when i swapped in ansons sensor and i showed no drops, it was probably because i had unplugged it and replugged it in etc
 Old 12-09-2012, 05:18 PM   #12
Tokay444's Avatar
Groans: 792
Fucking hard wire that shit.
Demodded.
The Seals
dantes5823 (12-09-2012)
0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? AFcadet MazdaSpeed 3/6 - Troubleshoot/Diagnostics 24 08-02-2012 11:12 PM
Fuel Pressure Drop/Cut Burton MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 6 05-31-2012 06:43 PM
Fuel Pressure Drop after load of 2 dpolseno41 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 02-17-2012 06:37 PM
Fuel pressure logs KostasCX-7 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 03-25-2010 02:42 PM
Auto stocks suffer amid the Dow's 449-point drop Haltech Automotive News 0 09-17-2008 01:40 PM
Page generated in 0.32002 seconds with 26 queries
