MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection Have a CDFP fuel pump question? Do you want to add Nitrous or Water Injection to your Mazdaspeed 3/6 ? Please come on in! |
![]() | ![]() | #1 | ![]() |
![]() Join Date: Oct 2008 Location: Carson, CA
Rep Power: 974 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
Groaned at 54 Times in 27 Posts
(Thread Starter) | ![]() ![]() ![]() I have been searching high and low for a good compact push to connect inline filter for my meth kit. The location I have my pump and tank doesn't allow for the bulker ones like AEM/DO has. After some research I bumped into this The Clear-VU EZ Connect Filter I guess the target market is the food and beverage industry but from what I have been able to find out all the materials used have very good compatibility with methanol. The plus side is they will send you a sample for free. Overview: -PET housing has best compatibility rating http://www.plasticseurope.org/Docume...-003-EN-v1.pdf -EPMD or Buna-N O-ring both have has excellent compatibility Chemical Compatibility Database from Cole-Parmer - SS (gripper teeth in push to connect) has excellent compatibility -Compact and clear for easy viewing -10 or 48 micron filter (I'm going to test for adequate flow on both but I believe there would be no issues with the 48 micron filter) hqdefault.jpg clear-vu-filter-ism.jpg
__________________ *COBB: AP, shifter weight *BITWISE: Harness, 3bar BNR: S3v2 *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, EGR delete, WP *GRIMMSPEED: EBCS *TWM: Full Shifter *KDM: HPFP internals *DENSO:ITV22 *FORD: syn trans fluid *OBX: TBE *BILSTEIN: B8 Sport *SWIFT: Spec-R springs *GTSPEC: 4point ladder brace, rear subframe brace *NITTO: NT-05 * Whiteline: BSK *MOOG: F/R endlinks* SPC: Adj. camber arms *MORIMOTO: 5K HID elite Last edited by specvspeedfreak; 01-14-2016 at 11:16 AM. |
![]() | ![]() | #2 | ![]() |
![]() Join Date: Mar 2013 Location: North Brunswick, NJ
Rep Power: 1122 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,644
Groans: 143
| ![]() ![]() ![]() Awesome. Definitely interested in this. Let me see if I can research methanol compatibility.
__________________ 2007 Mazdaspeed3 GT |
![]() | ![]() | #3 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Installed. These are non-serviceable but cheap at $7 ($25 minimum order)... 48 micron flowed much better so I am using it. Just need to test some more and cut the tubing a bit longer...otherwise it's perfect with my setup.
__________________ *COBB: AP, shifter weight *BITWISE: Harness, 3bar BNR: S3v2 *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, EGR delete, WP *GRIMMSPEED: EBCS *TWM: Full Shifter *KDM: HPFP internals *DENSO:ITV22 *FORD: syn trans fluid *OBX: TBE *BILSTEIN: B8 Sport *SWIFT: Spec-R springs *GTSPEC: 4point ladder brace, rear subframe brace *NITTO: NT-05 * Whiteline: BSK *MOOG: F/R endlinks* SPC: Adj. camber arms *MORIMOTO: 5K HID elite |
![]() | ![]() | #4 | ![]() |
![]() Join Date: Nov 2009 Location: Vancouver, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| ![]() ![]() ![]() What size is your meth line?
__________________ COBB AP : JBR 3 Inch Full Intake : CORKSPORT TMIC : AUTOTECH INTERNALS : JBR SSP CPE Full RMM : Cobb Catted DOWNPIPE : BNR S3 : KW V1 Coilovers : Klutch SL18 Rims Guardian Angel : Stratified 3 Port : Michelin PSS 235/40/18 : SNOW PERFORMANCE : E85 Stratified Tune |
![]() | ![]() | #5 | ![]() |
(Thread Starter) | ![]() ![]() ![]() 1/4 inch... but after some testing it seems that it might be restricting some flow at the top end (6k rpm and up)... I am not 100% until my tuner confirms. Will update.
![]() | ![]() | #6 | ![]() |
Groans: 143
| ![]() ![]() ![]() @specvspeedfreak; Do you have your inline filter installed on the feed or pressurized side of the pump? I would really like to install an inline filter just prior to my methanol flow gauge, but none of the ones I've seen so far (this one and the AEM I bought) are rated for 200 psi. I'm wondering though if this one would be usable at 200 psi despite its "rating".
![]() | ![]() | #7 | ![]() |
__________________ *COBB: AP, shifter weight *BITWISE: Harness, 3bar BNR: S3v2 *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, EGR delete, WP *GRIMMSPEED: EBCS *TWM: Full Shifter *KDM: HPFP internals *DENSO:ITV22 *FORD: syn trans fluid *OBX: TBE *BILSTEIN: B8 Sport *SWIFT: Spec-R springs *GTSPEC: 4point ladder brace, rear subframe brace *NITTO: NT-05 * Whiteline: BSK *MOOG: F/R endlinks* SPC: Adj. camber arms *MORIMOTO: 5K HID elite | |
![]() | ![]() | #8 | ![]() |
Groans: 143
Sent from my A0001 using Tapatalk
__________________ 2007 Mazdaspeed3 GT | |
The Following User Says Thank You to MD1032 For This Useful Post: | specvspeedfreak (02-10-2016) |
![]() | ![]() | #9 | ![]() |
![]() Join Date: Jan 2014 Location: Harco MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
| ![]() ![]() ![]() I've been looking for another filter ever since my check valve got clogged open. I ordered one so I'll give it a try and get back with my findings.
__________________ 2008.5 CWP MazdaSpeed3 Purple Drank Tuned ATP GT3076R @ 26 psi 369.5whp & 348wtq.. yawn ![]() |
![]() | ![]() | #10 | ![]() |
| ![]() ![]() ![]() I asked for a sample of the 48 and 65mm. They sent me 2 of each.
![]() | ![]() | #11 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Just an update.. I don't think there's a problem with filter.. I tested and verified the same (small) amount of KR without running the filter... My meth mixture or tune will need to be adjusted a bit, that's all.
![]() | ![]() | #12 | ![]() |
![]() Join Date: Sep 2011 Location: Frankfort, Kentucky
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
| ![]() ![]() ![]() If your pump has the 3/8 NPT fittings, I would look at going 3/8" hose and the 3/8" version of the filter to reduce resistance and most likely increase surface area. |
![]() | ![]() | #13 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Just received a 65 micron filter as well.. once I figure out my KR issue I will go back to the 48 micron (test again to verify of course).. but it doesn't seem the filter is the issue so far. If you have your tune dialed in; I would recommend using the 48 micron filter... the only reason I thought it was an issue was due to lack of logging prior to the filter being installed... so it was just process of elimination for me.
![]() | ![]() | #14 | ![]() |
| ![]() ![]() ![]() I've been running the 48 micron now for a couple weeks and I have not noticed any negative affects. Presumably the filter can flow 10gph no problem so there was no flow loss. I haven't had my check valve get stuck open either since install so I'll say it's doing it's job well.
![]() | ![]() | #15 | ![]() |
![]() | ![]() | #16 | ![]() |
| ![]() ![]() ![]() Yeah I use it for daily driving but for the dyno the other day I took it out juuuust to be safe
Display Modes | |
inline oil filter for BT | LiEast | MazdaSpeed 3/6 - Big Turbo Builds | 15 | 08-11-2011 12:02 PM |
inline converter colors??? | bikerboy2182 | 2010 MS3 - Car Audio & Electronics | 4 | 03-09-2011 08:47 AM |
Bid farewell to BMW's legendary M inline-six | Haltech | Automotive News | 0 | 12-30-2008 09:40 AM |
Inline bov video | steedspeed | MazdaSpeed 3/6 - Turbo Induction | 2 | 10-07-2008 10:49 AM |
