  • 1 Post By Enki
 Old 05-20-2011, 03:19 PM   #1
801MS3's Avatar
Posts: 453   (View Stats)
801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world
Groans: 30
Default Low Fuel pressure @ Idle w/Cp-e HPFP
So my idle pressure typically is in the normal range 415-430 range.. but after driving hard or doing a pull the idle pressure drops to 380-395 range... This was happening before turbo, and on several different maps..
Any ideas?
Again this is a cp-e HPFP.
Thanks in advance.
08.5 MS3- : ATP GT3071r: cp-e XL intake: cp-e big inlet: cp-e rmm 75 Duro: cp-e e-flex motor mounts : cp-e catted down pipe: cp-e cbe,: cp-e FMIC, cp-e HPFP: cp-e safe seals : DNP Manifold: COBB AP: COBB RSB: DO stg 2 meth kit ,: SURE TIG's, : KW V2 coilovers: Konig Milligram 18x8.5 +35, Hankook ventus evo's 235/40/18, Saitek adj endlinks :HKS BPV: TWM STS:
465whp 468 wtq Best e.t 11.9 Best trap 123mph
801MS3 is offline   Reply With Quote
 Old 05-20-2011, 03:24 PM   #2
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Groans: 166
Im pretty sure Ive seen mine (PTP) dip slightly after hard runs. So does it return to normal? I see 420 or very close normally
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
Originally Posted by Say Chi Sin Lo View Post
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
 Old 05-20-2011, 03:30 PM   #3
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
DONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the world
Groans: 266
Groaned at 83 Times in 60 Posts
if your above 1600 and wot your fine. You are leeting off the gas fuel demand drops. Therefor fp drops
Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next.
DONOTBUGME is offline   Reply With Quote
 Old 05-20-2011, 03:31 PM   #4
Spoofmastafly's Avatar
Posts: 1,444   (View Stats)
Spoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the world
Mines dipped lower than that at idle.. I wouldn't be to worried about it. Now if you start dropping that low at WOT then you have problem.. evening just coasting when driving down the highway i'll see my fp drop to around 450-600. Tap the gas and back to 1700psi.
Spoofmastafly is offline   Reply With Quote
 Old 05-20-2011, 04:12 PM   #5
801MS3's Avatar
Groans: 30
Yea my wot and normal driving is fine.. it was the dipping idle that had me concerned..
 Old 05-20-2011, 05:09 PM   #6
380-395 is normal at idle under certain conditions. Nothing to worry about.
801MS3 (05-20-2011), 802MS3 (03-12-2012), I Love Brownies (05-25-2011), Teethkikr (04-17-2012)
 Old 05-24-2011, 08:32 PM   #7
mo4130's Avatar
Posts: 118   (View Stats)
mo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant future
Groaned at 13 Times in 4 Posts
Yea, I had the same probelm, but like stated, I tap the gas and it instantly jumps to about 1700. By far the best mod for the car.
09 mgm sp3 Cp-e hpfp, jbrone sstp, heavy weight knob, gutted midpipe, ets tmic, trz rmm, ht tune, cobb sir/tip. rx wheels with some fat meats
mo4130 is offline   Reply With Quote
 Old 05-24-2011, 08:40 PM   #8
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
you're fine. safe as kittens.
what's your idle rpm setting? i notice my idle fp went up a little when i raised the idle rpm.
 Old 05-24-2011, 10:27 PM   #9
801MS3's Avatar
Groans: 30
Idle is set @ 850..
i am now concerned about my FP staying high (1800+) after a hard pull.. after i let off and i decell until i blip the throttle it stays at about 1800. Could be normal.. never noticed it before..
 Old 05-24-2011, 10:44 PM   #10
eppopipe's Avatar
Posts: 601   (View Stats)
eppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the world
Groaned at 12 Times in 8 Posts
Mine does the same with KMD internals, far as I can tell its normal
2010 Blue Mazdaspeed3
CP-E Nano Intake - JBR 88D Trilogy - Cobb AP - Sure Shortcut - 20% tint - Blox 490g shift knob - Big stereo system (WIP) - Singer 400AMP alternator - Turbosmart dual port - KDM V2 FP Internals - 10k DDM HID's (lows) - 12k HID's (fogs) - UR CBE (no mufflers) - Vibrant Ultra Quiet resonator - CP-E TMIC - UR Resonated Test Pipe - Dano Perm Tune - Blockhead Dual Gauge Vent Pod (painted) - Aeroforce Interceptor x2 - 19 inch RonJon Inspyres
eppopipe is offline   Reply With Quote
The Following User Says Thank You to eppopipe For This Useful Post:
kgb (04-02-2012)
 Old 05-24-2011, 10:58 PM   #11
AJ713's Avatar
Posts: 291   (View Stats)
AJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the world
My cp-e hpfp has started doing the same thing this week. Glad to hear i'm not alone. i started losing my shit alittle.
~AJ
AJ713 is offline   Reply With Quote
 Old 05-25-2011, 01:02 AM   #12
pearl_ms3's Avatar
Posts: 545   (View Stats)
pearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the world
Groans: 32
Groaned at 27 Times in 12 Posts
Mine does is occasionally as well.
Sent from my SGH-T959V using Tapatalk
CP-E INTAKE W/ AMSOIL FILTER, CP-E INLET, TURBOSMART BOV, DENSO ITV22, AWR RMM, STREET-UNIT TMM & PMM, STEEDSPEED MANI CERAMIC COATED, T3 GT3076, TIAL EWG, CUSTOM V-BAND DOWNPIPE, UR CATTED TESTPIPE, TURBO XS CATBACK EXHAUST, COBB FMIC, CP-E FUEL PUMP, DASHHAWK+CP-E MOUNT, JBARONE SSP, COBB ACCESSPORT STAGE 2 SF 91 FMIC. SELF TUNED WITH 400HP/375TQ @ 21 PSI ON 100 OCTANE.
pearl_ms3 is offline   Reply With Quote
 Old 05-25-2011, 01:05 AM   #13
snailD's Avatar
Posts: 3,039   (View Stats)
i guess the cp-e pumps all suck now? lol
The Following User Says NO Thank You to snailD For This Un-useful Post:
 Old 05-25-2011, 01:06 AM   #14
DONOTBUGME's Avatar
Groans: 266
no people are just retarded
The Following 3 Users Say Thank You to DONOTBUGME For This Useful Post:
Alpha (03-12-2012), I Love Brownies (05-25-2011), mazdafreak (03-19-2012)
 Old 05-25-2011, 08:28 AM   #15
801MS3's Avatar
Groans: 30
Thats just a stupid thing to say...
All this talk to "pressure release valves" Im not really sure what/how they work so.. Just making sure its nothing to be concerned about..
 Old 05-25-2011, 08:40 AM   #16
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
mine does it
dont really care tbh, so long as it runs
 Old 05-25-2011, 09:34 AM   #17
snailD's Avatar
i was joking, but i thought it was pretty intelligent
 Old 03-12-2012, 02:57 PM   #18
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
Anyone ever figure out what causes this? Noticed this also, after a hard run, or getting on it, fuel psi is 350-400 when I'm stopped at idle, and gradually works it way back to 410-430psi.
 Old 03-12-2012, 09:22 PM   #19
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
here too. pretty sure its normal. if your FP drops below 1600 at WOT, then you have problems.
'08 CWP MS3 w/ T3 3071r
 Old 03-12-2012, 11:25 PM   #20
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
When you engine brake, the car will command 0 PSI for whatever reason, and under certain conditions it will actually drop below 200 PSI because of it. Compare commanded to actual pressure in the log, and if lower, check fuel trims to see if it's actually causing issues.
charern (01-04-2013), Mizzle (03-12-2012)
 Old 03-12-2012, 11:45 PM   #21
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Because 0psi = great mileage.
 Old 03-13-2012, 05:17 AM   #22
G26
G26's Avatar
Groans: 39
Not talking about engine braking. I'm talking about being completely stopped idling.
 Old 03-13-2012, 03:05 PM   #23
G26
G26's Avatar
Groans: 39
@HPFPUPGRADE
Want your opinion on this phenomena.
 Old 03-14-2012, 01:21 AM   #24
HPFPUPGRADE's Avatar
Posts: 403   (View Stats)
HPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the world
Groaned at 22 Times in 17 Posts
I have never seen a datalog command 0 psi, the lowest I have ever seen is 291 psi.
Now, I have seen IDC drop to 0, but never fuel pressure (commanded).
Any ideas?
Thanks in advance.
This is common, pressure drops after a hard pull clutch out will drop to that level. Nothing to worry about.
Last edited by HPFPUPGRADE; 03-14-2012 at 01:21 AM. Reason: MSF Database - Automerged Doublepost
HPFPUPGRADE is offline   Reply With Quote
 Old 03-14-2012, 01:30 AM   #25
Enki's Avatar
Groans: 189
Everyone sees IDC drop to 0 when engine braking. First time I had commanded pressure drop to ITFP pressure I almost shit my pants as I was at the track racing. It ran fine afterwards, and the next day it happened again; fortunately, I caught the event in logs at the track and realized the ECU was being gaytarded.
 Old 03-17-2012, 01:04 AM   #26
74te27's Avatar
Posts: 36   (View Stats)
74te27 is a name known to all74te27 is a name known to all74te27 is a name known to all74te27 is a name known to all74te27 is a name known to all74te27 is a name known to all
my fuel pressure sometimes drop to 298 when I decelarate and when I go wot the pressure jumps back to 1700 psi but I never seen it hit 1800 psi I guess it's normal ? I have c-pe pump.
74te27 is offline   Reply With Quote
 Old 03-18-2012, 04:23 AM   #27
jeopardy98's Avatar
Posts: 1,920   (View Stats)
Groans: 112
I did some mods tonight and flashed a stage 1 map just to keep things straight. I installed Autotech internals, Cobb SRI, HTP TIP, and a SU TMIC. Still running stock DP and exhaust. I logged fuel pressure all the way home just to see how things were going and never went WOT. I have a few readings in the 260-280 range. I am attaching my log. Is this normal?
jeopardy98 is offline   Reply With Quote
 Old 03-18-2012, 07:46 AM   #28
G26
G26's Avatar
Groans: 39
I don't think you guys are understandIng what I am saying is the issue. I know fuel psi when coasting will be high 200s anytime.
I am talking about after doing an aggressive pull, and completely stopped at idle, fuel psi can be anywhere from 340 to 400, and slowly work it's way back to 410, 430.
 Old 03-18-2012, 08:14 PM   #29
801MS3's Avatar
Groans: 30
From what everyone including PTP.. that this is normal and not to be concerned.
The Following User Says Thank You to 801MS3 For This Useful Post:
G26 (03-19-2012)
 Old 03-18-2012, 10:07 PM   #30
Enki's Avatar
Groans: 189
I actually just saw this on a stock tune genpu I helped put internals in today; only this happened at idle pretty much any time. If this is normal, it makes me feel better about my work lol
scorpiorc10 likes this.
scorpiorc10 (03-21-2012)
 Old 03-19-2012, 05:18 PM   #31
Very common, nothing to worry about.
Bingo!
Thanks!!!
The Following User Says Thank You to HPFPUPGRADE For This Useful Post:
G26 (03-19-2012)
 Old 03-21-2012, 11:39 PM   #32
scorpiorc10's Avatar
Posts: 167   (View Stats)
scorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the world
Groans: 77
Groaned at 103 Times in 42 Posts
i have autotech internals that @Enki helped install and my pump is doing the same thing.
410-430 psi at idle
scorpiorc10 is offline   Reply With Quote
 Old 04-17-2012, 07:00 AM   #33
Teethkikr's Avatar
Posts: 677   (View Stats)
Teethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the world
Groans: 50
FWIW I had autotechs on my 2010 and it was ALWAYS around 400-420 at idle under ANY conditions.. Installed brand new autotech on my 2012 and just this morning saw 370-420 after driving... I guess its okay from what I am reading
2012 CWP Tech Package:
Powdercoated Rx-8 Wheels//35% Tint//Cobb SRI//COBB TIP//CS LED Kit//UR Test Pipe//Autotech Internals//TRZ RMM//Painted Front Grille//Painted Emblems//
Teethkikr is offline   Reply With Quote
Fuel pump internal/HPFP,really necessary? RMCAT MazdaSpeed 6 - Engine, Transmission & Driveline 13 08-09-2013 09:22 AM
How to scale the HPFP pressure sensor djuosnteisn MazdaSpeed 3/6 - ECU Computer Tuning 521 04-07-2010 08:39 AM
Fluctuating Fuel Pressure at Idle Campo MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 13 02-09-2010 07:03 PM
What is your manifold pressure at idle? florindi
Cobb Access Port/Maps
3 02-19-2009 07:37 PM
Page generated in 0.51571 seconds with 41 queries
