Notices
Like Tree4Likes
 Old 04-03-2012, 12:31 PM   #41
Spirry's Avatar
Posts: 700   (View Stats)
Spirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the world
Groans: 31
Groaned at 28 Times in 15 Posts
Yes it would, it would delay/accelerate it slightly depending on which direction it was advancing/retarding. There are three lobes which probably don't quite line up with fuel injection events, so if the cam is on the trailing edge of applying fuel pressure when the injector opens AND the cam is retarding due to VVT falling off then that is pretty much the worst case scenario.
Thanks! Running two more psi boost on stock FP internals now.
Spirry is offline   Reply With Quote
 Old 04-03-2012, 03:20 PM   #42
Enki's Avatar
Posts: 3,042   (View Stats)
Enki has disabled reputation
Groans: 104
Groaned at 21 Times in 19 Posts
What did you ditch VVT and gain fuel headroom?
LMAO
 Old 04-03-2012, 03:56 PM   #43
Spirry's Avatar
Groans: 31
LMAO
Yup.
The Following 2 Users Say Thank You to Spirry For This Useful Post:
Enki (04-03-2012), GLORIFIEDBOZO (04-15-2012)
 Old 04-03-2012, 04:15 PM   #44
Enki's Avatar
Groans: 104
Should post a thread; this *seems* like a decent way to buy some headroom.
 Old 04-03-2012, 08:46 PM   #45
event's Avatar
Posts: 540   (View Stats)
event is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the world
I'm sure as hell interested. VVT is something I haven't touched. It seems like voodoo to me right now. Need more quality threads on the subject! Nobody ever talks about it except when they have to replace the tensioner.
***sold*** 06 MS6 Cobb SRI 3.5" ETS TMIC Cobb AP Sure RMM JBR SSP EBay Catless DP Autotech HPFP Magnaflow
2013 Scion FR-S 6MT
1993 Mazda Miata with shocks, springs, fsb, GT2560r, Megasquirt
event is online now   Reply With Quote
The Following User Says Thank You to event For This Useful Post:
Enki (04-03-2012)
 Old 04-28-2012, 12:06 PM   #46
Decepticon's Avatar
Posts: 1,218   (View Stats)
Decepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the world
Groaned at 43 Times in 28 Posts
OP did ur check engine light code p0303 go away when u installed the new relief valve? I'm getting the same exact issue.
06 MS6, Cobb AP, -TUNED on corn mix, KMD v2 fp internals, NGK Iridium IX sp, Cp-e Xcel NANO, PG tip, SU bpv, AWR rear MM, Jbarone shifter plate and bushings, ATP catted dp, Corksport catback, Altered Custom fmic, H&R springs...
R.I.P. 08.5 MS3, Cobb Ap, KMD v2 fp internals, Denso ITV22 sp, Cobb Sri, TurboXS bpv, SU rear mm, SU shifter bushings, ETS TMIC, SU boost tubes, Cp-e catted dp, Enkei EKM3.
Decepticon is offline   Reply With Quote
 Old 06-08-2012, 05:02 PM   #47
daafisch's Avatar
Posts: 1,909   (View Stats)
Groans: 27
event I'm having the same exact issues you're describing. 150-250 idle pressure, noisy spill valve, normal pressure at cruise and then triple digits under higher load, except autotechs look fine.
Did the relief valve cure all of these issues? If so where did you get another OEM relief valve?
2012 Black Mica : Cobb AccessPort <> CP-e XcelXL//Nviscid//Catted DP//xFlex Stage 2 RMM//HPFP//TowPlate <> Forge BPV v1 <> EGR Delete <> Autolite XP5263 <> SURE Countershift <> JBR Shifter Bushings//5mm Wheel Spacers <> Schroth Rallye 4 <> Progress RSB <> Kosei K4R 17x8 <> 235/45 ZII
OLD 2008.5 MGM : CP-e Nano//Nviscid//Downpipe//CBE//xFlex RMM Stage 1//xFlex PMM//xFlex TMM//Dashhawk Mount//Tow Plate <> SURE Countershift <> Cobb STS <> SeriouSpeed Slick Shift <> E4P Bushings <> Forge BPV v1 <> Koni Sports <> Swift Springs <> Progress RSB <> MSD Dashhawk <> Prosport Premium Boost <> RPM Ventpod <> Carbotech AX6 <> DBA 4000 T3 <> Technafit SS Brake Lines <> Brembo LCF 600 <> Kosei K4R 17x8 <> 235/45 Hankook RS-3 <> Stratified tuned
Liquid Dinosaur Racing - liquiddinosaurracing.com
Lime Rock Park 01:06.0
Watkins Glen 2:23.608
Summit Point 1:28.895
NJMP Lightning 1:23.891
Pocono North 1:07.230
daafisch is online now   Reply With Quote
 Old 06-08-2012, 05:16 PM   #48
smoogs12's Avatar
Posts: 3,648   (View Stats)
Groans: 166
daafisch As far as where to get a replacement RV, I believe that I had read in a thread that it was now available separate from the fuel rail at onlinemazda parts. Give them a call.
-Pat
NATOR CT Lives!!!
2008 True Red MS3
GT3071R 'n Stuff
smoogs12 is online now   Reply With Quote
The Following User Says Thank You to smoogs12 For This Useful Post:
rfinkle2 (06-13-2012)
 Old 06-10-2012, 08:10 PM   #49
event's Avatar
Check the fuel pressure with the car hot and off, it should rise to 1600+ psi. If it doesn't replace the RV. Look at the 2011+ CX-7 for the rail valve. You can get it at mazda dealerships.
2013 Scion FR-S 6MT
The Following 2 Users Say Thank You to event For This Useful Post:
daafisch (06-13-2012), rfinkle2 (06-13-2012)
 Old 06-13-2012, 05:45 AM   #50
daafisch's Avatar
Groans: 27
Pick one up from SPEED6 KILLAH last night and installed it. Seems to have fixed the problem. No more ticking and pressure is back to normal.
 Old 06-13-2012, 07:50 AM   #51
SPEED6 KILLAH's Avatar
Posts: 1,044   (View Stats)
that good to hear it fix. What is the pressure reading now?
I anyone need one just PM me future..
SPEED6 KILLAH is offline   Reply With Quote
 Old 06-13-2012, 08:58 AM   #52
daafisch's Avatar
Groans: 27
400+ at idle and seems to be holding at WOT.
Also, the spill valve isn't making anymore noise.
Last edited by daafisch; 06-13-2012 at 08:58 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-26-2012, 01:58 AM   #53
Jackis's Avatar
Posts: 301   (View Stats)
Jackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the world
Looks like I shoud revive this thread now...
A year ago I have installed KMD internals and have changed my ITFP body (so I believe it should be clean).
Several days ago I started noticing sudden drops when accelerating between 3-4K rpm. Unfortunately, my DH is not with me at the moment. I decided to wait a little bit and see if it'd happen again.
Last friday my car just didn't start at all. I tried this and that, touched and retightened all the connections as a dumb and so on, but nothing helped. Also noticed that when I turned the key on with the hood opened, I can here some very-very slight clicking noise (not noticeable with the hood closed). Looks like it is a spill valve, and I hope that very low clicking noise is acceptable?
I waited for my friend with my DH, we connected it and I saw Fuelrail Pressure is ONLY 40kPa (6 psi only), while it should be around 400!!!
Ok, I decided that either my HPFP internals died or my ITFP died or has wiring problems. Next morning I tried to start - fail. I got to my ITFP conenctions under back seat, removed PLENTY of debris and dust from it - and whoah! It started normally with correct fuel pressure numbers.
I decided that it was electrical issue, also dureing a week-end there were no pressure drops at WOT also, car went fine as it should. But yesterday morning I again tried to WOT - and it stumbled several times at 3.5-4K range in 5th and 6th gear (3rd looked fine tho).
Yesterday evening on a way home there were huge tropical rain here, almost an hour. I didn't WOT because I didn't want water droplets hitting my MAF... But it looked fine and stable with fuel pressure on idle and cruise.
Today morning it just didn't start again, and nothing helped. And I again have no DHs with me, but I bet it is the same unreal FuelRail pressure before the start.
This issue now is annoying for me, because I really have my BT stuff ready to set up, and because I am not familiar so far with all those spill valves/ratainer valves/..., I want to ask you for the advice and directions what to do.
Thank you for your time!
Does your MS3 start when it's -30C (-22F)?
Forged, bolted, tuned, gtx30/tial/ewg. Thanks.
Jackis is offline   Reply With Quote
 Old 07-02-2012, 12:03 AM   #54
Jackis's Avatar
If someone ever interested, I have localized my issue above.
KMD piston was jammed in the upper point and never moved on the internal. A lots of scratches also.
Don't know what was the reason - maybe the fuel, which was in my tank for 2 months while I was repairing my car. May be. I am pretty sure installation was fine - I did all to the T. The whole last year (15K) before failure is gave me solid pressure.
I don't want to blame KMD, it can be the fuel issue (the dirt from the tank, for example, I donno), but the fact is...
So far put the stock internals back.
Low Fuel pressure @ Idle w/Cp-e HPFP 801MS3 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 32 04-17-2012 06:00 AM
Autotech internals, 390 - 400 psi idle fuel pressure Domino81 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 24 03-13-2012 04:31 AM
Please help!! Vacuum, idle, fuel pressure,... MPS Power MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 12-14-2011 08:25 AM
60psi fuel pressure at idle! CCC MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 31 10-04-2011 05:28 AM
Fluctuating Fuel Pressure at Idle Campo MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 13 02-09-2010 06:03 PM
Page generated in 0.36501 seconds with 27 queries
