  • 1 Post By neganox
 Old 12-15-2015, 10:17 AM   #1
Tyhackman15's Avatar
Posts: 1,742   (View Stats)
Tyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the world
Default Methanol Pump - Storage
Question for all those who store their meth injected cars in the winter, do you leave the pump hooked up and fluid in the lines? Or should I disconnect the lines and run the pump to clear it out for storage? I can't seem to find any definitive answers on Snow's website (running a snow performance system). I run blue washer fluid fwiw.
Any insight is appreciated, thanks.
SOLD 2008 MS3 17x8 Evo 9's, 235 v12
1995 Miata 1.8L w/ FMII GT2560R @11psi, FM stage 2 clutch/flywheel, FM Frame rail braces, FM high capacity radiator/fans, RB Sway bars, Racing beat exhaust, Fat cat Coilovers, Jongbloed 15x9, Wilwood 4 wheel BBK, Rollbar, Hardtop, TDR Racing seat
2001 Saab 9-3 Viggen 2.3T Stage 3+ bro, SRI, 3" DP, ETS FMIC, 17x8 BBS RK2's, Full chassis bracing / sway bars, Forge BPV, Winter/DD
Tyhackman15 is offline   Reply With Quote
 Old 12-15-2015, 02:57 PM   #2
FittedMazda's Avatar
Posts: 53   (View Stats)
FittedMazda is a glorious beacon of lightFittedMazda is a glorious beacon of lightFittedMazda is a glorious beacon of lightFittedMazda is a glorious beacon of lightFittedMazda is a glorious beacon of light
sub'd
2010 MS3 -Black Mica- EBTEC Built Motor, ACT 6 Puck, CM Meth Kit, OBX Exhaust, GT2871, BSD, Coolant Bypass, AEM Failsafe, EGR Delete, CNT DP, HTP 3.5" Intake, JBR OCC, OZ Ultraleggera 18", and moar
FittedMazda is offline   Reply With Quote
The Following User Says NO Thank You to FittedMazda For This Un-useful Post:
tegxsi (12-15-2015)
 Old 12-15-2015, 03:21 PM   #3
Feline Führer
neganox's Avatar
Posts: 1,790   (View Stats)
neganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the world
Groans: 49
I'd flush the system with distilled water to clear out any old residue. Your meth was probably a mix, but that blue stuff probably has dyes in it that will dry up and clog things.... I know Snow's overpriced boost juice did.
Tyhackman15 likes this.
Official CatDickRacing Sales Rep - All products backordered.
neganox is offline   Reply With Quote
The Following User Says Thank You to neganox For This Useful Post:
WetzMS3 (12-16-2015)
 Old 12-15-2015, 05:42 PM   #4
sheston's Avatar
Posts: 1,847   (View Stats)
Winter's when the car gets really fun :-)
The Following User Says Thank You to sheston For This Useful Post:
MS3Shadow (12-15-2015)
 Old 12-16-2015, 10:15 AM   #5
In the Midwest fall = boost season. Once you put on the snow tires all fun is on hold lol.
E85 Storage TRSpeed MazdaSpeed 3/6 - E85 Fueling 45 01-30-2013 11:45 PM
Mazda6 MPS, HTA 3076, 93 pump gas, methanol @ Mustang Dyno. 434/433 WCF MazdaGaragePat MazdaSpeed 3/6 - Dyno Sheets/Discussions 30 12-04-2011 10:15 PM
Mazda6 MPS, 3076, 93 pump gas, methanol @ Mustang Dyno. 394/409 MazdaGaragePat MazdaSpeed 3/6 - Dyno Sheets/Discussions 26 06-06-2011 03:02 AM
Page generated in 0.25746 seconds with 23 queries
